Question about ASUS M51Sn-C1 Notebook
Ive put windows 7 on my asus m51a and in the device manager cant up date the base system device it has no driver can you help
    Genius:
  • 1,542 Answers
Hi
It could be for the card reader try here :-
http://support.asus.com/
Also make sure you do all the updates
Posted on Nov 13, 2010
Usb Ports not working
The best solution is to go to ASUS web site and try to download the drivers. You should have to put the model and Operating System that you are using (Ex. Windows 7 32 or 64 bits, Windows 8) and then select the option for USB drivers download them and see if it helps. Also double check the device manager if it has an exclamation mark over the Universal Serial bus Controllers, if there's one that means there's a problem with the drivers. You can check it by clicking on start then right click on Computer and click on Properties then in the right side click on Device Manager.Good luck!
Nov 13, 2013 | ASUS K Computers & Internet
Bluetooth driver installation problem. Please help.
The best thing to do would be to use "system restore" to roll your computer back to a stage before the new driver was installed if you feel you need to revert the changes you have made.
Here is a guide on how to use system restore: http://pcsupport.about.com/od/fixtheproblem/ht/system-restore-windows-7.htm
Using that guide as reference, open up system restore and select a restore point that is tagged with a date prior to that when you installed the offending driver. System restore should then automatically make the required changes to your system and reboot. Any changes you made after the date you selected will now be reversed. Do not fear losing documents or other items you may have edited or created after that date as system restore does not affect such items. Only system settings and system files like drivers.
You may not have system restore enabled. If that is the case try opening control panel, then under the heading "programs" select the link "uninstall a program". This will open a list of software installed on your machine. In there you will hopefully find the drivers you installed. Select them and at the top of the window you should have the option to select "uninstall". Do this to remove the drivers.
If neither of these things work for you the next method would be to open device manager. To do this press the "windows + R" to open the "run" box. Type into the box "devmgmt.msc" (without quotes). This will open the device manager. In device manager you will see a list of devices in your machine. Navigate to the device with the dodgy driver, right click on the device in the list and from the context menu that appears select "uninstall".
Once you have tried any of these solutions you will need to restart your machine to see whether they have worked.
I hope this helps.
Jan 09, 2013 | ASUS Computer International K53e B1...
I have an Asus M51A with built in camera when i try to install the drivers for it it returns an error that there is no camera found, it doesnt show in device manage i also have an error for the mobile...
If you do a cold start, unplug AC from remove battery, hold on/off button for a few seconds, replace battery, plug into AC, start normally. Your windows vista OS should ID your webcam and search fro the driver and other devices. Run windows update for drivers and updates. If that fails look for the drivers here: http://www.asus.com/Notebooks/Multimedia_Entertainment/M51A/#download
Nov 09, 2012 | ASUS M51A-A1 PC Notebook
Bluetooth code 43
Click the Start button, click Control Panel, click System and Maintenance, and then click Device Manager.
If you are prompted for an administrator password or confirmation, type the password or provide confirmation
In the list, double-click the type of device, and then locate the specific device that isn't working properly.
If an exclamation mark appears next to the name of the device, Device Manager can't find the device driver. Go to "Use Windows Update to find a device driver."
If no exclamation mark appears next to the name of the device, go to "Uninstall and reinstall the device driver."
Close Device Manager.
hope this helps
Aug 01, 2012 | Microsoft Windows 7 Ultimate for PC
I cant find drive ASUS P5L 1394 Intel 945 Chipset for window 7 , please help me !
If you mean you cant driver or are having problems with drivers
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
if your computer came with a motherboard disk the drivers could be on it
hope this helps
Jun 28, 2011 | ASUS P5L-VM 1394 Motherboard
I install windows 7 ultimate to my ASUS Eee PC and THe VGA driver was missing
Try having Windows find the video driver automatically. To do this open device manager by clicking the Start menu in the lower left corner, select Control panel then System and Security. Click System. Then click Device Manager on the left hand side.
Once there look for your VGA card. Right click and choose to update driver. Select the option to have Windows automatically update the driver. Windows 7 is usually pretty good for getting most common drivers like video, sound, networking (LAN & Wireless) and the chipsets.
If that doesn't work, please post your exact Asus Eee PC model (eg 1005HAB) and I can try to find the exact driver.
Please leave feedback if this was helpful. Thanks.
Apr 16, 2011 | Computers & Internet
I upgraded the OS of my loptop ASUS a9RP from window xp to window 7.The device driver for base system device has not been installed, its because the software included has an OS of window xp and I need the...
Within Win7 Pro and Ultimate there is a in XP Mode. That would mean you can use your old driver howver, before that I would check on the manufacturers web site for your Base System for Win7 drivers. You may well find thet Vista drivers work OK.
Hope that helps.
Apr 03, 2011 | ASUS Computers & Internet
Hi I have a xp proffesional os the device manager indicates a yellow exclamation icon SM Bus controller and unknown devices. triend to find the driver in intel and asus support site but cant find the...
Try going to the system manufacturer's site and look for updates,
(however, you really should upgrade. Windows 7 works well, migrate your data while the old system still operates, and everything gets put away correctly. New hardware works significantly faster than XP era hardware....Hate to put $$ into older system.)
Feb 12, 2011 | Computers & Internet
My webcam is upside down and i cant change it back.. how could i do this?
Hi
This seems to be a problem on the asus sometimes
i have read that if you go to your device manager
start
search
device manager
click on it
scroll down to find the webcam write down what make it is and go to that website to find a driver
please let us know if this works as there is a lot of people on fixya with the same problem on their asus laptops especially when they are putting windows 7 operating system on it
Feb 01, 2011 | ASUS A8Jm Notebook
Ok, so my computer is a home build system with the EliteGroup ECS 945GCT-M/1333 Motherboard - v3.0. i was using windows xp for a long time and every thing worked correctly but i recantly upgraded to...
control panel admistrive tools,computer management,device manager scroll down sound and video controllers you should see a yellow question mark? right click to reinstall drivers you might find something there hope this helps
Sep 15, 2010 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
ASUS M51Sn-C1 Notebook Logo
562 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
