Question about Dell 5650 Computer Speakers
Dell MMS 5650 speaker Volume control
I can't control the volume with the control knob. I have to use the volume Icon. Any suggestions?
  • litesp Jun 20, 2008
    It worked great until a few weeks ago. The volume control on the soundbar turns on at the full volume even at lowest setting. I removed all the screws on the soundbar but can't figure out how to take it apart.
  • ClanMac Aug 20, 2008
    I have the same identical problem, with no apparent solution. Has anyone corrected theirs??
    Problem Solver:
  • 16 Answers
Since it has been working perfectly, you need you change the control knob, there may be a pershal contact that is preventing it from controlling the volume.
Jowinson
Posted on Jun 20, 2008
I have a Kenwood KC 105 preamp and the volume is stuck on high. I turn the volume knob but it does nothing. Any suggestions?
Looks like you are going to have to replace the potentiometer, AKA volume control. It must be shorted out inside (probably) or knob came off the shaft. (doubtful)
Feb 02, 2015 | Kenwood Sc-75 Av Surround Processor...
Yamaha RX-V1000 volume control erratic, remote doesn't work. All was well then the volume control knob became erratic (volume would change erratically as knob was turned in either direction, remain...
sounds like you need to take it in to have it looked at. no simple fix unless you are an appliance technician. hard to walk a beginner through. i suggest calling an stereo repair guy.
Fix Ya
FixYa Support
Please accept solution and rate 4 thumbs up! Thanks for your feedback!
Aug 21, 2011 | Yamaha RX-V1000 Receiver
Dell Home Theater Speaker System MMS 5650, subwoofer not turning on...fuse NOT blown. Has turned on for a second and then goes back out. What is the problem??
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
:((appropriate speakers)): also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Jul 05, 2011 | Dell 5650 Computer Speakers
Volume adjuster stays on one level can not increase or reduce volume
The Potentiometer/switch (the rotary knob to adjust the volume) is probably faulty. The original is a 9mm B50K panel pot/switch. I'm on the hunt right now for a replacement.
If I can't get one, I'll have repair it using substitute parts, specifically an appropriately sized SPST switch for the power circuit and a regular B50K potentiometer to adjust the volume.
Feb 24, 2011 | Dell 5650 Computer Speakers
16 year old Blaupunkt Toronto SQR 48 on/off/volume control knob ?
blaupunkt doesn't supply parts after ten years on their decks. you can try salvage yards.
Mar 03, 2010 | Car Audio & Video
Replacement volume control knob for pioneer deh
an authorized service centre in the back of the pamphlet that came with the reciever,or direct from pioneer.
Jan 13, 2010 | Pioneer DEH-P6900UB CD Player
Volume won't stay set
There have been many new things that have been introduced when Google bought Youtube, and I believe that one of them is that it resets the computers speaker volume all they way up, the best I can currently suggest is that you leave the computer volume up and turn the physical speaker volume down, and it should be fine.
Hope this has helped,
Ryan Frame
Creative Energy Associates Technical Center
Aug 16, 2009 | Dell 5650 Computer Speakers
Dell 5650 Computer Speakers Logo
2,252 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Greg Cann
Greg Cann
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
