Question about Little Giant WGP-65-PW 1/8 HP, 1900 GPH Premium Dual Discharge Pump, 16' power cord
I have a backyard waterfall fountain that uses a Little Giant WGP-65-PW pump. Several months ago it stopped working with the pump only making a buzzing sound. I have finally gotten around to draining the water and pulling the pump out. I would like to try to fix the pump if I can but it looks like there may be no way to open the external plastic case without cutting it or otherwise breaking it. Both options seem bad because I don't know how I would repair the case again if I could somehow fix whatever is wrong on the inside. Is there a way to open the plastic case so that it can be closed again and still allow the pump to funciton properly?
  • albertnelsen Nov 21, 2010
    The solution was helpful in telling me that you can't get the pump open but I already knew that if I couldn't reseal it that it would produce a shock when placed in water.
  • 2,926 Answers
This pump has no serviceable parts and is a sealed unit. Opening the pump and trying to use it again, especially in water, will create an electrical shock that will kill. The motor assembly is permenantly sealed.
Posted on Nov 14, 2010
My Little giant wgp-65-pw has tripped my gfi repeatedly. any idea why? No shorts in the cord are apparent
if a pump connected to a gfci outlet trips , then the gfci has detected a high resistance "shortage" inside pump and has disconnected power , this "shortage" can be nearly in detectable from human standards(shock) , but gfci picks it up
most likely pump seal has failed and water has gotten inside pump !! it only takes one drop to do this !!
Dec 24, 2012 | Little Giant WGP-65-PW 1/8 HP, 1900 GPH...
Problems priming little giant pw-95 pump
since this is a waterfall pump , id try using a short piece of dish hose and see how it flows water then , if it works there then id say your demand to lift is too great and a larger pump will be needed to lift that high ,
also note on waterfalls id leave out the ck valve on dish pipe , i know it takes longer to reprime itself each time , but that reverse flow action cleans your intake screen each time it shuts off
May 12, 2012 | Little Giant Wgp - 95 - Pw Pond Pump -...
My Little giant wgp-65-pw has been sitting idle in the water garden for a long time, how can i clean the alge from the intake.?
I would suggest soaking it in a 5 gallon buckets of water with a cup or so of bleach added. This will kill all the algae and release most of it from the pump. Follow with a through rinse with water and you should be good to go.
Mar 24, 2011 | Little Giant WGP-65-PW 1/8 HP, 1900 GPH...
I cleaned the screen, and the impeller is working however the little giant pump WGP is still not pumping water.
You may need to take the bottom of the pump apart and check to see if any thing has gotten through the screen and clogged the impeller.
Nov 27, 2010 | Little Giant WGP-65-PW 1/8 HP, 1900 GPH...
Little Giant pump WGP-90-PW trips GFI circuit
You might have 2 problems. The GFIC might be wired wrong or the pump wirng might be compromised with moisture. The noise issue? Are you running this unit without submersing it? They will burn out if you do. To get a more accurate running sound, submerse it with a flexible pipe so you can run it in a 5 gal bucket without losing the water.
It's possible a bearing is burned out.
Ron
Jun 10, 2010 | Little Giant Plumbing
Pump plugged in to grounded receptacle trips the
If by "trips the breaker" you mean the GFI then you are leaking current to ground, GFI's trip when there is an imbalance between the current going to the motor on the HOT side and returning from the motor on the NEUTRAL side, if it is tripping the GFI it is likely the sign of a failing motor.
May 27, 2010 | Little Giant WGP-65-PW 1/8 HP, 1900 GPH...
Little giant pond pump wgp-65-pw turn it on and it runs for about 1 min. then shuts off for seconds and then back on for a min.
the magneto has gone in the pump,replace the pump as its cheaper than the repair would be.
try a hoselock pump
Dec 20, 2009 | Garden
My waterfall pond pumps keep burning out. The
I found that little giant pump are oiled filled and if it gets hot it frys itself... As for submersible pumps Magnetic drive Beckett Pumps are nice. My Beckett pump has been going for 4 years now it pumps 4800ghp. the cost $269 last I looked.
Oct 14, 2009 | Little Giant Submersible Fountain Pump
Pw5500 Calpump not working
replace the breaker with a higher amp breaker . Thank you for useing fixya please take the time to rate me
Feb 09, 2009 | PW Calpump Pw5500 Waterfall Pump 5750 Gph...
Little Giant WGP-65-PW 1/8 HP, 1900 GPH Premium Dual Discharge Pump, 16' power cord  Logo
136 people viewed this question
Top Little Giant Garden Experts
J.D. Browning
J.D. Browning
Mike Squire
john h
Are you a Little Giant Garden Expert? Answer questions, earn points and help others
