Secure heatsink to cpu
I cannot figure out how to securethe heatsink and fan to the motherboard. Coolermaster ICT-D925R-GP
  • Anonymous Dec 30, 2008
    shuts down after one hour,found that the fan is not working, opened and cleaned dust of cooling fins, but cannot remove fan because the fan plug will not slide under chassis support. might have to remove plug from connecting wires.after i put everything sack the computer light goes one but no display and no hard drive sound. i wasw very carefull in puting back the processor so i can not see that it might have been damaged.
    Sergeant:
  • 458 Answers
I see why you are here. The website s#@.
It looks like you would remove the on board square and replace it with this because it appeared to snap in. Push down to install. Try not to remove anything if you have 4 holes in your board. What board and processor do you have?
Rate this as a fixya if it fixes your problem.
Posted on Jun 26, 2008
Where can I get instructions to put unidentified tower together?
You have all the pieces .. motherboard .. cpu .. ram .... heatsink/cpu fan?
Place the cpu into the motherboard socket. Note that it only fits one way. Check the pins on the cpu against the holes in the socket. Hold it in place with the securing catch/lever that you will see on the side.
Smear some heatsink/cpu paste onto the top of the cpu. The heatsink paste is basically a 'heat resistant glue'
Put the cpu cooling fan onto the cpu and screw it into position. Or, it may have a securing lever to hold it in place.
Put the RAM into the ram slots. They only fit one way. Make sure they are firmly in place.
Put the motherboard into the casing. Align what holes you can and use the screws that come with the casing to secure the motherboard.
Connect the casing power supply to the motherboard. Note that it only fits one way.
Connect the cpu cooling fan to the motherboard connector. It only fits one way ..
Next, look at the leads that are just lying loose .. the small female 2 pin connectors will be marked 'PWR' ..'LED'..'RESTART' ... There maybe 8 of them.
On the motherboard identify the block of male 2 pin connectors. The female connectors must connect to them. You'll need good eyes and probably a flashlight, as the writing on the motherboard is small..
If you are connecting a sata hard drive, connect to the motherboard connection that says 0. Connect your dvd drive to '1' Again, notice that sata leads can only fit one way.
Then connect any video or sound cards to the motherboard (if any).
Just look on the motherboard for anywhere the connecting wires will attach. You won't go far wrong.
The casing won't come with instructions of 'what to do' as such. If there were instructions there it would relate to pin/hard drive connections.
What you CAN do is a google search. If, for example, your motherboard is an ASUS 123456 .. search for 'ASUS 123456 motherboard connections'. Or log onto the motherboard manufacturer's website ..
Here's a couple of links that may help:
How to Build Computer The Complete Guide
How to build PC step by step comprehensive guide
Feb 19, 2016 | Computers & Internet
Aver AX1700 high cpu temp
apply some quality thermal paste (silver grease) between cpu and heatsink to maximaze the hat transfer between those 2 elements
Mar 13, 2012 | INTEL - BLKD945GRWLK Motherboard
Continuous beep and the systems is not coming up {boot}
Hardware problem:
* dead RAM
* dead video-card
* RAM not fully "seated" in its slot(s)
* video-card not fully "seated"
* dead fan on top of the CPU/heatsink.
* failing power-supply.
Jul 12, 2011 | HP Compaq dc5100 Small Form Factor PC...
New build cant post,dram light on red and keeps re booting every 2 sec
Firstly I would check that the cpu is correctly inserted into socket, heatsink and fan securely in place and that the cpu fan is connected properly to the motherboard
Jul 10, 2011 | Gigabyte Motherboard GAG1ASSASSIN Core I7...
My Pc heats up very soon and then power off itself.
Do you have forced air cooling fans running over the CPU and motherboard? If not then get them running. Check to see if it they are running correctly. Make sure that all the heatsinks are free of dust and any other obstructions – vacuum them out with a soft brush tool. Also monitor the fans speed and CPU tem from the BIOS. Also check that the CPU heatsink is correctly mounted on the CPU and if necessary get some heat transfer grease and cover the top of the CPU ii it making sure it is evenly spread and then reseat the heat sink and secure it firmly. Do not let it fall on the motherboard or CPU pins or socket. Monitor the CPU temperature in the BIOS. You can also invest in a can of freezer spray from an electrical component store and spray areas of the motherboard to see if this helps. Try small areas at a time starting with the CPU & Heatsink. Then try the maim system RAM and then move on to the BIOS chip and NVRAM and then on to the graphics processor or card. If all this fails you may need to replace the CPU.
Oct 02, 2009 | Intel D101GGC Motherboard
Dell 5160 stop all of sudden. Message shows CPU too hot. What should I do?
There are 3 or 4 possible causes:
The fan in the computer is damaged.
You are using the computer on a very hot environment.
or ventilation outlets in the computer are blocked.
Aug 28, 2009 | Dell Heatsink Assembly
When I boot the machine it gives me a thermal overheat event msg and shuts down, I believe the thermal contact between the fan and processor has broken, I do not know how to remove the cpu fan and re apply...
Theres many types of sockets for motherboards. If PC clone, search for the book manual for pinpoint wath socket it it or it is a IBM or DELL or HP, the same except the latter is little more tricky when detaching the heatsink. Once figured out, disconect the power, touch the fuselage of the PC to discharge from ESD. Of course, buy a heatsink compound and you can clean the cpu and bottonm of the heatsink with paper towel and Isopropyl Alcohol and apply new compound. Not too much, the nessesary only. I'd like to apply in a whirpool like on the CPU. And the heatcopound color grey is the best.
Aug 21, 2009 | Intel D845GLLY Motherboard
Intel D865GVHZ (Gateway Hazelton) motherboard system cooling fan
This fan error message shows up when the CPU fan is not plugged into the CPU FAN plug on the motherboard. The Intel D865GVHZ
motherboard has a total of 4-fan plugs so it is easy to plug the CPU fan into one of the other fan plugs that is not marked CPU FAN on the motherboard.
Apr 12, 2009 | Intel (8W501B1M3G) CPU Fan, CPU Cooling...
Computers & Internet Logo
400 people viewed this question
David Payne
David Payne
