Question about ASUS P4T-M Motherboard
Error codes The hard drives have been previously erased and when I tried a clean install of windows 2000 I got 4 different error code messages and it said it could no longer continue the installation process. I believe the error codes were: 0x4,0x1,0,0. How do I find out what these codes mean and what do I do to rectify the problem?
    Problem Solver:
  • 12 Answers
This type of error code can occur when installing Windows 2000, if there is some sort of hard drive confliction. If you have multiple hard drives in the computer. Please unplug all other hard drives except the MAIN drive that you are installing on, if the errors still occurs you may want to try installing to a different hard drive as your main drive, or replacing the IDE or SATA cable.
Another option to consider is that format did not complete correctly, you may want to viist the website of the manufacturer of the hard drive you are installing on and retrieve the utility to perform a Low-Level format on the hard drive - this will erase any and all data on the drive.
Posted on Jun 18, 2008
Error message 2000-0151 on dell inspirion 1545
Hi.
Remove and reinstall the Hard Drive for the error codes:
  • 1000-0141
  • 2000-0141
  • 1000-0142
  • 2000-0142
  • 1000-0143
  • 2000-0143
  • 1000-0144
  • 2000-0144
  • 1000-0145
  • 2000-0145
  • 1000-0146
  • 2000-0146
  • 2000-0151
Please see the Service manual for instructions on how to remove and replace the Hard Drive. Be sure to remove and reinstall the cables for the hard drive if you are on a Desktop Computer.
After reinstalling the hard drive re-run the diagnostics if you receive the same error code Contact Us.
Run the Drive Self Test (DST) from the Utility Partition also known as the 32 bit diagnostics to determine if the previous error has been corrected. If the DST from the Utility Partition does not indicate a failure of the drive, we consider the error to have been corrected and the drive does not need to be replaced.
  • 1000-0146
  • 2000-0146
For instructions on how to run the Dell 32 bit diagnostics click here.
Regards.
Sep 05, 2011 | Computers & Internet
Dear sir , i have a dell inspiron 1464 laptop.i have a problem during window installation.in a diagnostic test there are a error generate. the error code is, Error code 0146 Msg:Error...
Dear questioner after going through couple of posts on dell support forum I found that this problem occurs if your hard drive is not functioning well
If you laptop has warranty please visit the nearest dell store
Aug 06, 2011 | Computers & Internet
Erroe Code 0146 (Dell Inspiron E1505) MSD Unit 0 DST Log contains previous error. ???
Hi ! Error code is this error code 2000 - 0146??? if that is the error message you have to contact dell technical support to replace the hard drive because that error code mean that the hard drive is already faulty. You can Reinstall the Hard drive as well but it is not guarantee that it will fix the issue. Most of the time dell will send a hard drive replacement for that kind of message if the system is still in warranty it will be free but if not you have to pay for the replacement. Hope this will help you . God Bless!
Apr 18, 2011 | Dell Inspiron E1505 Notebook
Hello, I have a laptop Dell Inspiron 1501. A two days ago I reinstalled Windows Vista, because I've had some problems wih my internet connection and some other. So I installed it and everything is ok,...
Hi!
It is not yet the end for your machine. The error codes refers to a faulty hard drive. You'll need a new hard drive for replacement and that will fix the problem.
Should you have any other questions just leave a message.
All the best!
Musicaddict
Sep 15, 2010 | Computers & Internet
Dell studio windows failed to start. error code 2000-0146
the Error code was sited below as the (Disk Self Test) DST Log contains previous error(s)
in case of your error DST log contains previous error(s) doing a
chkdsk /r or a repair reinstall of xp might resolve the issue.
to resolve issue...
Error Code Error Message 1000-0141
or
2000-0141 No Drive Detected 1000-0142
or
2000-0142 Drive Self Test Failed Status Byte=XXh 1000-0143
or
2000-0143 Drive Smart Read Command Failed 1000-0144
or
2000-0144 No Support for Drive Self Test Error Code Error Message 1000-0145
or
2000-0145 Timeout waiting for Drive Self Test to complete 1000-0146
or
2000-0146 DST Log contains previous error(s) 1000-0147
or
2000-0147 Unit (x): IDE status failed. Status byte = (x) Control Code = (x) Msg = (s) 1000-0148
or
2000-0148 IDE ERROR: status (x) (s)
Aug 07, 2010 | Dell Studio 17 Laptop
I am getting the message error code 2000-0142 on my inspiron 1525. Does this mean the hard drive needs to be replaced and if so, was it something I did? It was working fine in the morning and then in the...
If reseating your hard drive doesnt fix it, Insert your Windows disk into your cd/dvd drive
As the machine boots up, hit the F12 key
This will give you the option of where to boot your machine from.
Select boot from CD/DVD drive
The disk loads some files and gives an option to either install windows or repair, select repair and boot onto Windows (select 1)
It brings you to a command prompt :
Type in CHKDSK/R
Hit the ENTER key
Jan 09, 2010 | Dell Inspiron 1525 Laptop
Error Code 2000-0146
I know this is not what you will want to hear, but according to the Dell Support site, error code 2000-0146 indicates: DST Log contains previous error(s). This means that the drive is failing and needs to be replaced. ASAP is best. I would suggest that you backup anything on the current drive that want to move to the new drive. If the computer is under warranty, contact Dell Support and they should ship you a new drive. If there is no warranty remaining, you will need to purchase a similar type of drive. Once you have the new drive, install it and then reinstall your software. It should go more quickly is you can use the recovery CDs that were shipped with the computer originally.
Good luck, and please let me know how it turns out for you.
~ Spoem
May 18, 2009 | Dell Inspiron 1501 Notebook
Windows XP does not recognise hard drive
Try pressing F6 to install special driver while booting the install CDROM
Mar 27, 2009 | Computers & Internet
Windows XP installation error
i have had the same problem when the hard drive was about to die or the ram is faulty
take ram out and clean gold edges with rubbing alcohol or a pencil eraser,
insert ram, if you have more than one chip try one at a time as one may be failing, ie (a bad spot on the chip and only stops the install when it gets to that location on the ram chip)
when you are running the install ,windows will ask you if you want to use the partitions on the drive
,say no and delete select partition ,this will format the hard drive and set a new one up,if the drive has problems it should show up then.
good luck ,and let me know how you go
Terry
Mar 31, 2008 | Computers & Internet
WinXP installation error
This problem can start when you have a ram problem or the drive is about to crash.
take ram out & clean the golden edge both sides with rubbing alcohol or a pencil rubber.replace the ram
when you start the install again, do not use the partition that is on the drive now ,go for format and set up new partition,windows will check the hard drive for errors before it starts to install,
hope this helps you
good luck let me know how you go
Terry
ASUS P4T-M Motherboard Logo
159 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
