Question about Samsung SGH-U600
Samsung SGH-U600 Blank Screen
I have read your solution, i took the battery out and the cover off, now i am confused as i dont see any clips at all.
Could you please help and tell me where it is located and it would be really helpfull if you could show me a picture. Thanks
  • Anonymous Jan 17, 2009
    blank screen and soft touch does not work
  • Anonymous Apr 03, 2009
    what do u do after u screw them out, also my phone speaker only works if i slide it down.
Then you should remove the sticker under the battery with the IMEI # an screw out 6 screws
Posted on Jun 21, 2008
Midland walkietalkies -how do you put in new
You have to remove the belt clip, then the battery cover. There is a locking tab at the top of the belt clip.
To remove the belt clip, press the LOCK TAB down , then gently pull the belt clip up toward the top of the radio.
Then remove the battery cover, press near the seam and slide the cover down:
Replace the batteries, observing polarity.
Slide the cover back on until it locks in place.
To install the belt clip, slide the clip down into the slot on the back
of the radio until the belt clip lock clicks.
Hope this helps! If you need more help, please ask!
Oct 17, 2013 | Midland LXT310 2-Way Radio
Overide pass word for windows 7
take thr cover off, by the battery youll see the word bios, next to it youll see a little like a very small cover, thres 3 clips but only covers 2 , you move it , to the ,left or right, then you start your pc,.it will go into bios mode, it clears the password, dont change anything in bios,exit saving default setting,it will tell you to turn off pc, and move clip back ,to original position, restart your pc & it should work also remove battery for aprox: 10 minutes, good luck
Feb 05, 2013 | E-Machines eMachines Desktop PC
I just purchased a Deltran Battery Tender Junior to charge the weak battery on my motorcycle. I was told to hook it up to the battery of my 2008 Yamaha Royal Star Venture. Butl in reading the directions,...
Jerry ,
An alligator clip is not required . just connect your terminals the right way . The red ( positive ) to the positive + on the battery terminal and the negative to the - of the battery . Please ensure to have the ignition turned off while you are charging the battery of you may " cook " some relay or CDI unit which is the main brain of the ignition system . Make sure to have good contact between the charger and the battery . The best way to recharge a battery is to disconnect the terminals from the bike to the battery and connect the charger alone to the battery to avoid any damage . Best of luck with that
Jan 05, 2011 | 2008 Yamaha Royal Star Venture
We had a power outage and now our phone blinks constantly..(.the red light that tells us when we have a message) how can we extinguish the light??
hello sir ,kindly follow these steps..
1) pull out the power supply from base unit
2) now pull out the battery cover on your handset
3) now very carefully (dont pull too hard) pull out the battery )
4) let it stay out of the phone for 15 mins
5) now insert the battery and fix the cover back on
6) plug it to power supply
and check your problem will be definately solved , still if confused mail me at cellphonez99@gmail.com , and if u find this helpfull plz vote, regards.
Dec 03, 2010 | Uniden Cordless Phone
Please can someone tell me what website to use to get a replacemen battery cover for the roboraptor.
wha website can be used for goruping series of hotwheels for collecting numbering system very confusing on packaging
Oct 11, 2009 | Wowwee Toys
Where are the fuses in 2001 chrysler voyager
Under the hood to the right of the battery. Squeeze the clips and lift the lid of the fuse box. Inside the lid it tells you what each fuse is used for, it's a bit hard to read black raised letters on a black plastic backround.
Also inside under the dash on the extreme left side beside the computer access port are more I am told. I think you remove the plastic cover held in by two screws. I never took it off but since my defrosters don't work front or rear or heated mirrors I hope to find the fuse in there.
I really hope help you with this. Good luck (remember rated this help).
Oct 06, 2009 | 2001 Chrysler Voyager
Please tell me where is located the battery on a Pontiac Torrent 2006?. thank you in advance for any help you can provide
Battery is under plastic cover on right front under hood. There may be a module clipped to the cover that you have to remove forst, then pop cover up.
Jun 22, 2009 | 2006 Pontiac Torrent
Dxg 506v
Casio EXZ60 battery cover and battery retainer.
Casio parts center Ph# 800-223.2001
$2.50 for the cover and .50 cents for the battery clip.
It only took 2 days on Internet, 4 trips to camera shops and numerous phone calls to finally win. My parts are on order.
Feb 24, 2008 | Cameras
CHANGiNG THE COVER!
Slide the phone open, looking at the back of the front slide, use a credit card or similar stiff plastic to unlock clips (2 clips at top sides, two clips lower sides)
Aug 05, 2007 | Nokia 6288 Cellular Phone
Samsung SGH-U600 Logo
1,790 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
