Question about Oster ODF520 Fry Right Deep Fryer
Does the oil pot come out of the deepfryer I want to change the oil but I can't get the pot out to empty it. I can't find a picture that looks exactly like mine and I can't find a model number on it anywhere. Is there any other way to contact me, my email address isn't set up yet?
I'v just brought a Crofton Mini Deep Fat Fryer. When emptying the old oil the manual says pour from the lip which i think i found at the back left corner would i need to remove the lid to this.
The manual says "Empty the oil out of the pot using the pouring lid" I must say that I dont think the manual is very good. I had a problem assembling the handle to the basket so phoned their helpline free on 0800 328 6063. The lady was EXTREMELY helpful and friendly.
Feb 22, 2015 | Kitchen Appliances - Others
Why does my faberware deepfryer say not to use peanut oil in it
The page says as a general rule, choose oils with a high smoke point and avoid flavored oils, peanut oil adds a nutty flavor to food olive oil has a low smoke point lard and walnut oil not sure. To me looks like a recommendation a foolish one but that's all they are stating honestly think vegitabkd oil is way to over powering and makes fried foods taste bad
Dec 26, 2013 | Farberware Collectibles 4-Qt. Deep Fryer
Bravetti deepfryer manual
I wont try it, the beast way to clean glass is to use a oven cleaner than wash it real good with dish soap!
Dec 14, 2011 | Bravetti EP4305FS Deep Fryer
How do I stop the oily residue in my brewd cup of coffee? The coffee maker is new. The residue is not from our filtered water.
Thoroughly wash the pot and the basket with a good oil/grease remover (detergent) such as DAWN dishwashing liquid.
Then run White Vineger/Water (50/50) mix through the coffee maker TWICE, with the basket and pot in place. (NO coffee, nothing in the basket)
DO NOT RUN any detergent or soap through the coffeemaker at any time.
Then, run straight water through the coffee maker TWICE (no coffee, basket empty)
Then wash the pot and basket out AGAIN with a good detergent.
This will remove any residue that is in the coffeeemaker from the factory.
As coffee brews, there IS a slight amount of oil that is produced. The coffee itself has oils in it, and is part of its flavor, and freshly brewed coffee will have a slight oil residue.
Jun 24, 2011 | Rival Coffee Makers & Espresso Machines
Guy's We have a Vulcan electric deep fryer in our galley , I do not have the model number at present but what we are inquiring about is to see if there is available a metal cover to place over the Top...
look for a hardware store dealing with this problem they will give u the exact metal sheet of steel to make a cover so that u will be able to void fire and other things falling in the frywer
Sep 07, 2010 | Vulcan Kitchen Appliances - Others
When I pour water into (empty) pot to fill. Bunn coffee maker
If you pour water into the machine, and water comes out, then the reservoir is full of water. There is no way the water can bypass the reservoir and go directly into the pot.
Apr 26, 2010 | Bunn 10 Cup Home Coffee Brewer
Need deepfryer power cord
couldnt get the power button to come on
Jan 04, 2010 | Rival CZF625 Deep Fryer
Hello
If your speedometer is showing a "Red Pot" that looks somewhat like a tea pot, This is you oil pressure warning light. Check your oil level and check the flow of the oil back to the oil tank.
Oct 18, 2009 | 2003 Harley Davidson XL 1200 C Sportster...
Just wandering how much oil to put in the 30 quart pot
thanks, all i did was put water in the the pot, took a three liter jug and emptied the water into it. it takes about nine liters , thanks again. jack
Dec 29, 2008 | Masterbuilt M30BV Deep Fryer
Cooking Pot Return Problems
I use an old heavy 3-quart alumnium sauce pan with a loose-fitting lid, canola oil, and high heat with about 1/2-cup of standard grocery-store yellow popcorn. I get the empty pot nice and hot, add the oil, then the corn, then the pot lid. I shake it occasionally, but basically let it go until the lid starts to rise off the pot, and I don't hear any more pops. Pour it into a large bowl, toss it with very fine sea salt, and go to town! It's also fantastic made with bacon fat, but you need to use slightly lower heat to keep it from burning and prepare for visitors: The smell of popcorn and bacon fat draws crowds.
Feb 16, 2008 | Paragon 1911-8 Popcorn Maker
Oster ODF520 Fry Right Deep Fryer Logo
194 people viewed this question
Top Oster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Ben Eng
Level 1 Expert
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
