Question about Garden
Traeger grill keeps shutting off saying Error
2 Suggested Answers
  • 34 Answers
SOURCE: I have an electric Traeger grill. I plug it in
Make sure your grill is unplugged. Them take the controler out and there is a fuse on the back side of the control. There is also a new fuse there to replace the old one. If the fuse is blown, you could have a bad hot rod or other component that is bad. Usually the hot rod is the problem and they should be under warrenty so call Treager and get a new one sent. If the fuse blows after it is replace, you can un hook the purple wire and replace the fuse and see if it will work them. If it does, it is the hotrod.
Posted on Apr 17, 2010
Burner not working
Traeger Industries burner not working Grills & Smokers ...
www.fixya.com > Forum > Tags > burner not working > Grills & Smokers
Traeger Industries grills & smokers burner not working related questions and answers. Ask your ... Question about BBQ075 All-in-One Grill / Smoker. 1 Answer ...
Traeger Industries water pump not working Grills & Smokers ...
www.fixya.com > ... > Tags > water pump not working > Grills & Smokers
Traeger Industries grills & smokers water pump not working related ... Question about BBQ075 All-in-One Grill / Smoker ... our auger stopped working how can we fixthis. it is not the electrical .when you put pellets in the burner it will light and ...
Support - Traeger Wood Pellet Grills
www.traegergrills.com/support.html
Traeger Pellet Grills, LLC. ... Why won't my grill light? ... Why is my grill running so hot on smoke? .... Large Commercial Trailer. Download manual. View All ...
FAQS - Traeger Wood Pellet Grills
Jan 01, 2016 | Traeger Industries BBQ075 All-in-One Grill...
I keep getting an error msg. When it finally starts, it shuts off with the Err
Hi Terry,
This may help... ...from Treager's site FAQ
"My Unit Goes Out On Smoke
  1. Open the cooking chamber lid and remove cooking grill, angled drip pan and U-shaped firepot cover. Look and see if there is a large accumulation of pellet ash in and around the firepot. If there is, it will need to be cleaned out. Do this ONLY WHEN THE GRILL IS TOTALLY COLD! Replace U-shaped firepot cover, angled drip pan and cooking grills and resume cooking/smoking process.
  2. If this does not remedy the problem, please contact the Traeger Service Department."
From my personal experience, cleaning out the pellet ash is needed when the smoker will not hold a high temperature regardless of the thermostat setting.
In your case, the fire pot may be packed with pellet ash and pellets from the auger jamming.
Good luck.
May 29, 2015 | Traeger Industries BBQ070 All-in-One Grill...
Traeger grill not smoking
This is a common complaint about Traeger grills. Some people have resolved it with smoke pipes which contain pellets that smolder during the cooking process.
Others use different pellets than Traeger pellets but they void their warranty when they do. For me, Traeger pellets seem to put out enough smoke at the low temperatures I use (less than 200 degrees) but if I get above 200, the smoke goes sway.
When I cook pork shoulders, I try to keep the temperature at 180. In ideal conditions the Traeger will fluctuate between 160 and 200, averaging 180. If I can maintain this low-slow cooking temp-speed, I get a good smoke ring and decent smoke flavor.
If I get above 200, I lose much of the flavor but usually have a smoke ring though not as intense as at the lower temps. There are lots of conversations about this on blogs at the Traeger website and at the Pelletheads website.
Jun 14, 2014 | Traeger Industries BBQ100 All-in-One Grill...
Traeger grill get to hot on smoke
If you're cooking when it's hot outside, it's hard to maintain low temperatures. In the heat of summer, I have to tend my grill continually opening and closing the lid to keep the temperature down to my cooking temp of 180. That, of course, lets the smoke escape. If it gets too hot when the temperatures are moderate, i.e. 60s and 70s, the augur may be dumping too many pellets into the fire pot and need realigning. I suggest you contact Traeger customer service at http://www.traegergrills.com and see what they suggest.
Apr 20, 2014 | Traeger Industries BBQ100 All-in-One Grill...
When grill is off, pellet feed keeps running
Sounds like a short in the wiring harness. You probably should contact Traeger at www.traegergrills,com to see what they suggest.
Feb 24, 2014 | Traeger Industries Grilling
I turned off my grill yesterday and it kept on smoking. There seems to have been a fire at the base of the pellet bin. How can I fix this fast? I have three events beginning on Saturday, where my...
Whenever you finish using your Traeger it is always best to lift the lid and turn the controller down to the smoke setting and allow the temp to drop for a few minutes. This will also slow down the delivery of fresh pellets into your firepot thus starving the fire of fuel.Once the temp drops below 200 deg F than shut off the controller. If you have any wind blowing remove your Traeger out of the draft of the wind and the fire will go out on its own.
Jun 30, 2011 | Traeger Industries BBQ125 All-in-One Grill...
One of the small wheels came off the grill as I was pushing out of my garage. The grill rolled on its back. I put the grill back upright and now when I plug it in and turn the digital dial it says...
Instead of taking it back to the store, which I don't think will solve the problem. As, it's not really a warranty issue. Contact Traeger Industries Technical Service Dept 800-872-3437 for a solution to the Error Code.
Apr 13, 2011 | Traeger Industries BBQ075 All-in-One Grill...
Have a traeger grill and while cooking it gave me an error message on the digital thermostat. what could be the problem
So I got a ERR on my treager it end up being the controller thank god had a old one to test it good to know
Nov 20, 2010 | Traeger Industries BBQ070 All-in-One Grill...
I'm getting an "Err" message on my digital temperature reading. The grill starts up but then shuts down when the "Err" message comes up.
Remove your grill, inner shield and outer dip plate from the Traeger. Start the Traeger in smoke mode. Observe to see if the blower fan is working. Is the auger turning? Are the pellets dry? Condensation can make the pellets swell and cause plug ups.
Aug 13, 2010 | Traeger Industries BBQ100 All-in-One Grill...
How to charge an auger on traeger grill
Turn the control on high and wait about three minutes. Shut contol off and restart in about 1 minute, This should have enough pellets in the auger to start before the hot rod shuts off. You can also put a hand full of pellets in the burn pot and usually bu the time these pellets are burned out the others are there. A couple of cycles usually will start them.
Apr 16, 2010 | Traeger Industries BBQ100 All-in-One Grill...
Garden Logo
252 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
