Question about Cameras
When I turn the camera on it makes a very fast beeping sound and on the screen is a yellow arrow. I can't get it to do anything. What could it be?
  • Cameras Master
  • 2,200 Answers
Please remove the batteries completey from the camera for 10 minutes. Replace and see if the issue is resolved.
If not please supply the exact make and model of the camera.
Thanks for using FixYa.
Posted on Nov 14, 2010
My acer aspire laptop makes a beep sound when swith on button is pressed
beep are of manyh types how many beeps it gives?????? reply me fast so that i can help u
Jul 06, 2012 | Acer Computers & Internet
Arrow comes on screen beeps then beep sound goes off arrow still there cant record or play while arrow is there
the capstan in the mechanism of your camera faulty it need to be changed.after changing it, if the problem is not solve you will need to past the error code on the screen.good luck
Aug 22, 2011 | Sony Handycam DCR-TRV250 Digital Camcorder
When turning on to vcr or camera, camera beeps repeatly
Sounds like the camera ATE THE TAPE will not eject,fastforward, or rewind.. This will need to be repaired , worse case a belt slipped or something got misalligned inside, I would recommend a camera shop so you can save the tape otherwise digging into this yourself could stirr up more issues in the long run. Please do be considerate of facts here that we cannot see your unit and this error is because the tape got ATE or something got jammed.
Thanks please do leave some feedback and ratings for your free answer today.
May 29, 2010 | Sony Handycam DCR-HC14E Mini DV Digital...
Flashes turn off and on in the LCD. beep sound
Hello!
Please consider the troubleshooting given below:
(a) Remove the Battery from the Camera then press and hold the power button for 30 seconds.
(b) Reinsert the Battery pack and turn ON the Camera. Please make sure that the Battery pack is fully charged.
(c) Next, try resetting the Camera to the original factory settings if the menu options are accessible on the Camera.
Perform the steps given below to reset the Camera to the original factory settings:
(i) Press the Menu button on the Camera to access the menu options.
(ii) Press the right arrow on the control button to select (Setup) setting, then press the right arrow again.
(iii) Press up/down/left/right arrow to select the Setup 1option.
(iv) Next, select the Initialize Option and select OK.
Performing the above mentioned steps will reset the Camera to the original factory settings.
If the issue persists even after performing the above mentioned steps then service will be required.
Aug 23, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Blurry Display Screen and 2 beeps with shutting Off
check the mode that the camera is in try to put it in auto mode, if its in other mode like fast motion etc it can cause this blurry pictures
Jul 13, 2009 | Samsung S860 Digital Camera
Turn on camcorder get a beeping sound message number 31:22 and a
Try Google this problem. You will 10K answers. Just slap it hard on TAPE side. Reset or powerdown couple of time. Remove tape couple of times , You should eb OK.
No solution for this is a mechanical + digital hybrid issue.
I need to know on Firewire connectivity with Dell D520..Please help if you have any info.
Basically it doesn't detect , not showing in Imaging devices.
Jan 23, 2009 | Sony Handycam DCR-TRV250 Digital Camcorder
Video playing in fast forward with no sound
This is a really simple problem and easy to solve.  Unfortunately the videos you've recorded cannot be changed back because they have been recorded in Time Lapse mode.
With the camera switched on in Video Mode turn the control dial on the back (this is the dial to the right of the LCD screen).  This will change the settings from TIME LAPSE to STANDARD.  There are actually 6 different modes but the best one for normal videos is STANDARD.  There is a HIGH RESOLUTION setting,  however these record fewer frames per second (fps) so whilst the quality is better per frame,  there are half the amount of fps so the the movie will look at bit jerky.
It's really easy to accidentally twist the dial when holding the camera,  so always check the icon in the top right of the LCD before recording to make sure its just a yellow camera in a yellow square.
This should be problem solved for all future recording.
Jan 05, 2009 | Canon PowerShot G9 Digital Camera
I have a digital video camera DCR-TVR140 and when I put the little casset on the screen(on center) appear a litttle arrow blinking and also a beep beep sound for maybe 5-10 seconds and still like that with...
Do you see any error number on LCD such as C32:11
If no.
1) It could be the Digital 8 tape is at the end set the unit on VTR mode then rewin the tape
2) The tab for record protection is on that mean the red tab at the right hand side full red indicated SAVE just turn to REC position in this case you can try on VTR mode it should work
Dec 01, 2008 | Video Cameras
Camera making beep beep sound and wont turn on
omfg, same, some *** better help us fix this.
thank youuu
Apr 02, 2008 | Samsung Digimax S730 Digital Camera
Icon
camcorder is just saying get this tape out of me. may be the tape, may need cleaning only or possible tension adjustments.
May 23, 2007 | Sony Handycam CCD-TR517 Camcorder
Cameras Logo
12 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
