Question about LG WM-2277HW Front Load Washer
Help please water leak
My washer is leaking water from underneath i cant really tell where. i have cleaned the screens on the back and front bottom. also the door you have to hold it in for it to engage the starting cycle. sometimes it wont unlock
  • 487 Answers
HERE is your service manual MAybe that will give you an idea
Posted on Jun 19, 2008
Leaking in the front
The door gasket can fail, and the bellows can get a little hole.
Nov 26, 2013 | Whirlpool LSQ9659PW 2 SPD 10 CYC 4 TEMP 5...
Kenmoor elite he 5t steam washer 47787 leaking from bottom. cant tell where leak is origanating from
Check your incoming fittings at the back of the machine-then if they aren't leaking your going to need to do a tear down and check inside machine-if you can't see anything going on you may need to hook water back up and run to see where the leak is-cheers Denny
Oct 26, 2013 | Kenmore Elite 45986 Front Load Washer
My maytag epic z is leaking from underneath
Remove the front bottom panel. Should be three 1/4" screws on bottom lip of panel. See if you can tell where leak originated. Chances are good you just need to pop the cap off the drain pump and clean it out. Here is a vid that explains the procedure.
http://www.youtube.com/watch?v=iLftnaruKp8
Jan 21, 2013 | Maytag EPIC MFW9700S Front Load Washer
My whirlpool duet front loader is leaking water? Not sure from where cause I havn't caught it in the act. But when I go in to get the clothes I have a puddle right under the front door. Cant tell if is is...
empty the washer. then remove the bottom panel of the machine.put some water in it and see if the water is leaking when it is filling or full.I have seen a small hole in the tub just behind the bottom counter balance where the mounting bolt goes you may need to use a small mirror to look under there.f94b104.jpg
Jun 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Front loader water leaks from bottom
This problem is usually attributed to the door bellow (rubber gray seal) becoming ripped or torn. If you puill back the folds in the rubber and inspect it, you may find a rip or hole in it some where. Another way to tell is by removing the bottom panel under the door and inspect from underneath. It is common for the front counterweight (concrete block) to become wet if the door bellow is leaking. Now, it is normal for these door bellows to wear out and they can be replaced. The following link explains how:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
Replacements can be purchased on line at searspartsdirect.com, appliancepartspros.com, repairclinic.com, or pcappliancerepair.com. All these sites offer competitiive pricing and great service, so shop all of them for the best price. If you still have questions, or require additional assistance, please let me know. I hope this helps you.
If my diagnosis is incorrect, please post back and elaborate on where the leak may be coming from so I can assist you better.
Jun 23, 2009 | Kenmore 42822 Front Load Washer
Washer leaking when filling up tub
Unlikely to be pump, sounds more like hose leaking, or drum seal.
Depending upon severity of leak, place a sheet of newspaper under front of m/c, pushing it as far back as you can. switch m/c on for a few secs, then switch off, remove paper and you should be able to judge where leak is.
Tilt m/c back and have a look underneath.
At 12 years old, if it looks major, I think I would replace m/c.
Plz rate my solution.
Thanks.
Dec 31, 2008 | Maytag Dependable Care LAT9206
When filling up my washing machine is leaking bad.I cant tell exactly where the water is coming from.I tilted the washer up so I could look underneath and couldn't tell anything was wet,so i turned it on...
Dear Customer,
i'll provide you with some checks,which when performed would stop the leakage from your Washing Machine..
Water is leaking onto the ground
  • Inspect the water supply connections
  • Inspect the drain hose
  • Inspect the water pump
  • Inspect outer tub for cracks or corrosion
  • Inspect the tub seal
  • Inspect the tub bearing
mam i hope this would work out.i request you to please rate this solution if it meets your needs.Thank You
Dec 18, 2008 | LG WM-2277HW Front Load Washer
Water leaks from underneath washer
my washer is leaking with water on floor.it is now geeting worse. the washer seems to clean fine. my floor is gettig ruined please help
Jun 03, 2008 | Frigidaire FTF2140ES King Size Front-Load...
Water Leaks from beneath my washing machine
Our WM2077CW just started the water leaking from underneath. We unplugged the electrical cord and disconnected the hoses (water, drain). We then removed the inspection plate from the back and checked for wet hoses. The big black hose on the bottom was a little wet. On careful examination we found a small hole that looked like a material fatigue failure at the point where the accordion part of the hose met with the solid part of the hose near the main drum connection. I suspect this is may occur in other LG washers of the same design. Unless your floor is perfectly level it's hard to tell whether coming from the left or right side really indicates where underneath the water is coming from.
Nov 26, 2007 | LG WM-2277HW Front Load Washer
LG WD-8016C Front Load Washer leaks from the bottom
Crawls, usually all leaks are visible. Im surprised the repairman did not actually get to the source of it. Your drain pump sits on the bottom and it possibly could be the filter cap, hoses to the pump or pump itself. Another area to check is the despensor. There are a number of hoses to this which could be leaking. The bellow itself could have a cut in it somewhere along the bottom. I would call the repairman back and have him at least get to the source of the leak...Catriver..post back.
Aug 14, 2006 | LG WD-16115FD Front Load Washer
LG WM-2277HW Front Load Washer Logo
276 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
