Question about Canon imageRUNNER C3220 Color Copier
Machine shuts off immediately
When switch is turned on the machine shuts offf. Have replaced fused board and power supply. Even with fuser drawer pulled out the machine will not stay on.
    Problem Solver:
  • 16 Answers
Check both lamps, exposure & heater lamps. Sometimes it may happen due to open thermister
Posted on May 04, 2013
Please check your power switch it may be bad, if it is coming of and goes off, Try and change your power switch.
Jowinson
Posted on Jun 19, 2008
  • 67 Answers
Your ac driver could be damage or a connector is loose
Minolta dialta di 181 CO500 service call
Press the Trouble Reset Switch on the master Board for this fusing malfunction. Remove rear cover to gain access to control board, small little black switch, power must be on to do this be careful if the code come s back buy a new fuser unit, if you can find one. Quite old machine. DO NOT CONTINUE TO RESET the fuser can catch on fire that will ruin a perfectly good day.!!!!!
Apr 22, 2017 | Minolta Office Equipment & Supplies
Hi there, My Dell 1815dn printer makes a clicking sound when I turn it on, and displays an error message "fuser door open", even when the door is closed. I have removed the fuser and turned...
There is a switch that should "close" when the door closes.
But, that switch either is damaged, or it is not sending the "now closed" signal to the printer.
Check that there is no obstruction blocking that switch, nor any dust plugging it up.
Jun 08, 2011 | Office Equipment & Supplies
Where is the fuse door open
The fuser door is located on the back of the machine. If that door is shut but you are still receiving this error, you should replace the High Voltage Power Supply because the fuser door sensor is a part of this board. You can order this part from Iteminc.com (part# WH773). GOOD LUCK!
Mar 25, 2011 | Dell 1815dn All-In-One Laser Printer
System error E000
E000 Fuser thermistor, heater thermal fuse E001 Fuser thermistor, or triac E002 Fuser thermistor, thermal fuse or triac E003 Fuser thermistor, heater, thermal fuse or triac E004 Triac or fuser won't shut off E007 Fuser film is off center or not driving properly. Might be able to reset in service mode 4-407 E010 Main motor drive problem E030 Counter E041 Paper deck motor, clutch or sensor E064 Composite power supply or main motor board E202 Scan problem. Motor sensor E210 Lens drive problem E220 Exposure lamp E240 Main board or composite power supply E260 Main board, power supply cooling fan or composite power supply E261 Composite power supply or fluctuating power E400 ADF communication to machine E401 ADF pickup motor or sensor E402 ADF belt motor drive E403 ADF feed motor or slip sensor E404 ADF exit motor E411 ADF document detect, or registration sensor or edge sensor E500 Sorter communication problem E510 Sorter drive problem E530 Stapler guide b
Jan 06, 2010 | Canon Office Equipment & Supplies
Permanent warming up message
When you replace a power supply for this machine, it needs to be the correct power supply for this model. If you have the old one, check to make sure the right power supply was ordered for this specific model.
Because I cannot see the display, and we only know what it is saying, the next best thing would be to see if the fuser warmed up at all. Open the side door and gently feel the fuser frame to see if it is warm at all. Do not touch the Fuser roll; it is hot even to the slightest touch.
If it is not hot, make sure all the plugs were correctly plugged into the power supply.
On this problem there can be other factors that can cause warming up.
First, the fuser assembly may be defective and needs replacement.
Second the main board may be gone out.
And last if the machine has memory chips in the back, unplug the machine, remove the small cover from the back and unplug the simms chips and reseat them. Plug in the machine, then power it on.
See if the machine will go to a ready.
If not, possibly the fuser, or main board, or both. If the main board or(and) the fuser assembly is replaced,
MAKE SURE THE CORRECT PART IS INSTALLED IN THE MACHINE.
If all else fails, Place a Xerox Service Call on the machine before it gets too expensive in troubleshooting the problem with purchased parts.
Oct 22, 2009 | Xerox WorkCentre M20i All-In-One Laser...
E-5 error code
E5 code refer to fuser unit.To dfisplay both digits press the Enter.
E 52 Fusing error 1 Defective thermistor,heater lamp open,defective main or ac/dc drive board.
E 53 Fusing error 2 thermistor in shortcircuit,fusing harness shorted or ac/dc power supply board defective.
E 54 fusing error 3 main board or ac/dc board defective.
E 55 Fusing error 4 rhermistor open,defective main board or fusing lamp open.
When E5 service call condition occur for safety reasons they cannot be cleared by turn OFF/ON the power switch.After repairing the copier turn ON the main switch.Enter in the SP mode and press 97.Turn the main switch OFF wait 10 sec and turn ON.
Oct 07, 2009 | Ricoh FT5832 Copier
False door open reading on my aficio 350
Check the fuse FU1 y FU2 in the power supply board FU1 display open door Without saying as.
Aug 10, 2009 | Ricoh Aficio 450 Copier
Sc code 547 power supply failure
The SP547 code is a fuser code and has to be reset in the service mode, it will not go away by turning the machine off and on. Check The lamp connections and trermistor connections .
Jun 02, 2009 | Ricoh Aficio 1035 Copier
Xerox F12 will not power up
There is a fuse in the power supply, That is located under the paper catch tray.Just look to the right of the on off switch, You will see 2 silver phillips screws in that cover. Remove those and pop the cover off, it will POP, there is a tab holding it in place, so it will have alittle resistance in removing it.
You also will have to remove 3 screws on the power supply shield to access the power supply. some have 1 some have 2 fuses. If the supply is bad. Google a business called " the parts drop". Give Britt a call, he is very good to deal with and will have that part.
Mar 25, 2009 | Xerox FaxCentre F12 Laser Printer
Minolta CSPRO EP2030
You Can make reset for this code by: 1. Open the front door of the machine & lift the upper half 2. Turn the machine on 3. Locate the srvice switch on the main board( backside of the machine you can reach even without opening the back cover) 4. If this code is coming from time to time just change the upper heater roller
Oct 05, 2007 | Office Equipment & Supplies
Canon imageRUNNER C3220 Color Copier Logo
49 people viewed this question
old marine
old marine
