Question about Atlas Refrigerators
My atlas m30 c is too much freezing, in the boton inside, wath number is the correct to freeze good? 1,2,3,4,5 or 7? Thanks!
4 Suggested Answers
22yooper
  • 828 Answers
SOURCE: Refrigerator Freezing
What is the make and model number of your refrigerator? Is it a frost free unit? How old is it?
Posted on May 23, 2008
appldoctom
  • 311 Answers
SOURCE: i have a refrigerator with
yes you need a new thermostat.it is what controls run time.call appliance parts supplier with your model and ser# ps.its attached to the dialwith the # 1 on it God bless ,tom
Posted on Jan 11, 2009
heatman101
  • 43501 Answers
SOURCE: what is a good temperature.
You need to start out at 5 or higher and then adjust from there...
heatman101
Posted on Sep 02, 2010
Water dripping inside ice maker freezes up. it makes ice but the water dripping freezes up. Checked level OK
Water control valve is defective=> DA97-07827B Water Inlet Valve
are you posting the correct model number? RS265TDRS
25903480-aczhirsgw2b24vrsxm5guear-4-0.jpg I'm here should you have question, Thanks, Sea Breeze
Oct 11, 2015 | Samsung RS265TDRS Side by Side...
Ps3 starts up and quickly freezes at the Sony insignia part. Shut it off and restart and it freezes at the same spot.
Ensure that you are not starting PS with disk inside, if disk is scratched or bad, or PS lens is dirty you can get same problem when you start PS with disk inside.
Aug 20, 2008 | Video Game Consoles & Games
Fix freeze up
There is a reason they freeze up 1. low on freon..2 evaporator coil needs cleaning(inside coil)..3. very dirty air filter, any one of these for a an air conditioner may freeze up... due to a number of other reasons. The most common reason for an air conditioner to freeze up is low on refrigerant.
Jun 27, 2015 | Heating & Cooling
Ice cream is not freezing on FFUS2613L Frigidaire Refrigerator
Thanks for your post, friend!
I understand that your ice cream inside of your Frigidaire refrigerator, FFUS2613L. I would turn down your thermostat to see if that would help correct the issue of your ice cream not freezing. I hope this helps. -Matt
Sep 30, 2014 | Frigidaire FFUS2613L Side by Side...
The temperature in refrigerator is coler than setting on the display why?
Before I begin is the model number=> GI5FVAXVL correct? If not I will need the correct model number to proceed. Thanks, John Tripp Appliance 911
Jan 29, 2014 | Whirlpool GI5FVAXVL (249 cu ft) Bottom...
Underside of ice bin freezes up built up with frosty ice, dispenses no ice. numerous times we have defrosted with blow dryer, removed, cleaned bin, replaced; cleaned out ice that was built up in lower part...
W10224328 Dispenser Door Spring
The chute door is the reason your ice bin is freezing up and also the chute door being open draws warm moist air inside your freezer compartment causing massive amounts of frost and keeps the compressor runing all the time between defrost. You really n eed to get the chute door fixed. What is the correct model number? For the model KSRX25FT dispenser parts click HERE The chute door spring may be broken but you will not know untill you open the dispenser housing. I'm here should you post the correct model number or have questions, Sea Breeze
Oct 17, 2013 | KitchenAid Architect ® Series II KSRX25FT
Refrigerator freezes water and cola drinks inside it
have the thermostat checked as it appears that it has stopped controlling the temperature you set to
Jun 16, 2013 | Haier Refrigerators
Siemens ka..n freezer problem
Look inside the back wall of the freezer to see if you have a layer of frost building. If yes this will indicate that the refrigerator is missing its defrost cycle. When you miss defrost it is usally number 1 the defrost control. Number 2 is the defrost heater has burned out and #3 the defrost thermostat. For you to look up the correct replacement parts you will need to find your refrigerators model number found most times inside the fresh food compartment. Click Here for=> Bosch Refrigerator Defrost ControlsI will be here to answer any questions you may have or if you have your model number let me know and I will help you find the parts you need, Thanks Sea Breeze
Feb 16, 2012 | Bosch Refrigerators
My refigerator is not getting cold but the freezer is working great. I have cleaned out the inside of both but it only helped a little bit.
It could be more than one thing.
1. Its low on freon or has a freon leak. A good sign of this is the freezer will freeze up on the inside around the coils and inside were the food goes. You need a tech that has equipment to recharge the system.
2. The fan that moves the air from the freezer is not working. The top part of the fridge has a vent in the back, feel if there is air flow while the fridge is running. If not have your local parts store get you one. They should have diagram to show how to install it.
3. The Temp control in the refrigerated part is not functioning correctly. Try turning it way down and then adjust up one number or notch every 4 hours until cold ( turning to up to high can cause a freeze up). If there is no change and if its not a freon issue then the circuit needs testing with a multi-meter. (DO NOT TRY UNLESS YOU HAVE EXPERIENCE! Electricity is really dangerous... but you know that. )
Good Luck! I hope this helps you!!
Jun 28, 2011 | Refrigerators
Frig has cold spots that can freeze some items
If you can get the brand name and correct model number, I will be able to get this fixed for you. But if the vent ducts leading to the refrigerator bottom are not responding to manual adjustment. Cold air tends to migrate down to bottom of refrigerator, because it's heavier air. Look for correct make/brand and model number and we will fix this. Thanks, Sea Breeze
Apr 16, 2009 | Refrigerators
Refrigerators Logo
Top Atlas Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you an Atlas Refrigerator Expert? Answer questions, earn points and help others
