Question about Toshiba Computers & Internet
I cannot get my laptop to connect wirelessly to the internet through my home hub
    Genius:
  • 1,542 Answers
Hi
Have you set a password on the router if so have you entered it on your laptop when trying to connect it ?????????
is your laptop finding your router at all ??????????
have you enabled wireless in your router settings ?????????
Do you know how to get into your router via your browser
can you let us know what router you have what operating system you have on your laptop and try to answer the questions above to help us try to solve your problem
Posted on Nov 13, 2010
I cannot get these plug in units to pair or connect to the laptop. is it me or are they ****?
If you can install a wireless repeater it may provide a better signal.
OR
A wireless 3G network uses the mobile/cell phone network and can be separate or combine with your cell phone account. This type of Internet connection uses an USB wireless device shaped like an USB memory stick.
Sep 30, 2012 | Computers & Internet
I have just bought 2 Acer aspire one netbooks. Before Xmas I checked that these would connect wirelesly to internet and they both did - have now tried again after Xmas and they wont connect wirelessly...
Hello, Vicki.
A drained battery would have no bearing on wireless access.
Since both laptops do not access wirelessly, sounds like as issue with your hub. Try the laptops at a wi-fi cafe to see if they work OK.
Hope this helps.
Dec 28, 2009 | Acer Aspire One PC Notebook
My hp pavilion dv 9000 can not connect to bt home hub 2.0
hi, please make sure that you enable WPA encryption on the wireless router. Vista will give you trouble if you use WEP encryption. Also, please update the firmware on the wireless router, if possible.
Let me know how it goes.
Oct 26, 2009 | Computers & Internet
How do I add an additional laptop to browse the internet?
If you mean to your home network you could use either a router or a hub. With a hub you can connect a cable to access the internet. With a wireless router you can use a wireless card in the laptop as well and use the laptop anywhere in the house.
Sep 12, 2009 | Dell Inspiron 1501 Notebook
How can i connect my laptop to internet without router device via desktop pc connected to internet
you could its called an ad-hoc connection..but youneed either a wireless adapter on your desktop or a network hub
Apr 29, 2009 | ASUS Wi-Fi@HOME (WIFIG80211G) 802.11g/b...
Lost connection between switch and hub - LED flashes every 5 secs
You say you have the same problem when you connect the cable directly from router to laptop, so it apparently is not a hub problem. That leaves the router and the cable. You're fortunate in having a working system on the other port. Why not try swapping pieces to see which is the failed piece? For example, what if you swap the ports for the cables? If it's a router problem, then the "bad" cable should work when in the other port. What if you swap cables? That would reveal a bad cable. Finally, swapping computers would show a computer configuration problem, such as the connection not being set to automatic.
Jan 23, 2009 | Dynex 5 Port 10/100 Ethernet Switch...
Wont connect ti internet
Same device as mine. and im on home hub aswell. Uninstall the drivers. Restart windows. Reinstall the drivers. Hopefully this should make a differance. Also when reinstalling. make sure the device is not plugged in until you finish installing drivers. And maybe put it into another usb when you are ready to try again. this is something good to try on older systems. or OS's.
Oct 02, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Wireless connection problem
BT is right, the fault is at your end, because you can connect to the Internet with an ethernet cable.
You have lost your wireless connection with the wireless hub.
This could be low signal strength (especially if the wireless access point is in one part of the house and your laptop is in another room)
OR Your laptop wireless card has lost its wireless access configuration.
Check your laptop wireless configuration, check your signal strength, check your SSID, check your security (WEP or WAP),
Have you got MAC address filtering.
Go to control panel, click on network connections, right click on Wireless Network, Click on repair (might fix your connection problem), Else right click on Status (should give you indication of how your wireless is functioning or not functioning).
Check your TCP/IP settings is set for "Obtain an IP address automatically"
Without more information it is difficult to identify exactly what is wrong with your connection.
May 11, 2008 | Acer Aspire 5100 Notebook
Internet
Problem with wireless connection to Acer Aspire 5100. Is there a step by step instructions to connect? A manuel of some sort?
May 10, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
