Question about Polaris 3900 Sport Pool Cleaner ()
My polaris hose keeps getting tangle. - Polaris 3900 Sport Pool Cleaner ()
  • 640 Answers
If you have stored your automatic pool cleaner with the hose coiled, this is probably what is causing the problem. Lay the hose out flat and stretch it slightly. Let it sit in the sun for several hours and it should help to straighten in. You should also not store your cleaner with the hose coiled. If you are talking about your sweep hose getting tangled, you might need to adjust it, lower your RPM, or add sweep hose weights.
Posted on Feb 02, 2011
  • 1,631 Answers
Belive it or not... too many swivels add to the problem!
Most people think if I add a swivel here where it begins to coil then tangle, it will fix the problem, but yet the problem remains!!!
The manufacturer recommends this for the proper layout of the hoses; from the wall all the way to the head:
  • First, determine the deepest part of the pool/pool "Depth"
  • That is how "Long" the 1st hose is to be. The softer clear hose
  • Now... Attach all the hoses together, 1st hose already cut per the above and the other two "White" hoses - UNCUT.
    • Place the head at the point on the deck where the wall adaptor is for the hose to attach
  • Walk around the pool holding the wall adaptor
    • Move your hand forward towards the edge of the pool to mark the total length of the pool, if you come to a point where your hand is over the water, hose is too short, move your hand back, if your hand is too far back away from the waters edge, the hose too long
  • Once you get back to the starting point, you should now know how long the hose needs to be. You could probably have 1' - 4', maybe more maybe less? Take note of the excess hose, that will need to be cut off, too long of hose will only tangle up. BUT WAIT, THERES MORE....
    • You may think that, I now just cut off the excess length? You would be wrong!!!
    • Lets say you have 4' of excess hose...
    • Follow the hose in your hand to the next swivel, disconnect it.
    • NOW Cut. But... cut off only 2' from one of the white hoses, AND 2' from the other white hose.
    • Reconnect the swivel. You have now cut off a total 4' of excess hose.
Recap: What you have done is with the 3 pieces of hose is cut it & adjusted it to the correct lengths. The soft hose is as long as the pool is deep. The two White Harder pieces are Exactly Even!! The way it should be!
Now, the Back up valve will be placed on the soft hose about 3-4' away from the head.
Follow this and the hose should not tangle. And...
The advice about storing the hose coiled is not good, ABSOLUTELY CORRECT!
Whenever storing, always store in a straight line, otherwise it will retain the memory of the coil.
Good Luck
Posted on Mar 17, 2015
My backup valve on my polaris 380 is not shutting would this cause hose to tangle
no the swivels are stuck move them by hand till they loosen up or replace
Jun 09, 2014 | Polaris 380 In Ground Pool Cleaner
My Hayward pool cleaner hose keeps getting tangled
check to see if swivels are free if not move them or replace also cold water will do it
Aug 24, 2013 | Polaris 3900 Sport Pool Cleaner ()
No My polaris hose keeps getting tangled up, how do I fix it.
Remeasure the pool cleaners hose to verify that it is adjusted to the proper length for the pool shape. With the Polaris operating, check that the swivels in the hose and the hose connections turn freely. Make sure feed hose is floating.With the Polaris turned off, spin each of the wheels. All wheels should turn together.
Nov 13, 2010 | Polaris 280 Black Max Pool Cleaner with...
My polaris keeps getting tangled up. How dod I fix this?
If the hose on these pool cleaners is becoming tangled, there are a couple things you will want to check. Remeasure the hose to verify that it is adjusted to the proper length for your pool shape. With the cleaner operating, check that the swivels in the hose and the hose connections turn freely. Make sure the feed hose if floating. Then, with the Polaris turned off, spin each of the wheels. Make sure they are all turning together and adjust if they are not.
Aug 11, 2010 | Polaris 280 Black Max Pool Cleaner with...
My Polaris back up valve pulls too hard; the whole unit is pulled from one side of the pool to the other and then the hose gets tangled up. Is there a way to reduce the pull?
It doe's not adjust but you should make sure it is in the right spot. It should be just after the first hose away from the wall at about 18". If it is in that spot it can't pull to far.
Sep 10, 2009 | Polaris Vac Sweep_ 380 Suction Side In...
Polaris 3900 Sport Pool Cleaner () Logo
1,095 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
