Question about Microsoft Xbox 360 Console
Console door won't open, and the console is flashing an orange light. Grandson very upset. PLEASE HELP. It is an X box 360 help help help
  • 767 Answers
No Problem. Press the eject button wait one second and then smack the
top of the console right over the drive . This will release the tray and it should open,
you may have to make a few attempts as timing of the smack has to be just right.
The problem is excess frictions caused by grime build in the gears or the lasers carriage
rubbing in the guides. The drive must be disassembled and cleaned . average cost
for sticky trays fixes 30.00-50.00 .
If you have any questions feel free to ask.
Rob
Posted on Nov 13, 2010
  • Rod Sims
    Rod Sims Nov 13, 2010
    Where is the light flashing and are you sure it's not red?
    because if that's the case then you will need to have a
    a shop repair it the cost is between 50.00-80.00 or you
    could buy the right repair kit and either you or him could
    do the repair yourself.
    Give me a little more info on your console
    and ill try and help you.
    Rob
The orange light on my xbox360 power box is blinking orange and it won't turn on what do i do
I need you to tell me exactly where the light is flashing if it is on the gray box that ataches by cable with a light on it or if it's the on switch on the xbox 360 itself.
If it's on the 360 and it's flashing orange then that means a able is badly connected or missing.
If it is on the gray box next to it then i do NOT KNOW.
Jan 18, 2011 | Video Game Consoles & Games
Power box light is blinking orange and sometime a steady red and console want come on.
Green Indicator Light:
The default indicator light is green. When the Xbox 360 power supply light is green it means that there are no problems with your power supply. However, if you are having problems and the power supply light is green, this means that the console is faulty and you need to contact Xbox 360 support.
Orange or Yellow Indicator Light
When the Xbox 360 power supply light is orange or yellow this means there is no problem with your console but the power supply can't supply it with power.
To remedy this problem, first try unplugging the Xbox 360 power supply from the console and unplug the power cord from the wall outlet. You'll also want to uplug the Xbox 360 power supply from the power cord.
Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If you are still getting an orange or yellow indicator light, then something is at fault with the Xbox 360 power supply. If this is the case, contact the Xbox 360 customer support to get a new one.
Red Indicator Light:
If the xbox 360 power supply light is red, then there is something wrong with the power supply connection. If this is the case, try the same solution as listed above of unplugging the power supply from the console, unplugging the power cord from the wall outlet and unplugging the power supply from the power cord. Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If the indicator lights are still red, then there is a fault with the power supply. If this is the case, contact customer support about getting a new one.
No Indicator Light:
If the XBox 360 power supply light is not illuminating at all, this usually means that the Xbox power supply is not connected to the wall outlet correctly. On the other hand, it might also be a fault with the power supply or the power cord.
Either way, try the same solution as listed above for the red indicator lights. If you still don't see any lights illuminated after unplugging and then reconnecting everything, you'll need to contact customer support about getting a new power supply.
Green and Orange Indicator Light:
If the indicator light is flashing green and orange, this may mean that the console does not detect the AV Pack.
Disconnect and then reconnect the Xbox AV Pack. Make sure the connections are firmly connected. Turn your Xbox back on.
If the indicator light is still flashing green and orange, try another AV pack if one is available.
If the indicator light is still flashing green and orange, you'll need to contact Miscrosoft Customer support.
Flashing Orange Indicator Light:
If your Xbox console's indicator light flashes orange, this means the internal components have overheated and the Xbox has automatically shut down to prevent damage.
Turn off the console and let it cool for at least 10 minutes.
To prevent the Xbox from overheating in the future, make sure that it's not placed in a closed cabinet or on carpet. It's best to get the Xbox elevated off the ground where the PSU can have maximum heat release.
You'll also want to make sure the Xbox is not located near a heat source like the back side of a television, computer, monitor, or other electrical device.
Aug 26, 2010 | Microsoft Xbox 360 Elite Console
Tree lights in red
Step 1: Turn on the console, and check the light on your power supplyThe power supply light is located on the black box that is in the middle of your power cord.
Figure 2: The Xbox 360 Power Supply light uparrow.gifBack to the top Step 2: If power supply light is green, try this solution 3frlgreen.jpg
Figure 3: Three flashing lights on the Ring of Light with a green power supply light Solution: Submit a console repair requestYour console is in need of a repair. There are no additional troubleshooting steps. To begin the online repair process, click one of the following links: Step 3: If the power supply light is red, is orange when the console is powered on, or is not lit, try these solutionsuparrow.gifBack to the top 3frlpower.jpg
Figure 4: Three flashing lights on the Ring of Light with a red, orange, or unlit power supply light Solution 1: Unplug your console, plug it into a different outlet in a different room, and then turn it onThis will help determine whether the problem is with your power supply, your power outlet, or your console. Solution 2: Request a replacement power supplyIf the power supply light is still red, orange, or not lit, the problem is with your power supply. Contact Xbox Support to obtain a replacement power supply. Contact Xbox Support(source: www.microsoft.com)Regards
Mar 23, 2010 | Microsoft Xbox 360 Console
Xbox won't power up, orange light is on the power brick
Are you using a plug and play kit? if so disconnect it, mine does that sometimes, if thats not the case comment me,I would write them all down but I am getting a bit fed up with writing lots of solutions to problems and getting no response from the person I give the time to help.
Feb 13, 2010 | Microsoft Xbox 360 Console
Xbox wont power on past orange brick light
You need to have the 3 red light fix service. We can fix it for you. We are a listed repair service on this site. Here is a link to our 3 red light service.
http://www.videogamerepairservice.com/catalog/item/5675532/5556610.htm
Dec 08, 2009 | Microsoft Xbox 360 Console
Xbox 360 won't turn on and the kids are upset.
Press the power button on the front of the Xbox to turn it on.
As you're doing this look at the power supply to see if the amber light turns green.
If the light does not turn green, you'll need to get a new power supply.
I you think this information is helpful to you, please take a few minutes to rate this reply.
Aug 29, 2009 | Microsoft Xbox 360 Console
Orange flashing light on power brick ,no power to x box what do ?
You need a new power supply. Did the electricity in your home go out while your xbox was on? It seems like the power brick got shocked and you may need a replacement. Call Microsoft.
Jul 14, 2009 | Microsoft Xbox 360 Console
My xbox 360 won't turn on!!!
When it says ORANGE on the Power box, that means that the Power box is waiting for the console to be connected, You might wanna try another power box if you have a friend or relative nearby, and if another power box does the same thing, then you can call xbox support to check the warranty of your xbox 360, then send it in for repairs
FYI:
The light on the power supply should be GREEN in order for the console to turn on
Mar 15, 2009 | Microsoft Xbox Console
Three flashing red lights on xbox 360 console
Wow, 4th? That's horrible! Hopefully the following helps you out! SYMPTOMS loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. CAUSE loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. MORE INFORMATION loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem: 1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated 2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.If your console continues to display three flashing red lights, your console may have to be repaired. If none of these help, pease contact Xbox support at http://xbox.agent.asahost.com/ to talk to a live agent.
Sep 05, 2008 | Microsoft Xbox 360 Console
X-box 360
hey i had that problem
i found there a new trick to get the xbox to work its only temp tho
heres the link
http://www.youtube.com/watch?v=avWs4-wD15w
if that doesnt work microsoft will fix it
hope this helps please rate me
regards grant
Nov 22, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
