Question about Toshiba Televison & Video
Toshiba Dr570ku dvd recorder froze. get no reaction from the buttons on the remote, OR on the unit. Clock switched to military (24 hour) time by itself. Had to turn off power to the unit to shut it off, same reaction when It was powered up again
SOURCE: TV LED Flashes then TV shuts itself off
capacitor problems in power supply or a regulater isolate the power suppley by disconecting the line output stage/unplug scan coils for example and run a 60w bulb as a dummy load one wire to earth and the other to rail voltage colecter of line output transister if the bulb glows steady the power supplys fine
Posted on Jun 25, 2007
  • 12 Answers
SOURCE: 24 hour-12 hour time
Press Set - hold (top Left button) -When the sec start flashing go to the bottom left button press it 3 times -When the hour flashes press the bottom right button 1 time -Press the top left 1 once with
Posted on Jul 05, 2007
snakehead
  • 1074 Answers
SOURCE: Panasonic DMR ES30V DVD Recorder/VCR
take it to a tech to check the system control chip could be bad.good luck
Posted on Jul 22, 2007
atlasuk2007
  • 85 Answers
SOURCE: RCA DRC-285 DVD Player won't respond
hi, 2 things usually cause this kind of behaviour 1-the dvd+r have been burnt at a high speed 2-the dvd player itself is a bit old when you burn your dvd+R always burn them at a lower speed lowest if possible it'll take longer but it's well worth it and you wouldn't have a problem playing them back
Posted on Aug 22, 2007
spare_head_2
  • 47 Answers
SOURCE: Wharfdale DVDR24HD160F
Hi Barb22,
Sounds faulty to me, I'd take it back to the store and get a replacement. However, I guess you want that DVD out first? I'm not sure this will work because the units logic board is mostly likely faulty and will prevent the DVD transport from opening. Unplug the unit and press the eject button, keeping it pressed plug the unit back in. If the unit does not come on then press the power button too. If the unit starts to open release the button immediately. It's unlikely to eject, but you might get lucky.
Sorry I can't be of much further help.
Regards,
Spare head 2
Please don't forget to rate this response.
Posted on Jan 13, 2008
Why does time keep switching to military?
you have it set on 24 hour time instead of 12 hour time
it will change over at midnight to military time as that is when the 24 hour period ( military time ) starts
May 01, 2015 | Elgin Travel Alarm Clock
The clock says 13:01 AM!!! Tried everything in the directions none of the buttons do anything...
Switch button on bottom of clock from 24 to 12. Military time uses a 24 hour clock which means 1:00 PM becomes 1300. This doesn't answer "AM" as there is no am or pm for military time.
Feb 19, 2013 | Elgin 3468E Electric Time-Ready LCD...
I have a toshiba dr570ku/i only get 2 hours recording time
If you have the manual it should give you the instructions under timer recordings. If not you should be able to find the manual on their website.
Oct 30, 2012 | Toshiba DR570 DVD Recorder
My bose wave radio 1 somehow switched to military time. There is no clock set button?
Not explicily, but on page 18 of the manual (Bose.com) clock setting is explained...
To set AM/PM (12 hour) or Military (24 hour) time - Press the On/Off button once to turn your Wave radio off.
Press and hold Clock Set, and then press On/Off to switch between AM/PM (12 HR) or military (24 HR) formats
Sep 08, 2011 | Bose Wave Radio
My bose just started using military time in place of the P.M. how can I get this back to using normal time?
It's in the manual...
Jul 05, 2011 | Bose Wave Radio
Time is in miltary time with a 24 hour clock. I want it regular
It's in the manual which is available at Bose.com
May 21, 2011 | Bose Wave Radio
I want to change the time from military to regular, but my bose does not have clock set just and arrow to the right and left for time
The manual is available at Bose.com and page 17-18 shows the detail.
May 02, 2011 | Bose Wave Radio
I want to change from military time to regular time on my Bose wave radio. I already tried holding down the alarm set button and on/off button but it didn't work
Page 18
http://www.retrevo.com/support/Bose-Wave-radio-Radios-manual/id/525bh044/t/2/
Jan 27, 2011 | Bose Audio Players & Recorders
Clock is in military time mode. How do I reset to regular? Also I want to preset radio stations and I've lost my manual.
Here is your manual in PDF format:
http://www.bose.co.uk/GB/en/images/Wave%20Radio%20CD_tcm6-4104.pdf
To set AM/PM (12 hour) or Military (24 hour) time - With the system off, hold down Alarm Setup and press On/Off to switch between AM/PM (12 hour) and Military (24 hour) time formats.
To preset up to 6 AM and 6 FM stations - Use the Track/Tune buttons to find the desired station. Then, on the control panel only, hold down any Preset button until the preset number lights. The station is now preset to that number.
Dec 05, 2009 | Bose Wave Radio
Clock format
24 hour mode is all there is. Time to learn military time.
Feb 11, 2008 | Protron PD-DVR100 DVD Recorder
Televison & Video Logo
108 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
