Question about Intermatic Hardware & Accessories
Instructions on connecting Model T8805P10C1 - Intermatic Hardware & Accessories
  • bebus01 Nov 16, 2010
    I think that I gave the wrong Model; it should be T8845PV. Also to which block is the wiring from the electric source attached.
    Thanks
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly.
This timer is used to control a solenoid.
The connection diagram is here:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t8805p101c%20-%20english.ashx
On the bottom of the terminal block there are 4 terminals. (Terminal one to the left)
Input power WHITE - connects to Common and the Clock connection
Input power BLACK - connects to the Line connection
Solenoid power - connects to the Clock (White) and Line (Black) connection.
Input power if it has a solid copper wire would also connect to the Ground.
All power connections for this timer must comply with National Electric Codes year 2005 and after.
If you have a rain sensor it will connect to the 2 terminal block and uses the timers 24 VAC output to power the rain sensor.
Kelly
Posted on Nov 14, 2010
  • Kelly
    Kelly Nov 16, 2010
    Here is the data sheet: http://www.intermatic.com/~/media/files/... - english.ashx
    The power in is white to neutral
    and black to the line connection.
    The solenoid power is 24 volts and will not be connected to either the white or neutral input power connections it should be a separate terminal block.
    The Ground connection is usually a solid copper wire from the main power. (if used depending on local electrical code)
    Kelly
  • Kelly
    Kelly Nov 19, 2010
    Hi, Just doing a follow up. Were you able to get your timer connected?
    Kelly
Need instruction on how to set it up (i.e. connect it) Is there an online instruction manual?
depends what you're connecting it to.
try typing the model number of your router followed by the word manual into google and you'll get the instructions.
Jun 04, 2015 | Computers & Internet
Black decker instructions
Go here: http://servicenet.blackanddecker.com/Parts/Search?searchedNumber=Model%20#%20ASI300
You will need the Model #, there are instructions for locating this and it will connect you with the Instruction manual.
Aug 16, 2014 | Black & Decker ASI300 Air Station Inflator
My ledu light did not come with instructions and i need to know how to put it together?
Please. If it is difficult for you to find out without any instruction, how difficult could it be for someone not seeing an instruction and not seeing the lamp? Perhaps you did give us a brand, but surely not what model.
Jun 26, 2014 | Ledu Corporation Home
I reset my roku 2 and now it will scan for and find a wireless connection to connect to however will not connect, the light that usually flashes while it is trying to connect will not flash... I can't even...
Ok first try these step process if you have:
Roku 2 (Model 2720) - http://support.roku.com/entries/27936640-Roku-2-Model-2720-Setup-Instructions
Roku 2 XS(Model 3100) - http://support.roku.com/entries/27940370-Roku-2-XS-Model-3100-Setup-Instructions
Try to reboot again if still have problem and after all Roku will not connect than try to reset your router or configure your router with your ISP. For router configuration and set-up Linksys Support .
Jun 04, 2014 | Computers & Internet
How to connect an HT-E550 to a receiver?
One of the biggest problems with connecting devices are missing owners instruction manuals. They instruct and advise how a device are used and connected. If you haven't a owners manual contacting the manufacture on the internet often provides on screen manuals to download and advise as they are the manufacture who made and deigned the model of your device.
Other problems is constant updating of connections that are often obsolete very quickly. In a case like this doing homework examining the type of ports used by the manufacture of the model identifying the type looking up your model in Google images you can match the type of ports the images show the manufacture has elected to use to check if they are consistent specs for your model spec and determine the port to port connections that may be required unique to your model number.
Another avenue consulting service shops for advice with using print outs of any images you are concerned about and photographs can be helpful
Another avenue is images of your model showing the ports posted on line to an expert who may be helpful if they can see the ports and advise.
May 04, 2014 | Samsung HT-E550 1000W 5.1-Channel DVD Home...
Manual for jabra t820
To pair the Jabra with a Verizon Wireless phone, the phone must have Bluetooth. Bluetooth allows a device to communicate and transfer data with another Bluetooth device without having to be physically connected to it. The instructions for connecting the Jabra with the Verizon phone vary slightly depending upon your phone model. Jabra headset instructions don't vary per model.
Jun 19, 2012 | Radio Communications
I just bought a netbook but i can't get it to connect to my wireless router. in the instructions of the netbook it states that if this problem occures i must go into the setting of the router and hide...
Please visit the link below or click HERE >>
Connecting wireless computers to your network and follow the instructions on how to connect your netbook to your wifi router ..
Also please provide more details about your problem ..like netbook model # , router make or model ...or if you are getting an error while connecting your netbook to your wireless router.
Click the add/view button to reply .
Dec 19, 2011 | Linksys Wireless-G WRT54G Router
Connecting to an existing wireless LAN
Hi there you can find the instructions for connecting your netgear DG8345G wireless router to your existing wireless router by configuring first your netgear router and click to help so that you can see the instructions by configuring it into your pc or you will go to the netgear support website so that you can find that model and look for instructions for your netgear router..
Jun 25, 2008 | NetGear DG834G 802.11G Wireless ADSL...
Connection
Please provide a little more information about the model of the Samsung. Generally, when partnering with a bluetooth device, the default code to enter in to the phone is 0000. This will secure the negotiation with the headset.
I'd need the model of the Samsung to indicate which menu options to select in the phone.
Hope this helps, if it does, please choose FixYa!
ThankYa!
Nov 09, 2007 | Microsoft Office Outlook 2003 for PC
Hardware & Accessories Logo
107 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
