Monitor goes into Power Save mode unexpectedly
This problem seems to be getting progressively worse. When I'm on the computer the screen sometimes breaks up, looking a little bit like I'm looking through a venetian blind with bands across it. The computer will freeze up and sometimes then go into Power Save mode. When I try to reboot, 7 out of 10 times it will go immediately into Power Save Mode and nothing I try gets it working.
  • VLA63 Jun 19, 2008
    I thought my monitor was starting to go so I went and bought a new one...same problem. I turn the computer on when I need it and off when I don't. I checked my Power Options and all seems to be OK, there was nothing that was changed and this seems to be a progressive problem, i.e. getting more frequent and harder to reboot.
  • niko rh
    niko rh Dec 11, 2013
    dear friend i have the same problem any fix for that unexpected safe mode?
    Scholar:
  • 152 Answers
What are your settings in Control Panel, Performance and Maintenance, Power Options? Do you leave your pc on all of the time or do you turn it on just when you need it? If you are getting lines on your monitor, it is possible that it's starting to give out on you. Please don't try to fix a monitor unless you know EXACTLY what you are doing. It can be very dangerous.
Posted on Jun 18, 2008
  • Tricia Scerbo
    Tricia Scerbo Aug 21, 2008
    Is it possible that you have a virus? Have you scanned your system for problems? It appears that the problem is NOT the monitor, since the new one is doing the same thing. (Did you buy the same monitor?) Here's what I would do if I were you. I would back up my system and reformat the "C" drive and reinstall. Yes, I know it's a pain, but if this problem is continuing, then it's not the monitor, it's something with the pc.
BenQ G2400W power save mode works find with DVI but will not go into power save using HDMI cable.
Look on the remote find the button under menu then on the screen find sleep timer or power saber and turn off.
Terry
Jan 31, 2015 | BenQ G2400W Monitor
Computer screen goes into "digital power saving mode"
You should be able to adjust the settings on the monitor to prevent it from going into power save mode, or at least to delay how long it takes before it goes into power save mode. Press the menu button and look for settings that might disable or change power save mode.
Also, does your desktop/PC display show anything before the monitor goes into power save mode? If nothing comes up, its possible that you have a loose VGA connection or that your video card/motherboard are defective in some ways. Try using a different monitor.
If the other monitor works fine with your computer, try changing/lowering the screen resolution. If in XP right-click on the desktop and go to Properties, and select the tab for display settings and adjust the resolution. If in Vista/Win7, right-click the desktop and select Screen Resolution/Display Settings and adjust it there. Then check and see if your newer monitor works on it.
If the other monitor also doesn't show any display, most likely the problem is either with your video cable or your PC's video card/motherboard, not the monitor.
Hope that helps. Good luck
Feb 15, 2010 | LG L1915S 19" LCD Monitor
Computer powers up but monitor goes right to sleep?
when i power start my computer,,the light come on and seems to operate but the monitor doesn't come on,,,when switichin the monitor off and on , the blue light comes on and it reads monitor goin to sleep and the screen gets dark,,but the monitor orange light is on,,,pls help
Sep 21, 2009 | HP Pavilion MX70 17" CRT Monitor
My Dell E176FPc monitor seems to be stuck in power saver mode. There is no way to access the on screen menu. When the monitor is unplugged from the compouter, it shows a self test screen with 3 colored...
Try the monitor if you can on another computer and see if it stays in power save mode. If it does then the monitor is bad.
If you try the monitor on another computer and you get video then that means theres an issue with the original computer.
Aug 04, 2009 | Dell E176FPC Monitor
LG W1952T LCD monitor power save mode during bootup?
called customer service - see other post for details
May 11, 2009 | LG L1915S 19" LCD Monitor
Monitor goes to power save mode on startup
Sounds like a bad video card (if embeded "built in") then you need a new mother board
Dec 09, 2008 | Belkin (F6C800-UNV-PL) UPS System
Monitor automatically clicks into power saving mode
check the primary settings for your default video card.
Jun 08, 2008 | Dell Dimension 4600 PC Desktop
LG Flatron L1710S Monitor stuck in Power Save Mode
Try wiggling the Cord on the backside of the monitor.. Not the Power Plug Cord, The Other Cord that attaches to the PC. Do this once the monitor turns off , grab ahold of the cord about 2 inches from the back of the monitor, then bend the cord to the right, keep bending from the right to the left a couple times to see if your screen comes back, if it does, than you have a Loose connection and this sometimes causes the Symptoms you are receiving.. Hope it helps.
Jun 02, 2008 | LG Flatron L1710S 17" LCD Monitor
Computers & Internet Logo
137 people viewed this question
David Payne
David Payne
