Locate the cooling fan in front of the radiator...when you remove the serpentine belt and fan assembly (including the pulley)..usually 4 bolts on the front of the fan...you can see the water pump...Sometimes you can ask your Parts store to show you the new part...(water-pump) this can help identify what needs to be removed in order to replace...Use gasket sealant on the new assembly, and I also recommend the anti-freeze that is labeled "For All Models"...for longevity and cooling...You do not have to remove the radiator or anything else...Hope this helps...:)
Yes you do have to pull the axle and make sure you put everything back in the same place you removed it from. The ring and pinion shouldn't have to be bothered. You will have to remove the rear end cover to remove the axle. Its very easy to do. There is a pin inside the rear end that has to be removed to pull the axle. Pay attention to how you take it out and put it back the same way. It sounds as if you can do this with no problem.
see when you say you step on it, and the vehicle stalls, it sounds as if it bein starved of fuel...you step on it, and therefore the demand is there, but not the supply. to prevent itself from over heating, the fuel pump shuts off...after a moment of cooling off, it fires right back up...get it checked at your mechanic...do the strainer on the bottom of the pump, and fuel filter as well...is it time for a tune up yet?
Put a prybar between 2 of the small fan bolts. Have someone hold the prybar, or rest it on the frame if it is long enough.Then turn the big nut on the fan to the left.It will be VERY tight. If that doesn't work, you can probably rent the fan removal tools from your local parts store.
You can get the special tools to remove it or some people take a air hammer with a pointed bit and give the edge of the nut a quick hit in the direction the fan spins to break loose the nut.And to tighten it thread it back on half way then start the engine and when it spins it will tighten it up.
