Question about Jenn-Air 21.6 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water
Where do you install the filter for the ice maker ?
  • dlaporte774 Nov 16, 2010
    The answer was way off the mark. Each refridgerator has a filter holder inside the fridge itself. I could not find the one on this model. I went into Sears and got the info I needed.
  • 17,970 Answers
Keep in mind that you have "retractable ice/water filter" there; to know how work and maintenance this part, I suggtes check THIS LINK with information about: Water Filtration System.
Depending on your model, there may be a water filter indicator or water filter status lights on the control panel. Follow the instructions specific to your model in page 10 and next.
Hope this helps. Keep us updated.
Posted on Nov 16, 2010
  • Jenn-Air Master
  • 43,501 Answers
Ususally the best place to install the filter is in the water line going to the refrigerator....
If you can get it in the line at a place that is always accessible it makes it easier to change it every few moths...
Cut the water line and just use compression fitting or if it has the push in fittings the istall is even easier...
heatman101
Posted on Nov 14, 2010
  • D. Floyd Kolb
    D. Floyd Kolb Nov 16, 2010
    You did not say that... so I took from you question that you did not have one in that fridge or that you wantted to install a separate one...
    It is very hard on this end to read a mind when the questions are so vague many times...
    I do my best to guess at what the person is thinking and yes... sometimes I am way off.. my apologies for not getting it right...
    heatman101
Ice maker no longer making ice after changing filter,GE Eterna ESS25LG refrigerator
recheck filter install is water valve on and is ice maker itself on
Jul 24, 2016 | Refrigerators
I HAVE SMOLL BLACK DIRT IN ONE IND OF MY ICE MAKER . ALLWAYS SEAMS TO BE AT BOTTOM . NOT MUCH BUT SOME .
if you're seeing things in the ice cubes or you say there's dirt in the ice maker most likely the ice maker is rotting out and needs to be replaced,my ice maker lasted 7 years and i had to replace it
Feb 21, 2011 | Refrigerators
Ice maker not working
If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
May 30, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice from ice maker taste bad and can not find a water filter on it.
I would install a filter inline on the water filter I have one under the sink and on the ice maker
Apr 14, 2009 | Refrigerators
I have a Whirlpool Model EC3JHAXRL00. The ice
Is the ice maker wire shutoff arm or switch (depending on
models) in the OFF position?
 Is the water line shutoff valve to the refrigerator turned on?
 Has the ice maker just been installed? Is the freezer
temperature cold enough to produce ice? Wait 24 hours
after ice maker hookup for ice production to begin. Allow
3 days after ice production begins to completely fill ice
container.
 Does the ice maker mold have water in it or has no ice
been produced? Make sure your refrigerator has been
connected to a water supply and the supply shutoff valve is
turned on.
 Has a large amount of ice just been removed? Allow
24 hours for ice maker to produce more ice.
 Is there a water filter installed on the refrigerator? The filter
may be clogged or installed incorrectly.
 Is an ice cube jammed in the ice maker ejector arm?
For models with an interior ice bin, remove the ice from the
ejector arm with a plastic utensil.
 Is a reverse osmosis water filtration system connected to
your cold water supply? Make sue your connections are secure.
Feb 19, 2009 | Refrigerators
Ice from ice maker does not taste right
Hi
Ice storage bin needs to be emptied and washed. Unsealed packages in the refrigerator and/or freezer compartments may be transmitting odors/tastes to the ice cubes.
Interior of the refrigerator may need cleaning.
Water chemicals. Installing an in-line filter can help with many odor/taste complaints.
An open box of baking soda in the refrigerator section can help with preventing the transmitting of food odors.
This is a common in-line water filter, they are fairly easy to install and usually come with instructions.
Even when your well or municipal water supply provides healthy, potable water to your ice maker, some impurities may remain. These can affect the smell or taste of the ice cubes, and therefore the beverages in which you serve them. A taste and odor water filter on the incoming water-supply line--such as our charcoal "Universal Replacement Water Filter"--can help a lot.
Also, over time, the ice cube bin can absorb difficult-to-remove odors from the freezer. Some manufactures recommend that you replace the bin every 2 to 3 years, whenever it seems to be retaining objectionable odors and transferring them to the ice cubes.
A Fixya Rating would be appreciated.
Thanks
Rylee
Feb 11, 2009 | Whirlpool ED2GHEXN Side by Side...
New ice maker--was working till filter changed- no ice now ...
You may not have the filter installed correctly, or installed the correct filter.
If you rotate to lock the filter in place, make sure you rotated the filter completely to lock.
If you had to turn the water off, did you turn it back on?
Jan 06, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
Hello jitkagardner,
Welcome
You said, The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
How old is the fridge?
When have you last changed the water filter.
Should be down below at the front grille!
Try these tasks!
If the ice maker is not producing ice or not enough ice
Refrigerator connected to a water supply and the supply
shutoff valve turned on? Connect refrigerator to water
supply and turn water shutoff valve fully open.
• Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
• Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
• New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
• Freezer door closed completely? Firmly close the freezer
compartment door. If the freezer compartment door will not
close all the way, see "The doors will not close completely."
• Large amount of ice recently removed? Allow 24 hours for
• Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
• Water filter installed on the refrigerator? Remove filter and
operate ice maker. If ice volume improves, then the filter may
be clogged or incorrectly installed. Replace filter or reinstall it
correctly.
• Reverse osmosis water filtration system connected to
your cold water supply? This can decrease water pressure.
Let me know how it goes!
Huuum
Please remember to leave a rating!
Oct 21, 2008 | Refrigerators
ICE MAKER...NO WATER IN ICE PAN
do you have water thru the door? you may have air in the line. filter incorrectly installed / or a bad water valve
let me know
Apr 04, 2008 | GE GSS25SGSSS Stainless Steel Side by Side...
Ice Maker
First, are you getting water at the door? If not, the filter is installed wrong or there is some packing on the filter you didn't remove.
Jan 10, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Jenn-Air 21.6 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water Logo
53 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
jasbo
jasbo
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
