Question about Pride New Mobility Victory XL 4 Wheel Scooter
When traveling on flat surfaces, there is a noise coming from the front (axel, tire, steering column???) area. No noise going up an incline or down a hill, just on the level. Had this scooter only 12 months.
  • 278 Answers
The most likely source of the noise is your front wheel bearings or the front springs for the suspension. Each front wheel has an inner and outer wheel bearing which is sealed but can develop noise over time. If you can, block up the scooter and spin the wheel in the air. If you hear noise it is either a noisy bearing or you need to remove the wheel and grease the spindle (axle) the wheel is mounted to. The wheel bearings need to be punched out and replaced with the same size bearings from the manufacturer or a bearing store.
While the scooter is off the ground check the steering linkages and spray lubricate them. Also, lubricate the springs and anything else that moves or pivots. If the steering tiller squeaks at the head tube frame (steering column) upper or lower bearings you have a more technical repair. That involves loosening the lock-nuts for the steering column dropping the lower front frame assembly to either repack with grease or replace the bearings. You would also have tor remove the upper tiller assembly and get it aligned on reassembly.
You should be able to hear and isolate the noise once you have the front end blocked up off the ground. Hope this helps.
Posted on Nov 14, 2010
There is a noise coming from the front left wheel when the vehicle is in motion. It seems to speed up & slow down with the speed the vehicle is traveling. I can't tell what it is. If it's not brakes or a...
Another problem is the CV universal joint going to the wheel. this is inside a rubber boot to protect the constant velocity universal joint and maybe the boot has been damaged and allowed water/dirt inside. Find a large open parking lot and make a tight figure eight with the steering wheel all the way over and listen to see if the noise is louder. locking the steering wheel hard over turning left and then hard over turning right and if the noise is louder then your CV joint is bad. A squealing scraping noise could be worn out brake pads allowing the small L shaped metal tab to rub on the brake rotor causing the noise too. Look at the pad, the should be very thick riding against the brake rotor. You should be able to see the L bracket and if it is against the brake rotor, new brake pads are needed. A grinding kind of noise that changes its sound when you make small turns like avoiding pot holes could be coming from a bad wheel bearing. Jack that wheel off the ground and then grab the top and bottom of the tire and see if it wiggles on the axel. There should be no play at all if the wheel bearing is good. Regards, Dennis
Feb 27, 2015 | 1998 Dodge Durango
Have a rubbing noise in steering. Especially when turning slow or backing an turning to the left. I had this same issue in a previous chevy truck
When you turn at low speed you most likely had your foot on the brake. As such, you are loading up the front suspension i.e. weight shifted to the front. Backing up at low speed has the same effect of loading up the front suspension. Your front tires contact patch to the pavement also increase in area -- think about the tire is less round but more flat surface touching the pavement.
In both cases (low speed/foot on the brake and backing up), they put more stress on the steering and thus the steering pump.
Hopeful fixes:
1) check tire pressure of both front wheels especially the sound occurred more often when turning left than right. The correct tire pressure when cold reduces the resistance from turning the steering wheel
2) check and/or replace steering pump belt(s). When they are worn out, they became inefficient in helping the steering pump to provide needed pressure to assist steering. Now the steering pump has to work 'harder' to provide the needed assistance to the steering
3) your steering pump is wearing out. Not totally dead yet. In cold days, the steering fluid is 'thick' --think viscosity. It is less efficient in circulate the pump. As such, a 'weak' pump has to work harder to make the thick fluid to circulate (to provide steering pressure). Mechanics refer to this cold days steering noise as "Morning Sickness". You can try to mitigate the problem by changing the steering fluid. You might need to change it a few times before the fluid in the entire system is purged and completely replaced.
Hopefully, inflating the tires to the correct cold temperate; changing the belts and/or complete steering fluid flush could solve your problem. They are all much less expensive than replacing the steering pump.
Oct 12, 2014 | Cars & Trucks
Entire car and steering wheel wobble on my 09' Chevy Cobalt when driving straight. There is no difference when turning left or right. What is it?
Have you checked the steering wheel linkage ?
2009 Chevrolet Cobalt. Consumer writes in regards to steering column problems. The consumer stated part of the steering column was replaced 4 times, since the vehicle was purchased new in 2009. The problem was originally noticed as a rattle in the dashboard area in December 2009. The steering column was replaced. A similar noise returned in October 2010, where the steering rack and pinion input bearing was replaced, and on March 30, 2011, the steering column was replaced again. In February 2014, the rattle returned for the 4th time and the steering column was replaced. On November 2, 2011 the consumer attempted to turn off the vehicle, but was unable to do so. The dealer replaced the ignition switch. The old switch had completely apart inside the steering column.
see attached link for more
See attached link for more
Jun 01, 2014 | EBC Brakes 2009 Chevy Cobalt - 2.2L 4-cyl....
I have a 2005 Pontiac grand am and every time I go around a corner, doesn't matter if its a left or right turn, I hear what sounds like a grinding noise coming from the front of the vehicle near the...
this might help:
Here is the Technical Service Bulletin that maybe of help, worth looking into but can't guarantee that it would fix your problem Steering - Steering Column Clunking When Turning TECHNICAL Bulletin No.: 01-02-32-001P Date: November 25, 2009 Subject: Clunk Felt/Noise Heard From Steering Column, Steering Gear and/or Front Of Vehicle During Turning Maneuver and/or Steering Wheel Rotation (Replace Intermediate Shaft As Directed) Models: 2001-2004 Buick Regal 2005-2008 Buick Allure (Canada Only), LaCrosse 2000-2008 Chevrolet Impala 2000-2007 Chevrolet Monte Carlo 1998-2002 Oldsmobile Intrigue 2004-2007 Pontiac Grand Prix Supercede: This bulletin is being revised to add the 2008 Buick LaCrosse/Allure. Please discard Corporate Bulletin Number 01-02-32-001O (Section 02 - Steering). Condition Some customers may comment on a clunk type noise coming from the front of the vehicle while driving during a turning maneuver.
1. Locate a large area (parking lot) where the vehicle can be turned in a tight circle. 2. Turn the steering wheel to the right and/or left all the way to the steering lock, then off the steering lock a 1/4 turn. 3. Drive the vehicle approximately 5 km/h (3 mph) in a circle, preferably over rough pavement or seams on the road surface. 4. Drive the vehicle straight ahead at idle speed while applying and releasing the brake pedal. Listen/feel the steering wheel for the clunk/noise condition. 5. If a clunk is felt in the steering wheel, the MOST likely cause is the I-shaft - not the steering gear. Continue with the correction. Correction DO THIS - Replace the intermediate shaft DON'T DO THIS - DO NOT lube the intermediate shaft Replace the existing intermediate shaft
Apr 13, 2013 | Cars & Trucks
While driving my car is making a noise like i have a flat tire but all the tires are fine
check the wheel bearings and drive shafts also does it do it on the same bit of road as the difference on road surfaces can make the tyres sound strange also get the pads on the breaks checked as well hope this helps ivan
Oct 01, 2012 | 2010 Mazda 3 2.0
I have a power wheel caddilac escalade and the steering wheel and tires are stuck to one side.
your steering column has disconnected underneath, check that the steering column is inserted in the hole on the front axel
Apr 29, 2012 | Fisher Price Fisher Power wheels Cadillac...
Have trouble going up inclines. legend 3-wheel scooter
Tell you what.... I had a friend that her mother had the same problem. Under normal use, flat surfaces, did fine, but slowed for a climb, we checked the actual axel on the bottom and found that her deep pile loose carpet had been collecting fibers on the axel and it slowed the tires. Check that and if that is not the problem, let me know, I can check further no problem.... Guy
Sep 12, 2010 | Pride Mobility Products Health & Beauty
Right rear axel makes noise
You need to jack it up, And put it on jack stands. Its a safty thing. Next spin the tires with the engine, Put it in drive. let the Brake off slow. Don't forget to block the front tires with a brick, or a 4x4 or 2 pieces of fire wood. Put one under each front tire. Now run the engine 30 to 35 miles per hour.With the tires still on your Rover. Pay close attn to the noise as the tires spin. Now pull the wheels and pull the rotor or drum off. Now if its a bearing you will here it. Be sure to let off the gas pedal very slowly so you won't hurt the drive train. We checked wheel balance, Wheel bearings, Brake noise, even out of round tires can be spoted while running the tires on and off to do the test. its like driving it down the road but you can get down there and look and hear things. I sure hope this is helpfull to you.
Aug 18, 2009 | 1999 Land Rover Range Rover
Rotating wheel noise from front end
That is the bearings going bad on it.
May 24, 2009 | 2004 Toyota Sienna
Thumping at front passenger wheel area
if the noise isassociated with "wheel speed" then it is in the rolling parts... axle hub bearing brake rotor caliper wheel or tires...if it goes away on right turns then you are unloading or separating the issue then...so a hub /wheel bearing /axle issue is most likely...does your brake pedal pulse when you feel it..(riding the brake while driving)..does the steering wheel shimmy ?
Dec 18, 2008 | 1993 Buick Century
Pride New Mobility Victory XL 4 Wheel Scooter Logo
336 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
