Question about Apple iPod MA446LL/A MP3 Player
My ipod classic is stuck on "do not disconnect"
5 Suggested Answers
ohms
  • 1879 Answers
SOURCE: ipod is stuck on disk mode.
ipod instructions here
too many to paste in here
Posted on Sep 02, 2008
  • 50 Answers
SOURCE: my ipod classic is stuck
Even if the above mentioned step doesn't work, it should ad least turn the iPod off. Then you can push the menu and the play button as you connect it to the computer. That will force-connect your iPod to the computer so you can restore it. AFter that you should be up and running again. If not you may have a hard drive or hard drive cable issue, there is an iPod repair service that can help you with that or a free ipod repair guide, if you want to do it yourself
Posted on Jan 31, 2009
jazzyboy11
  • 728 Answers
SOURCE: ipod classic
Try doing this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal. Hope this helps!
Posted on Apr 18, 2009
  • 500 Answers
SOURCE: itunes no llonger recognizes my
W dyson,
To unlock it from the "Do Not Disconnect Mode", do the following:
1) Toggle HOLD switch to ON and then OFF (Slide/Move it to HOLD, then turn it OFF again)
2) Press and HOLD the Menu and Center/Select (Do not hold press it dead centre though) buttons together at the same time until the APPLE logo appears, This takes about 8 to 10 sec.
ALSO NOTE: (Found this on an Apple Help site, if the above does not work)
Try connecting iPOD to a Active power adapter, or connect iPod to your Active computer. Now try resetting the iPOD while it is connected to power.
As for the problem with syncing, please check the setting "Sync Music" in the Music Tab which is found in iTunes, after selecting your device. Like so: Plug In Device >> Select Device In iTunes >> Select Music Tab >> Make sure Sync Music is selected...
Your problems should be over.
Hope you find this helpful. If you do, please accept the answer.
Posted on Apr 18, 2011
Ipod touch is stuck in loading
Hi grazwobam
Try these solutions to your problem
**************************************************************************If you have forgotten the code, you can unlock the IPod by doing the following:
Connect your IPod to the primary computer you use it with (the first one IPod synced with), and open iTunes.
When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock IPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod.
Afterwards, you can add your music and data back to your iPod.
If you want to change the primary computer that your IPod is associated with, do this:
1. Restore your iPod. WARNING: The restore process cannot be undone.
All of your songs and files will be deleted. Always make a backup of your important data.
2. Connect your iPod to the computer that you want to be the primary computer.
3. Open iTunes and synchronize.
If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the IPod, which will erase all music and data.
Please take time to rate me
Bud
Oct 07, 2012 | Apple iPod touch
My ipod classic (160GB) can't be restored by using itunes10
just do one thing Press Both menu and select buttons for few seconds till u see apple symbol on screen and leave it it will restore...!
Mar 18, 2012 | Apple 160 GB iPod Classic (Silver) +...
Charging in dock, knocked off table. Stuck on charging screen.
Use the Five Rs to restore the iPod. You will lose the data that is currently on it if you restore but you can always re-sync the data to the iPod. http://www.apple.com/support/ipod/five_rs/
-=/ Daft Tech /=-
Oct 25, 2009 | Apple iPod classic MP3 Player
Ipod classic
Apr 09, 2009 | Apple iPod classic MP3 Player
Unusual iPod Classic connection/sync problem
Try downloading the driver for your ipod onto your computer and see if that works
Mar 26, 2009 | Apple iPod classic 6th Generation Digital...
Problem with ipod classic
Hi! YOu need to disconnect your ipod from the pc.
Put the ipod into diskmode by following these instructions-
Before placing the iPod into disk mode, you should verify that it is charged.
Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
ht1363_2.jpg Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect
After doing this open latest version of itunes and then restore your ipod to factory settings by selecting it from itunes.
Dec 29, 2008 | Apple iPod classic MP3 Player
My ipod classic is stuck on "Do Not Disconnect"
Hi There.
Reset on any iPod is to Hold 'Menu' And 'Select' together until the Apple symbol appears.
All the best
Sean
PiDigital
Dec 16, 2008 | Apple iPod classic MP3 Player
Apple iPod MA446LL/A MP3 Player Logo
70 people viewed this question
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
