Question about Panasonic VDR-D150EF-S DVD Camcorder
I tried to finalize my disc on my panasonic, vdr-d150 video camera, and it said finalizing failed. Took the disc out & now after re-inserting in the camera it says "please check the disck" Also tried the disc in my PC & DVD player but it is not working... Is there any easy way to recover the flles? Thanks
sandrew
  • 2961 Answers
SOURCE: How do I get videos from camera onto PC? panasonic VDR-M30PP
Sorry for asking, but have you installed the drivers that came with the camera onto your pc, because some of the software has this built in to enable you do as you wish with the recordings. Also PS2 consoles dont play all types of DVD especially DVD-RW, but normally DVD do have to be finalised before they are playable. If all else fails just uninstall the drivers that you got with camera and re-install before connecting your camera back up, if they were installed initially. Normally it's wise to install all the software bundle that comes with it, then later remove what you don't need and don't have more than one editing programme installed as they can conflict stopping your downloads. Hope this helps.
Posted on Oct 13, 2006
SOURCE: Cannot finalize disc
I discovered a solution to the finalizing issue and perhaps it is the same for you. It turns out the disc I have (I think that came with the camera) is a DVD-RAM and these do not need to be finalized. I just went straight to the DVD Movie Album downloaded from the set up disc and it downloaded. Hope that helps.
Posted on Mar 10, 2008
SOURCE: problem in finalizing the disc over camcorder.
Inorder to finalize the disc you must purchase, or have a piece for the charger that looks like a battery. it plugs into the charger than into the camera. The camera will not finalize the disc without it incase the battery runs out, than all info would be lost.
A huge pain in the ***. I know, I have the same problem.
Posted on Mar 28, 2008
jerryg50
  • 1689 Answers
SOURCE: i have the panasonic DVR-255.
With use, the laser tends to weaken. It is possible that it has reached the end of its lifespan. It is also possible that with use, the tracking alignment has drifted off specs.
You can call Panasonic to find out where their service rep is located for you to have a quotation for repair. If it is only tracking alignment that needs to be re-set up, the repair cost would be an hour or two for the work done. If the laser is defective, then the repair will be fairly expensive.
Jerry G.
Posted on May 26, 2008
SOURCE: transfering dvd ram disc to computer
try buying ulead videostudio and it doesnt even need to be finalized.
videostudio was great for me because i could simply put in my disc and then click on import from disc and it would import it onto my computer. hope that helps.
Posted on Aug 30, 2008
I have bought Panasonic camcorder VDR-D150 which using mini DVD disc. I can't finalize the disc because i have lost the cable which use to connect the charger to the camcorder. Can you please advise...
see camcorder manual, tape model of cord, on your computer search bar make sure you go to a website that provides reviews from previous buyers, then pay using visa to possible avoid a fraudulent purchase,good look.
Aug 29, 2011 | Panasonic VDR-D150EF-S DVD Camcorder
How i can finalize my vob file that i filmed in panasonic camera vdr d100
Need to provide power from ac charger of camera so disc finalize option will appear to finalize disc.
Powering camcorder with battery wont give you Finalize option so use ac charger to get Finalize menu.
Thanks.
Dec 25, 2010 | Panasonic VDR-D250 DVD Camcorder
INCOMPATIBLE DISC
Good news.. you should be able to put the disc back in to the device that you recorded in on... and go to the menu to do the finalize... in fact, you may be able to add more to you disc prior to the finalize process if you want...
once it's finalized you should be able to view on other equipment... your files should all be there as well.
Let me know how you do!
May 26, 2009 | Panasonic VDR-D300 DVD Camcorder
Camera menu
I replied you before, how to finalize disc in this model.
Use ac adapter to see disc finalize option in menu. If you use battery, you will not see finalize option there.
Dec 24, 2008 | Panasonic Palmcorder VDR-M50 DVD Camcorder
HOW TO FINALIZE A DISC
I replied you in premium post as well. here is with details...
Be sure to use the AC adapter to power the DVD Video Camera when
finalizing a DVD-R disc. Finalization cannot be executed using a battery pack. Now you will see finalize option in menu and can select it to finalize disc.
Good luck.
Transfering dvd ram disc to computer
Aug 26, 2008 | Panasonic VDR-D100 DVD Camcorder
VDR-D210
the disc is most probally badly manufactured this is why it could not finalize. the only thing you can do now is playback the disc in the camera and plug the AV out into a stand alone dvd recorder and dump it to disc or hdd.
Jun 08, 2008 | Panasonic VDR-D200 DVD Camcorder
How can I finalize an open disc to view content on disc.
Ekse,
I'm having the same problem that Sandyur is having. There is something on the disc because I can view it on the camcorder. I just can't view it on the pc.
Apr 15, 2008 | Panasonic VDR-M53 DVD Camcorder
hy,
I recovered my data (video) with a program, and then with another program i transformed the file in video that is more accesible
Mar 02, 2008 | Panasonic VDR-D300 DVD Camcorder
Problem in finalizing the disc over camcorder.
Dec 24, 2006 | Panasonic VDR-D250 DVD Camcorder
Panasonic VDR-D150EF-S DVD Camcorder Logo
248 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
