Question about Corona 23-DK Compact Heater
Wick r/p instruction corona 22dkc - Corona 23-DK Compact Heater
SOURCE: wick
I must warn you, replacing the wick is a very tricky job. You should take it to the place where you buy the wick and let them install it.  Call first to make sure they provide this service.
Posted on Nov 10, 2008
SOURCE: change wick corona dkc22
u need to start at top . remove cage from top. there should be a few screws on the side of the upper case (the round upper part of the heater) once that is removed u will see the shaft the wick is attached to,the heater control are mounted here too. there should be some screws or wing nuts remove them. now lift the shaft out the wick will come with it (carefull wick wiill be wet with kerosene) remove old wick. when replacing new wick make sure to allign the top of the colored band with the top of the wick holder(the piece with the pins that adjusts the wick up & down) lower shaft & wick back onto heater and reasemble heater .be sure all controls and shut off work smoothly and correctly.
Posted on Jan 14, 2009
tinytrees
  • 92 Answers
SOURCE: CORONA DK23 NEED INSTRUCTIONS
Go to the corona web site and download the instructions for your model or got to homeappliance.manualsonline.com
Posted on Jan 22, 2009
  • 24 Answers
SOURCE: i have a 23-dk corona kerosene heater. it was
Check all airvents into conbustion chamber. Make shure they are all clear of blockage. The heater needs air to burn fule properly. Check wick adjustment it may have to much wick.
Posted on Sep 03, 2010
  • 4736 Answers
SOURCE: I am trying to change
The replacement wick you purchase will have the instructions on how to install it. Be sure you have your model number with you, when you go to purchase it. Most local independent hardware stores (True Value or Ace) stock the wicks. Where rubber gloves when replacing the wick. Especially if you still have kerosene in the tank.
Posted on Feb 05, 2011
How do I replace the wick on a corona 23. I lost my manual
If you've already purchased a new wick from a reputable dealer/retailer and its the one designated for your model Corona heater. The installation instructions come packaged with the wick. I would encourage you to wear rubber gloves if the heater tank still has kerosene in it.
Feb 01, 2011 | Heating & Cooling
I have a 23-dk corona kerosene heater. it was smoking so i replaced the wick. after replacing the wick it still smokes heavy. how do i fix the problem.
Sep 03, 2010 | Corona 23-DK Compact Heater
How to replace the wick in corona 23dk
I believe you will find the instructions on or in the package of the new one. I've seen many styles of replacement wicks at Walmart. Also the replacement instructions will be in your owners manual.
Dec 08, 2009 | Corona 23-DK Compact Heater
Corona 17 dk
Just pull it out with pliers. It has sharp directional tabs pointing down holding it in. Once the wick is pulled out, it is no good. New wick pushes right in.
Apr 03, 2009 | Corona 23-DK Compact Heater
Jan 22, 2009 | Corona 23-DK Compact Heater
Wick
Nov 09, 2008 | Corona 23-DK Compact Heater
Wick won't raise.
check with your local hardware ace store like I did my wiks for both my models come ready to install
Oct 27, 2008 | Corona 23-DK Compact Heater
Corona DK 23 kerosene heater won't start
try bringing your wick up to the fully raised position and pinch and bend the wick toward the igniter until they line up right. I have two coronas one of which has a broken igniter due to wear and tear. If you open the little door,press down the start lever,and light the wick with a barbecue grill lighter,you can safely light the heater if lining up the wick fails.
Oct 09, 2008 | Corona 23-DK Compact Heater
Change the wick
You must be very careful and follow the instructions exactly on these wicks. The pins must be inserted into the holes on the wick holder. It is also easy to install the wick holder upside down. Look for a small up arrow on the side.
You must soak your wick for at least 30 minutes, preferably 1 hour. I know it's tempting to light it right away, especially when you are freezing, but you must wait. Wicks work by using capillary action. The fuel must have time to soak in properly.
All wicks are NOT created equal. Buy good ones, under no circumstances should you buy the ones that Walmart sells. They **** and you will be changing it in a day or two. Home depot sells a decent one, but for the really good ones visit Miles Stair wick shop. He also has some good info to deal with condensation and moisture problems.
Also note these heaters will not work if they are dirty. They must be absolutely clean of all dirt and debris, every single part. Especially the parts that come in contact with the wick.
Regular maintenance, good wicks and good fuel will keep these heaters working.
Oct 13, 2007 | Corona 23-DK Compact Heater
Corona 23-DK Compact Heater Logo
174 people viewed this question
Top Corona Heating & Cooling Experts
Paul Carew
Tim Whalen
Are you a Corona Heating and Cooling Expert? Answer questions, earn points and help others
