Question about Eagle SeaCharter 500c DF Sonar/GPS GPS Receiver
Seacharter 480 DF
Good day
I have a 480 Df seacharter, or better i think the second in on the way
First was a problem with a cable and the machine did not read the fish echos.....problem solved
Than the beeps were not working and the seacharter did not read the map...
The company send me another seacharter
now another problem, the seacharter does not work in fish track, or better it works with fish track with fish deepth but does not work in fish track without fish deepth
Since i bought this seacharter just problems and more problems
The seacharter is in Lisbon, i Think for assistance, i hope they send me another one, and if possible ....a GOOD ONE
Luis Macedo
4 Suggested Answers
hydetech
  • 113 Answers
SOURCE: My Lowrance LMS-337c df keeps going crazy.
Normal 0 false false false MicrosoftInternetExplorer4 st1:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}This could be caused by glitch in the operating systemsoftware or by low voltage due to a short in the unit or somewhere in the boatswiring. To troubleshoot the problem Iwould recommend the following steps.
  1. Try a soft reset
  2. If the problem resurfaces, try a hard reset
  3. Update the the operating system software
Soft Reset (Does not delete GPSData)
1. Turn unit OFF 2. Press and holdthe PAGES key
3. Press and hold the PWR key
4. Release both buttons when the USA map
Appears
Hard Reset (Deletes stored GPS Data
such as Waypoints and trails)
1. Back up any waypoints, routes,and trails that you want to save on a blank MMC card
2. Turn unit OFF
3. Press and hold the ZIN&ZOUTKeys at
the same time
4. Pressand hold the PWR key
5. Release both buttons when the USAmap
appears
To update the operating system software, check out this link:
Lowrance337c df update
If you don't have a card reader I can program an update card for you.
Posted on Dec 16, 2008
SOURCE: Eagle Seacharter 642c back light flickers all the time
Mine did the same two weeks out of warranty and I was told by NAVICO, the Australian importer and repairer, to throw it in the bin as the whole unit would need replacing, thanks for the expert advice NAVICO. It will be the last Eagle/Lorance product I will ever buy.
Posted on Jun 24, 2009
Sorry to hear that this seems to be a common eagle problem. Exactly same experience couple of weeks out of warranty. Same ****. Shame on you Eagle.
Posted on Apr 01, 2010
Menu menu no longer works first menu only when pushed twice it just exits the first menu again
do a soft reset,with unit off hold down pages and power keys until it starts up and map of usa appears,release keys. Ive done this a few times now and works well I didn't lose any waypoints or data but you will have to reset units of measure etc.
Mar 01, 2012 | Eagle SeaCharter 642C DF iGPS
September 6, 2009 to March 24, 2010 is 70% of what date in the future? Thanks......
D1 is the first date given D2 is the second date given Df is the future date Dt is today's date expression is then---- D2 - D1 = 70%(Df - Dt) Solve for Df and get Df = Dt + (D2 - D1)/.7
Mar 25, 2010 | Air Tools & Compressors
Machine does not acquire its GPS position. If it does it can take up to 45 mins to achive. Can I put an external antenna on it? The unit is used in an open boat, so has clear access to the sky, so should...
your antenna is probably original and obsolete see if you have a RayStar 120, if so, it is junk. The RayStar 125 is plug and play for you and sells around 300. Your GPS is a self contained receiver, that means it uses 12 V and output computer language. If you have no power to the seatalk antenna, you get nothing. If it is intermittent as you describe, 90% chanace it is the antenna, (mushroom or puck). 847-746-0100
Dec 28, 2009 | Eagle Seacharter 502c Df Igps T/M, Hst...
No back lighting and screen blinks. Purchased exactly 2 yrs ago
Sync lock transistor is faulty here. and i agree Lowrance units are unreliable and their service is soemthing else!
Aug 19, 2009 | Eagle SeaCharter 642C DF iGPS
Backlight flickers 2 years old to the date do you
Furuno has similar displays. I don't know if Eagle provides the same support but you may be able to find an actual schematic diagram technical manual from them if you ask nicely i don't know if Eagle has any government contracts but you can try and tell them you are with some government agency like DOD navy or coast guard or homeland security ;) and see if they will send you a PDF of the manual also try Retrevo.com they may have the techmanual on file. It sounds most likely like a connector problem between the LCD and the power supply. Does it only happen out on the water (vibration or shaking)?
Jun 19, 2009 | Eagle SeaCharter 642C DF iGPS
NP 6545 Copier - Error Code E401
error code E401...DF paper feed motor lock...check the motor of your DF...try to turn off the machine and unplug the communication cable from DF to the machine and turn on the machine again...
Mar 16, 2009 | Canon NP 6545 Copier
Brother DCP8020D Document Feeder
Clean rubber rollers with metho, run a page by hand of laminate or stiff card threw the doc feeder. Stick it where the paper comes out of DF and ensure path is clear.
Push down on left side or tape down little black switch (rear left corner near glass)while trying to use df to confirm hinge aint the issue
If it is the rollers it should feed when paper is "helped a little" with hand at feed time
Ensure prints ok when using glass instead of df to know it is df problem
Cheers
Apr 28, 2008 | Brother DCP-8020D All-In-One Laser Printer
Gestetner DSC530 -- Auto Document Feeder
Normally the cable from the doc feeder has come out. Turn the machine off unplug the cable from the DF to the machine then reinstall it should click turn the machine on then try.
If this doesn't work open the DF cover and check that there are the paper detect fins also when the cover is open then the machine should register a cover open this will tell you if the DF is recognized or not.
Thanks J
Dec 13, 2007 | Gestetner DSC530 All-In-One Laser Printer
How Long Can I Record?
HS Mode STD mode LS3 Mode Tape: (1080i/720p): (Better than Mini DV): (DVD Quality): DF-300U 2.5 Hours 5 Hours 15 Hours DF-420U 3.5 Hours 7 Hours 21 Hours DF-480U* 4 Hours 8 Hours 24 Hours
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
GPS Logo
44 people viewed this question
Top Eagle GPS Experts
fordexpert
Computer Links
carl blood sr
Are you an Eagle GPS Expert? Answer questions, earn points and help others
