Question about Campbell Hausfeld 8GAL Air Compressor
Regulator will not hold indicated air pressure output. reducing regulator pressure to zero then reset results in little difference, output appears to be on low end.
    President:
  • Campbell Hau... Master
  • 1,388 Answers
Pressure regulator can be dis-assembled and lubricated or replaced. If lip seal and pressure pin are dry, the regulator will not function correctly. I do not think that there is a repair kit but try lubing with silicone paste sold at Lowes in the plumbing department. Lowes also stocks campbell hausfeld regulators and water seperators. An upgraded regulator will provide more cfm and a greater accuracy in pressure control. To repair regulator, empty tank of air and turn regulator counter clockwise to release pressure on spring and take apart. If you do not see any way to dis-assemble, then there is a tiny pin on the lower edge of knob that must be removed before knob will thread off completely. Push pin up from under knob. Good luck
Posted on Nov 13, 2010
Tip
How to Reset Your Air Purifier Filter Light
<span style="font-weight: bold;">Airgle Air Purifier:</span><br /> <ol> <li>Turn off and unplug the unit </li> <li>Press the light button to the "on" position </li> <li>Plug in the unit, and then release the button after the Filter-check starts</li> <li>The system will automatically reset the Filter-Check Gauge in about 25 seconds</li> <li>Once the procedure has completed resetting, please turn on the unit and press "Filter Check" button again.</li> <li>This time, the system should report an accurate result. </li></ol><span style="font-weight: bold;">Alive Air Purifier:</span><br /> <ol> <li>Insert a straightened out paper clip into the reset hole, with the unit off, and push the Timer button.</li> <li>You should hear a 2 beeps, signaling that the Reset was successful.</li></ol><span style="font-weight: bold;">Holmes Air Purifier:</span><br /> <ol> <li>Units which have an indicator light must be reset once the HEPA filter has been replaced. Reset indicator by inserting a small object (such as a pin or paperclip) into the hole marked reset.</li></ol><span style="font-weight: bold;">Honeywell Air Purifier:</span><br /> <ol> <li>Reset the filter indicator by pressing and holding the "Filter Monitor" button until the indicator light shuts off.</li></ol>or<br /> <ol> <li>With the unit powered on, press and hold the appropriate filter<br />indicator button down for approximately 10 seconds until the<br />light turns off.</li></ol><span style="font-weight: bold;">Hunter Air Purifier:</span><br /> <ol> <li>Change the filter and/or pre-filter.</li> <li>Now, you must choose which counter you want to reset. Press and hold the filter reset key (approximately three seconds) until the prefilter indicator flashes. Press and release the reset key again to alternate between the two indicators. The counter that will be reset is designated by the flashing indicator. For Models 36394 and 36395: Use the tip of a pen or pencil to press the key.</li> <li>Once you have the correct indicator flashing, press and hold the reset key for three seconds to reset that counter to zero hours. The indicator will stop flashing when it has been reset. If needed, repeat these steps to reset the other counter.</li></ol><span style="font-weight: bold;">IQAir Air Purifier:</span><br /> <ol> <li>To reach the Filter Life Reset function from the main display window, press the Menu key seven times.</li> <li>Press and hold the Enter key until the flashing cursor appears. Release the Enter key. The first filter selection to appear is the Pre-Filter.</li> <li>Press the Up Arrow key to select the filter that has been replaced. The Filter Life LED for the appropriate filter is now flashing red.</li> <li>Press the Enter key to confirm that the selected filter has been replaced. The filter life LED for the appropriate filter is now flashing red.</li> <li>Press the Enter key one more time to confirm the filter change or to exit without resetting the filter life, press the Menu key (M=Menu).</li> <li>Upon successful reset of the filter life, the new remaining filter life (taking the currently selected fan speed into account) will be displayed, and the filter LED light on the control panel will change from red to green.</li></ol><span style="font-weight: bold;">Kenmore Air Purifier:</span><br /> <ol> <li>Press the FUNCTION and OFF TIMER buttons at the same time for five seconds. The CHANGE FILTER INDICATOR will flash five times and turn off </li></ol>
on Jun 17, 2011 | Air Purifiers
Pressure in tanks is fine,but when i go to inflate a tire for example I get a burst of pressure and the regulating indicator drops to zero with just a trickle of air, no volume or pressure....
Over time water and debris will enter the regulator and cause problems. Easy to fix however. Drain air from tank and turn pressure control knob out to relieve pressure on the internal spring. Open the regulator and clean and lube the internal parts (use silicone paste lube on rubber parts). Some regulators have a small nut on the rear that should be remove to clean small piston. If parts are rusted beyond usefulness, replace with generic regulator that will fit into space. Good luck
Jun 18, 2011 | Hitachi EC12 Portable Electric 2hp Air...
Have an 80 Gal. 2 stage compressor outside, below freezing temps with 100% humidity. Running 2 DA's, they keep losing air pressure inside the DA's, hose pressure is good but DA will not let air past the...
Mark,
First bring that compressor in from the cold. Any water it collects in the tank is freezing and reducing the volume of air it can hold.
Second, it sounds like water is getting to the DA and freezing at the inlet. Will also be solved by bringing the compressor inside.
Third, put the filters at least 25 feet from the compressor if possible. And make sure all lines from the compressor to the outlets are running a little up hill. This way any water that gets in the pipes will run back toward the compressor
Fourth, At each station have at least 4 inches of pipe below the fitting with valve on the bottom. This way any moisture that gets to the end of the pipe has someplace else to go rather than the air tool.
This will not only make your tools run better but they will last a lot longer.
Feb 28, 2011 | Ingersoll Rand 6? Dual Action Sander #...
I just bought this unit took it home read the instructions loaded the gun with nails hooked up the cables opened the gauge turned on the unit and i waited for the tank to fill with air and the gauge...
There are usually two gages, one for the pressure in the tank, the other is for the regulated pressure in the hose going to whatever tool you have connected. I assume the tank filled up and the tank gage registers pressure in the tank. When you said you "opened the gage" I am guessing that you turned the knob counter-clockwise which would be the normal direction to open a valve. However, this is not a valve, it is a spring loaded regulator device. When you turn the knob counterclockwise you are removing all pressure from the spring which sets the regulator to allow zero pressure in the hose. Turn the knob clockwise to increase the pressure in the hose. I hope this was helpful. Good luck.
Feb 18, 2011 | Porter Cable Air Tools & Compressors
I can get 120PSI easily but no or very little pressure on the pressure gauge going to the hose. Can"t even run a staple gun.
Most regulators have an adjustment knob that allows you to set the output pressure for the intended tool. You should be able to adjust the pressure at the regulator by operating the knob and observing the pressure on the output gauge. If you don't have an output gauge, connect something to the air hose so that you can observe the changes that you make by operating the tool and feeling the air. I use a blow gun when I need to do it like this. Works good.
Best regards, --W/D--
Jan 22, 2011 | Garden
My accu-gage tire gage does not hold tire pressure reading. the dial drops slowly down to zero.
If there is a button you push to release the pressure (resetting the gage to zero), this is a valve which probably has a little piece of dirt impeding the seal of that valve. The dirt would have been carried there by the air and condensation. But don't take it apart to clean it. This is a typical problem with these kinds of gages. When you have plenty of air available (a compressor nearby) hold the gage on the valve stem, while you repeatedly push the release button. That should clear the dirt, but you may need to add more air to the tire.
Jan 17, 2010 | Accu Gage Tire Pressure Guage 60 Psi Range...
Will only produec 20lb of pressure
I have the same make/model. Connect a device to your air line (impact, blow gun, doesn't matter anything that will use air). Operate the device and note if the pressure on your output gauge falls, and then rises back to 20# when you let off of the device. If it does, this indicates that your regulator is either defective, or it is adjusted too low. Try adjusting the regulator knob, operating it in both directions, and note the pressure on the output gauge. If you can get it to rise, you're home free!
Regards, --W/D--
Jul 16, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
BMW 320D,2006- run flat tyre warning light is on. How do I reset?
Using the indicator stalk, navigate to the tyre pressure reset option, press the reset button twice in short succession but hold it in the second time until a tick appears on the display
Apr 19, 2009 | 2003 BMW 325
Campbell Hausfeld 8GAL Air Compressor Logo
408 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
