Question about Windsor SR12 Sensor Bagged Upright Vacuum
My Dirt Devil Vibe bagless vacuum started giving off a burning smell. The brush roller was jammed with hair. I immediately shut it off and cut the hair out of the rollers with scissors until it turned freely. When I turned it back on, the smell was gone but there's no suction now. Did I ruin the belt or something else?
  • 694 Answers
It's more likely there's a clog in the hose somewhere, possibly where it connects to the power nozzle. Detach hose and check the PN.
If there's no clog in the PN, detach hose completely from machine and try to drop a marble or coin through the hose. If it doesn't fall through, there's a clog that needs removed/cleared. Hold PN end of hose tightly to tank of vacuum and turn on. That may be enough to **** the clog through. If not, use a canister or shop vacuum to blow the clog out.
Posted on Nov 13, 2010
How do you go about cleaning the rotating brush on the dirt devil bagless vacuum?
Using a sharp pocket knife or a utility knife making a single cut across the length of the roller is a good way to start. Then it is just a matter of pulling the strands or fabric and hair, etc., off. I like to inspect the end caps and bearings as well. A touch of grease of oil can help increase the life of your roller as well. ( for the bearings)
Jun 10, 2011 | Dirt Devil Featherlite Bagless Vacuum...
I dont have a manual for the dirt devil vibe bagless cleaner. It's depositing dirt instead of picking it up. Is there a belt? i don't see one and maybe that's why
Information on your Dirt Devil Vibe Bagless Quick Vac M084500V can be found here:
http://www.dirtdevil.com/products/details.aspx?id=M084500V#parts
A link is available to download the manual as well as for replacement parts.
Yes this model has a belt to run the power brush; the manual has replacement instructions.
If dirst is being left behind it could also be a problem with a blockage, overfilled dirt cotnainer, or problem with the filter.
Mar 27, 2011 | Dirt Devil M084500V Vibe Quick Vac Bagless...
When I sart to run my bagless vacuum, it runs for a second and then shuts off. I replaced the belt and the filter. The repairman told me that on bagless vaccuums, the motor and bearings get clogged w
take the brush roller off and on the ends are the bearing caps.try to take those off and clean the bearings ,carpet strands and hair will cause that.after you do that make sure the roller turns freely if not then the bearings might be bad and if thats the case you might have to order a new brush rollersome bearing caps unscrew and others pull off
Apr 27, 2009 | Vacuums
Dirt Devil Jaguar Bagless Upright Burning Smell
take the belt off again you will see burnt rubber from the old belt stuck to the motor shaft.you can take a fine piece of emery cloth and clean the shaft down to its polished finish.always good to do this after each belt.check the brush roller and see if there are any signsd of plastic melted.make sure it turns freely if not the brush roller might be siezing uo on youhave you cleaned the hepa filter?does it smell like wires burning or rubber.with it unlugged take it apart to the motor and take a fine iece of emery cloth and go over the motor armature .then try it again.you can take all the filters out and run it without the filters.that will help you narrow it down.please leave feedback
Mar 15, 2009 | Dirt Devil Featherlite Bagless Vacuum...
M1300 i dirt devil brushes wont roll
Ok I would say the belt burnt into if you can turn it on and the motor runs it is the belt . I would pull it apart and replace the belt.
Feb 25, 2009 | Dirt Devil M130000 ''i'' Dual Cyclonic...
Dirt devil vibe 088915v
Are you talking about the beater bar? If so, you probably have a broken belt
Jan 16, 2009 | Dirt Devil Featherlight Bagless Upright...
The belt is broken of my dirt devil
Remove brush roller and black caps at each end of the roller. Clean and oil the bearings.they must turn freely.
Dec 10, 2008 | Dirt Devil Vision Turbo W/Bonus Upright...
Dirt Devil M088174 Rattling Noise
You may need a new brush roll. The ends should turn easily,
Dec 26, 2007 | Dirt Devil M088175 Extra Light Upright...
Windsor SR12 Sensor Bagged Upright Vacuum Logo
99 people viewed this question
Top Windsor Vacuums Experts
Mike
Thatvacguy.com
Are you a Windsor Vacuum Expert? Answer questions, earn points and help others
