The WGT624 v3 internet globe is blinking but the wireless light is not illuminated
  • 7,733 Answers
Make sure the physical connection is good between the computer in question and the D-Link gateway. If you do not have a solid link light, try swapping cables. Make sure the ethernet adapter is installed and functioning properly.
If you are running any firewall software on the computer that cannot connect, disable it. Make sure the TCP/IP settings are set to obtain an IP address automatically. Try releasing and renewing the IP address for your ethernet adapter. It should pull a 192.168.0.x address with a subnet mask of 255.255.255.0 and a default gateway of 192.168.0.1. If it does not get an IP address in this range, specify the address to be 192.168.0.10, subnet mask 255.255.255.0, and add the default gateway and primary DNS 192.168.0.1. Try and go online.
If it still cannot get online, go to the Control Panel and open Internet Options. Restore the default settings on the Security and Advanced tabs. On the Configuration tab, make sure the Dial Up setting is set to never dial a connection. Click the LAN settings button. All you want selected here is automatically detect settings, uncheck the other two boxes. Try and go online.
Posted on Nov 13, 2010
WGT624 wifi light blinking
Someone is using it? Log in and verify DHCP clients to see how many connections are on.
Dec 09, 2012 | NetGear WGT624 Wireless Router
Tip
How to configure Netgear WGT624 v3 router with Globe Broadband Huawei B200...
1. You have to reset your router to its original factory configuration by using the reset button at the back of the router (WGT624 v3) near the antenna. 2. Connect the cable from the Globe Broadband Huawei B200 modem to the wan port of the router. 3. Connect another cable (RJ45) from the router (any Lan port on the router) to the laptop or desktop. 4. Switch on both device (modem and router). 5. Wait till both device boot up and the modem flash a blue, green and yellow color on its led and solid green to all router indicator led except the test led indicator flashing for a few seconds only.
6. Open your browser (e.g. Mozilla Firefox, Safari...) 7. Type http://192.168.1.1 at the address bar. 8. Netgear setup website will open. 9. Go to advance settings. 10. Go to back up menu and click erase to reset your router to its original factory settings. 11. Logout. 12. Switch off the device (modem and router). 13. Remove the cable connecting the computer and the Lan port of the router. 14. Connect the modem directly to the laptop using the cable. 15. Open a browser. 16. Go to the netgear website. 17. Go to the Support menu on the Netgear Website. 18. Type the model of the modem (WGT624 v3) on the blank space provided (Find your product). 19. Go to Downloads. 20. Download WGT624v3 Firmware Version 2.0.26_1.01 NA. 21. Read the instruction how to download the firmware and how to upgrade your router to the new firmware. 22. Save the downloaded firmware. 23. Exit the Netgear Website. 24. Switch off the modem. 25. Now follow the instructions #2 to #8. 26. Go to "Upgrade the Router" menu. 27. Upload the downloaded firmware to the router. 28. After uploading the firmware go to the Basic Settings Menu or use the Smart Wizard Menu to configure your Router.(Important Updates: Lan IP Address will be changed automatically to 10.0.0.1). Automatic internet connections will be tested by the network. 29. Configure your wireless settings. Logout. 30. Reboot all the devices and the laptop/desktop. 31. Follow the sequence when rebooting. (modem-router-laptop/desktop). 32. Open a browser and browse any website. 33. Enjoy.
on Jul 12, 2010 | Computers & Internet
My netgear is up and running and all the bars are up and im on it but when i log on too the web it says problem loding page
Netgear WGT624 V3 Wireless Router Problems by BigG2 - January 16, 2007 1:17 AM PST
Hi Guys/Gals,
My wireless connection is not working and i cannot log on to it, I have connected a Netgear WGT624 V3 Wireless Router to my Motorola SurfBoard SB5101E Modem which is connected to Telewest Cable Broadband (internet works fine if i access directly through the modem), on the router the power light is lit and also the internet light flashes rapidly but the wireless light comes on for a couple of
seconds and then goes out - i think this is the problem? I have tried logging on to the router to check the wireless settings but cannot access it, i have also tried connecting directly via LAN but cannot get this to work either although i am not sure if i have connected it correctly?
Any ideas/comments/advice is very much appreciated!!
Thanks in advance,
Jan 05, 2011 | NetGear WGT624 Wireless Router
Wireless computers lose signal
try reset wireless settings
or reset to defaults and use a wpa2 Encript security.
Jan 15, 2010 | NetGear WGT624 Wireless Router
My WGT624 v3 has no power, seems dead
Yup, I have seen those die that way sometimes. Put a voltmeter on the power supply to check (or take it to Radio-Shack) but it is probbaly the router itself
JOAT
Oct 16, 2009 | NetGear WGT624 Wireless Router
The light with the globe is constantly blinking
If you tell me the version number of your Belkin mimo wireless router , i will fix this issue.Any Routers issue contactme,, i will help you out. copy and paste this URL to your Browser http://techhobbies.blogspot.com
Feb 25, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
WGT624 v3 transmits no wireless signal.
You have to set up your router again. The id will be "admin" the password "password".
See manual" http://kbserver.netgear.com/pdf/wgt624v3_ref_manual_25Apr05.pdf
Feb 19, 2009 | NetGear WGT624 Wireless Router
Internet works but wireless does not on WGT324 v3
if you're having problems communicating with your old router try to reset it by pressing on the reset button and then hold for 30seconds first. if you just press on it quickly, the router will not reset. this is the last option because by resetting it, your router will go back to its default settings and the un/pw is admin and password or admin and leave password blank
Dec 11, 2008 | NetGear DG834G Router
Have no set up instructions for the wgt624 wireless router
do you have the cd that came with it? if not, everything can be downloaded here
http://kbserver.netgear.com/products/WGT624v1.asp
there 4 different routers in the wgt624 family. this is the first. check your label to be sure it isn't a later model chipset such as v2, v3, v4. if so use the download link at the netgear site to get the correct downloads for your specific model.
Nov 30, 2008 | NetGear WGT624 Wireless Router
Netgear 108 Mbps Router WGT624 v3
As you say that, you are able to go online with the modem, connect your modem- router and laptop witha cable and check if you are able to go online with the router wired first, if yes, then the w/ls settings has to be checked..open your w/ls network connection, remove your preferred wireless network and then try to reconnect again and check.. if you are not able to gon online wired with the router, disconnect power cables from modem- router , wait for 10 sec, and reconnect it , wait till all the lights come up and then reconnect, check if you are able to go online if not your router has to be reconfigured,,
plz check and revert back in case of any issues
Nov 27, 2007 | NetGear WGT624 Wireless Router
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
