Question about OKI Office Equipment & Supplies
133:fatal error - OKI Office Equipment & Supplies
  • Anandaskky Jan 09, 2009
    I suddenly got the serious error 133 message. It was working yesterday. Must i call service? Isn't there anything i can do myself?
What?
Posted on Jul 22, 2008
That error is an LED detection error. Check the connections for the cyan LED. Also the fuse on the pcb for that LED. If those check out OK than you can try swapping the LED's to see if the error travels with the LED. If the error travels then replace the LED. If the error does not travel then it is more likely the PCB.
Aug 17, 2014 | Oki Electric Industry C711n Led Printer
Im having a Asus psgc -mx/133 board with 1 gb ddr2 and 40 gb bata hard drive ,while open the system it apears coms went worng coms battery worng system halted chassis /fatal error
Firstly your motherboard will not accept DDR2 memory. It will however accept PC133 RAM. Also it won't accept 1Gb and will only work with Windows 95. Although you may be able to get it to run Windows 98. Your board is very old( Antique) get a new one from the recycling center. It will be faster and more useful.
Aug 16, 2013 | Computers & Internet
Xante ilumina I have an error code 134:fatal error , please help!!!!
LED Head Error
131 = Y Head 132 = M Head 133 = C Head 134 = K Head
Sep 21, 2012 | Xante Ilumina Digital Color Press Printer
How do i fix a 131 fatal error?
FATAL ERROR 131, 132, 133 OR 134 ON THE DISPLAY ON POWER-UP
CAUSE - ONE OF THE LED PRINT HEADS IS DISCONNECTED
SOLUTION - RECONNECT THE RIBBON CABLE TO THE PRINT HEAD
Just for information, the led print heads are the four assemblies that hang down from the lid of the machine when you open it.
Sometimes they become unclipped, and the ribbon cables can get pulled loose.
131 probably means the front one.
Mar 04, 2011 | Office Equipment & Supplies
Fatal error 133 xante cl 21. Course for this
yellow led head. swap yellow with cyan and see if the error changes
Feb 14, 2011 | Xante CL30 HSE Laser Printer
Please what can I do to work the machine that says fatal error 133;
133 relates to the cyan LED sensor, infact most likey it is the actual Cyan Image drum.
make suer the LED above the Cyan drum is clean, and freely mounted in the spring assembly.
remove and re instal the image drum..
if that does not work, most likely u need a new image drum,Cyan..i bet it is low and due soon for replacement...
good luck
Nov 10, 2010 | Xante Ilumina Digital Color Press Printer
Please what can I do to work the machine that says fatal error 133; for xante ilumina
If you are in a Windows OS it means that:
133 JOIN or SUBST command can not be used for a drive that already contains readers joints.
So uninstall your printer and install it again using the best driver.
Iomega HDD Fatal Error 05
Fatal Error 5 is normally indicative of a Disk Failure. Because the OS can't read the portions of the drive.
Jul 05, 2009 | Iomega ScreenPlay
799 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
