Question about Whirlpool Duet GHW9150P Front Load Washer
My washer is only 4 months old. It was working fine and now it keeps stopping at the wash cycle- It fills up okay and then it gets stuck at the wash cycle....it keeps beeping and the wash light is blinking. It won't stop until I hit the power button-then it drains and shuts off. i start it again and it runs fine the second time around???
    President:
  • 1,218 Answers
Good day,
Knowing the problem would be nice, but if it's under one year of age, it is under factory warranty.
I wouldn't worry about it. Just call your selling dealer for a warranty repair. It should be totally free to you.
Posted on Nov 13, 2010
After working well for six months, my washer now expels water at random points during the wash and rinse cycles.
Check inside the fill hose for debris. There is a screen designed to block debris from getting inside the machine valve. If the screen builds up with debris the water slows down. Sounds like the water is filling too slow. Also the unit and/or the load may not be balanced causing it to stop and drain out. If it's okay then see what lights are blinking when these events occur and post here.
Jun 06, 2013 | Haier HLP21E Top Load Washer
Washer seems to cycle fine but the water will over fill
Hello, fill the washing machine with water and when the water is about 1/2 full of water,unplug the washers power cord from the wall outlet.if the water keeps flowing into the washing machine with the power cord pulled the "fill valve"(where the hot and cold hoses are attached to the washer) has mechanically stuck open and will have to be replaced. if the water shuts off when you remove it's power cord from the wall outlet,try plugging the washer in and out a couple more times and if the water stops each time the fill valve indicates as being good.
Thanks
May 21, 2010 | Washing Machines
Washer is getting stuck at rinse cycle-
sorry to keep asking questions but i just need to know a little more information. are you using auto fill? have you tried manual water level settings? is your machine the one with the LCD DISPLAY?when it stops at rinse, is it agitating? if you have the LCD display have you tried the- traditional wash mode? please reply 4 further help.
May 21, 2010 | Fisher and Paykel GWL11 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Maytag s1000 stacked washer will not start water fill and cycles.
could be wash spin relay stuck in spin must be 15 years old
Feb 19, 2009 | Maytag LSE7806A Top Load Stacked...
Estate washer, new, water will not stop, overflowing
you need to replace the inlet valve something is stuck in the valve not allowing it to shut.
Dec 23, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Maytag washer lse7804a won't fill
with the timer in the wash position on any cycle do you have 120 volts on the selenoids that the water hoses are connected to with the temp selector set for warm wash and timer knob pulled out? if you do then the water inlet valve is the issue, if no voltage you could have gotten a defective timer
Apr 10, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag Washer Getting stuckon wash cycle
the possibility of it being the timer is most likely..as the rest of the cycles remain ok.. if you require a timer,you can get one here at this link..(click the link here) http://www.easyapplianceparts.com/AdvancedModelSearch.aspx?ModelNum=HAV4657EWW&mfgModelNum=&fkMfgID=1
please be aware that you will need the machine serial number in order for them to issue you with the correct part/s you will require.. parts are cross referenced with the serial number.
these diagrams will also enlarge in order for you to maintain your machine by yourself at little but the cost of the parts required... but please DO NOT ATTEMPT ANY REPAIR YOURSELF if you think you may not have the technical know how to follow these technical drawings..hope this helps
Nov 06, 2007 | Maytag MAT13MN Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
135 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
