Question about InFocus ScreenPlay 61" Rear Projection HDTV
When i am in advanced settings and go to mirror adjust my adjustment will go vertical but not horizontal can this be fixed thanks
  • 1 more comment
  • Giovanni Latona
    Giovanni Latona Nov 14, 2010
    he was helpful but i need more info thanks
  • Giovanni Latona
    Giovanni Latona Nov 16, 2010
    the picture is 2 inches to the left and i cant center it on the screen
  • Giovanni Latona
    Giovanni Latona Nov 21, 2010
    thanks
  • 12,061 Answers
Https://portal.infocus.com/.../infocus_SP50MD10_SP61MD10_referenceguide_en.pdf
www.aboutprojectors.com/.../infocus-screenplay-7200-manual.pdf
I think that this is the only way it works?
Unless you are experiencing some?, any? other difficulties then perhaps it is best left alone?
I am at a bit of a loss to see what's wrong? apart from that i mean? Have you a picture, sound etc?
Above i include links to reference manual and the user manual for your convenience.
Posted on Nov 15, 2010
  • 1,212 Answers
I have not repaired this particular TV. The cause may be similar to those I have repaired. I would suggest that you replace the convergence ICs., and any low ohm, low wattage resistors, near the convergence ICs. See if website www.TvRepairKits.com has a kit at repair your model of TV. Yes this can be repaired and it seems to be the obvious! Thanks for asking.
Posted on Nov 14, 2010
  • matt martin
    matt martin Nov 14, 2010
    I'm sorry, I believe I may have given you a wrong soltion. This TV is a DLP, and I have not been real interested in repairing these. They seem to have many many problems after the fix. Once again I apologize for wrong information. Please consider another answer! Thanks for asking though!
Wing mirrors will not adjust
Wing mirrors have a certain range of electrical adjustment. Manual adjustment by pushing with fingers can make electrical adjustment inoperative. The solution is to make finger adjustment to get back to the electrical range.
May 22, 2016 | Cars & Trucks
Tip
How to set convergence on Projection TV ' s
I have given an general explanation on most projection TV ' s
  1. Enter the menu on your TV. Use the remote control and bring up the menu.
  2. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  3. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  4. Press "Enter." A crosshair pattern will appear on your screen.
  5. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  6. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  7. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  8. Repeat these steps for all colors.
on Mar 18, 2010 | Televison & Video
Memory seats adjust on there own as well as mirrors
BCM has nothing to do with this function , MMM - memory mirror module !
Memory Mirror System Operation
The MMM is capable of storing mirror position for 2 different drivers. Mirror position is determined by both horizontal and vertical position sensors in each of the power mirrors. The MMM supplies a reference voltage and a low reference to these sensors and determines mirror position through the horizontal and vertical position signal circuits.
The MMM receives power through the battery supply voltage circuit and the MIR/LOCK fuse and a constant ground source. Any time that battery voltage is disconnected and then connected from the MMM, the MMM will enter the mirror relearn mode. The mirror relearn mode can also be commanded using a scan tool. Refer to Memory Mirror Module Learn for further information.The memory switch receives power through the battery supply voltage circuit and the MIR/LOCK fuse. The MMM upon receipt of a memory switch signal input, a class 2 message from the SIC or a class 2 message from the PCM indicating that the transmission is in park, will then supply battery voltage and ground to the appropriate power mirror motors through the mirror motor control circuits to move the mirrors to the predetermined positions.
DTC B1586, B1596, B1616, or B1626
The mirror horizontal and vertical position sensors are potentiometers. The Memory Mirror Module (MMM) provides these sensors with a 5 volt reference circuit and a low reference circuit. The MMM monitors the horizontal and vertical position sensor signal circuits which change values based on mirror position. These voltage values are used to determine mirror position and can be set into memory. When the MMM receives a memory recall request, the MMM will control the power mirror to the memory position based on the horizontal and vertical position sensor signal values.
Install a scan tool.
Turn ON the ignition, with the engine OFF.
With the scan tool, observe the mirror horizontal and vertical position parameters in the Memory Mirror Module (MMM) data list.
Operate both the left and right mirrors through the full range of movements.
Does the scan tool indicate that the left and right mirror horizontal and vertical position parameters are within the specified range?
Memory Seat System Components
The memory seat system consists of the following components:
• Power seat switch assembly
• Memory recall switch assembly
• Horizontal adjuster motor
• Front vertical adjuster motor
• Rear vertical adjuster motor
• Recline adjuster motor
• Memory seat module
• Memory mirror module
• SEAT 25A circuit breaker
• MIR/LOCK 3A fuse
Your best bet , take it to a qualified repair shop !
May 23, 2017 | 2002 Cadillac Escalade
Which service manual setting controls horizontal size?
You're discussing about the factory mode adjustments. The horizontal width adjustments will not be there. You have to adjust it by replacing certain capacitors at the horizontal output stage.
May 18, 2013 | Panasonic CT-20G6 20" TV
Camera reverse
There should be a tool in your camera settings to flip the image vertically or horizontally.
Tools ; Web Camera Settings ; Advanced ; Advanced
where there is a section called Image Mirror. Here I can specify if I want to flip the image vertically or horizontally.
Aug 18, 2012 | ASUS K40IN Notebook
My picture is doubled on my toshiba TN50V71 as if there is a shadow behind everything? Please help!
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
    good luck!
  • Feb 02, 2011 | Toshiba TN50V71 50" Rear Projection...
    It has tripple vision and looks like a bow tie.
  • good luck!
    Feb 02, 2011 | RCA HD61W66 61" Projection HDTV
    How do you set convergence
    What is your Make and Model number?
    Adjusting vertical and horizontal
    There is no adjustments on this model if horz is off i suspect a bad capacitor in around the verticle ic.
    I fix a lot of these tv at my shop. cost is around 120.00 at our place.
    I hope this helps thanks DOCTOR VIDEO
    Apr 27, 2008 | RCA 32V550T 32" TV
    InFocus ScreenPlay 61" Rear Projection HDTV Logo
    290 people viewed this question
    Top InFocus Televison & Video Experts
    Donni Steen
    Clive
    Clive
    Are you an InFocus Televison and Video Expert? Answer questions, earn points and help others
