Question about Whirlpool RBD245PD Electric Double Oven
We have a RBD245PDT14 Double Wall Oven by Whirlpool. The light works and I can hear a beeping when I push buttons, but the screen is blank.
  • 833 Answers
SOURCE: Whirlpool Double oven - control panel stopped working
Atlanta...sounds like you may have a power supply problem or the panel is bad. Cut the power, open the unit up and see if there is a fuse in there or a reset. No good? Then replace the circuit board. They just, well, die sometime. Happened to my microwave. Some units may be available remanufactured. Look around on the web.
Posted on Dec 07, 2007
SOURCE: whirlpool rbd275pdb double wall oven died during self clean
The first time we used our Whirlpool oven the same thing happened - no power and yet the circuit breaker was not blown. I called Whirlpool, and they sent out a technician to check it out as it was still under warranty. He said the temperature was off (too hot) by 20F - he adjusted. He also replaced the blower. What he did not tell me was that the thermal fuse had blown, and he replaced it - this was the REAL cause for the failure. I got the impression that he did not want to let me in on the secret. He did not note on the paperwork that he replaced the thermal fuse. Last week I decided to run the oven through the self-cleaning cycle (the oven is now 8-1/2 yrs old) - I don't believe that we cleaned the oven but a couple of times since the first time that it was "repaired." I used the default 3-1/2 hour setting. Everything appeared to be fine - the oven went through the cleaning cycle with no apparent problems. The display now read "cool down" - I went to bed thinking everything was okay. I got up the next morning only to find out that the power was out. I called Whirlpool and demanded that they repair the unit again as they clearly never fixed it correctly in the first place. They offered me 15% off on a new oven - WHOOPEE! I asked to speak with the supervisor - he did not budge either. I was upset, and I told him that I would NEVER purchase a Whirlpool appliance again! I decided to tear into the oven to see if I could detect anything wrong. I pulled out the front panel - everything looked okay. I then noticed the "thermal fuse" - I did not know what it was called at the time, but it looked familiar. I checked voltage on either side of the fuse and found the voltage to be zero on the downstream side of the fuse. I pulled it out and read the information on the device: Microtemp 110C. I called a local appliance repair shop - they told me that it would cost $50 to purchase a new fuse! I told them that seemed very high. I ended up stopping at Radio Shack. They have thermal fuses in various temperature and voltage ranges. I got a 144C 10A fuse and carefully soldered the connectors to it and replaced the protective plastic sleeve. I actually bypassed the thermal fuse in order to use the oven before I found the replacement fuse. While it is a good idea to have a protection device for the slim chance that an oven may malfunction by overheating, it is not a necessity for the functionality of the oven. Hopefully, the thermal fuse will not fail during my next attempt to self-clean the oven. I do have a concern about the 10 amp rating, but I'm sure that it will work fine.
Posted on Apr 15, 2009
  • 42 Answers
SOURCE: Whirlpool Double oven control panel
Sounds like you may need a new control panel
Since the keyboard and the control panel cost about the same ($150) get them checked befor you order any parts.
keyboard - part # 8300440
control board part # 830219
Posted on Aug 11, 2009
fixyourboard
  • 310 Answers
SOURCE: hi--my whirlpool double oven,model gbd277pds10
Getting beeps when you push the keypad buttons means that power is getting to the control board. First, try shutting off the breaker to power down the oven for a few minutes, then turn back on. This will force a system reset, hopefully the oven will recover.
If not, you probably have a problem in the control board. If this is the case we may be able to save you some money if you can get the board pulled. We repair oven controllers at www.fixyourboard.com
Posted on Sep 10, 2009
Macmarkus
  • 2605 Answers
SOURCE: Oven display went blank. Has Power.
Hello, The first thing I'd look at is your owner's manual to insure the timer hasn't been set to "Sabbath" mode accidently. If that is the case you could experience a "no display" scenario. The manual will also explain how to enter/exit the "Sabbath" mode. In the event the timer itself is at fault ( i.e. the display transformer gone bad ) it will have to be replaced or (if an available option exist's for your timer) have your timer rebuilt. Hope that help's and please take a second and rate the info provided by me here at fixya. Thank you and good luck. macmarkus :)
Posted on Dec 07, 2009
Have a Whirlpool Gold Accubake Double Oven. After a power outage, the display is dark and ovens are not responding to keypad. Lights work both from doors and keypad. Directions?
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty.
GBD RBD Whirlpool Oven Problems Causes and Solutions
Feb 20, 2017 | Whirlpool Ovens
Why is display blank?
You may need new capacitors on your display board, if it is expensive you can have it rebuilt
Feb 29, 2016 | Whirlpool GBD307PR Electric Double Oven
WHIRLPOOL double wall oven has a blank control screen the start button is the only button that beeps
Their is a small in line fuse going to the oven control. Service manual
6b484ffa-e6f8-4c65-aa67-df87a903038a.pngPage 4-2 shows how to get to it. Radio shack has the fuses
Nov 24, 2013 | Ovens
My whirlpool double oven accubake GBD307PDS09 display went blank!!!! HELP!
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty. GBD RBD Whirlpool Oven Problems Causes and Solutions
May 03, 2017 | Whirlpool GBD307PD Electric Double Oven
My whirlpool double oven accubake GBD307PDS09 display went blank then beeped. The oven does not turn on but when I tried to turn it on just to test it, it beeped once and then three short beeps. I have...
Hello Diana,
Their are a few things that should be checked. I know its going to be tough to check on a built in double wall oven but one thing that needs to be checked is if their is 240 volts ac entering the oven(i know the breaker is ok) but the connection at the back of the oven can burn,then the proper voltage wont enter the oven.
Another thing is a high limit thermostat thats inside of the control panel,need to checkif it has blown.
Last thing i can think to check is if 120 volts is at the clock, if not 120vac that explains the blank display
Aug 20, 2011 | Whirlpool GBD307PDS Electric Double Oven
I have a Whirlpool RBD305PDQ8. The display is blank, but will beep when pushing the buttons. If I attempt to start the oven, it will not turn the oven on and will have a series of beeps. Do I need to...
Up there in the controls is a bullet fuse like this:
Designed to kill power to the controls if it gets too hot in there so the controls won't be harmed. That could be it but I don't know if it would beep if the fuse is blown, that could be a bad control. Use this manual to help you diagnose:
Whirlpool double oven repair manual
Jan 26, 2011 | Whirlpool RBD305PD Electric Double Oven
Our home has a Whirlpool Gold built-in convection oven. The home is @5 years old. We've lived here for one year. Today, the display had an error message (E6). After we cleared the error message, the...
Hello!
Apr 21, 2017 | Whirlpool GBD307PD Electric Double Oven
Hi--my whirlpool double oven,model gbd277pds10 all of a sudden has a blank panel ,nothing works ,when you touch a command it just beeps, can anyone help me, please..
Sep 10, 2009 | Whirlpool GBD307PDS Electric Double Oven
Whirlpool Accubake System Mod.# RBD275PB10 front panel blank
Hello Edward!
May 13, 2017 | Whirlpool RBD305PD Electric Double Oven
Whirlpool RBD245PD Electric Double Oven Logo
101 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
