Question about NEC Televison & Video
My remote doesn't work I have changed batteries, checked the ir settings set the id number to all, can't get it to work
    Problem Solver:
  • 15 Answers
You need to get a replacement one. that is the only way it will work.
Posted on Nov 13, 2010
When i change the batteries the remote control KFR09 Soleus Air P-05-ID-Remote Control KFR-09GW
After battery change, it should be set up with set-up codes to your device again. Programming [set-up] procedure is too much to type in here by this window, and is not practical. If you wish to get details; check the site linked here. It have set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Jun 02, 2014 | Soleus Air P-KFR09-05-ID Remote Control...
RCA flatscreen remote doesn't work
\its most likely the ir sensor which has the issue. I will need the model number of your set to help you further on the issue. You can reply to this same post for further assistance if needed.
Jan 01, 2013 | Televison & Video
The TV stopped responding to the remote control
tried with reset doesn't work, ok it could be the IR sensor at the front panel of the tv doesn't work. but before you replace it you need to ensure if your remote controller is working. have you tried to check the remote with camera trick just to know if the remote controller is sending light to the IR sensor of the tv.
Sep 23, 2012 | Advent LC-20H15A 20 in. EDTV-Ready LCD TV
Sharp GA219SA doesn't work
If the remote works for sometime once the battery is put into , it means that the circuit is erratic as the frency seems to change from the set value. This can be a fault in the processor IC in the remote, a fault in the crystal or associated capacitors. Check also the IR driver transistor which can be leaking and so changes the output.
Oct 24, 2011 | Sharp GA219SA Remote Control
My Sony Bravia doesnt work with remote control, with any remote including universals
You didn't include the Sony Bravia model that you own - so I can't be more specific. If the TV is set up to use RF (radio frequency) codes instead of IR (infrared) codes; the universal types probably will not work. This is because most universal remotes are the IR type.
The remote included with your TV may have inadvertently be switched to send the codes as an IR type while the TV will respond only to RF type codes. It may also be that the TV was changed to respond to RF codes only. Either way, check your manual (or your TV menu settings) to see how to set the TV and the remote to work in the same mode.
If you can't find your manual, reply with your TV's model number - and if possible the remote's model number, too. I'll see what I can find that is specific to your TV.
I hope this helps & good luck. Please rate my reply. Thank you.
Apr 06, 2011 | Televison & Video
Remote control don't work with receiver
Hold the remote in front of a cell phone or camera any push buttons on remote . you should see the IR diode illuminate white in the camera display. if not the remote is not working. check the obvious. Batteries, contact in batt compartment. if you see illumination check in the menu. you can operate this unit with 2 different remotes. there is AV1 and AV2.You can also do a factory reset but all your settings will go back to original configuration. With the set on hold down VIDEO and CD buttons and Press POWER. "FACTORY" will appear on the display. Next if still no reult check the IR reciever ic on the front board. 3 pins 1 will have constant 5 volts even when turned off. When you press a button on the remote you will see voltage changes on one of the other pis. With a scope you can see the data. The other pin is ground. The part number and location is IC101 part 3 8-759-332-18.
Mar 25, 2010 | Sony STR-DE545 Receiver
TV won't take remote control commands
I have the same issue. Obvious thing is to install new batteries. I assume you have done this already. Have you tried using the buttons on the bottom of the monitor to scroll through the main menu using the volume buttons to option 3, and scroll down to IR remote to see if it is selected ON. If it is OFF, select ON with the bottom LEFT or RIGHT buttons.If your remote still does not work, you can try to work it by connecting a 1/8" stereo mini-plug cable into the front end of the remote and the other end to the monitor remote control jack(second from bottom on back panel). Check the IR Remote settings this way. If it still does not work then you have the exact same problem I have... IR and Wired remote inoperative. I am still hoping for a solution but I am afraid there is either a stuck bit in the IR remote circuit or a bad board/chip. Anyone have a solution to this??
OPTION3
KEY LOCK OFF←→ON
IR REMOTE OFF←→ON
LOOP OUT OFF←→ON
ID NUMBER ALL←→1←…→256
Nov 08, 2009 | Pioneer PureVision PDP-424MV 42 in. Plasma...
Remote stop working
You should verify if the remote has failed. Contact the support for Vizio, or ask your dealer where you can buy original replacement accessories.
Visio Tech Support:
http://www.vizio.com/support.aspx?id=1586
Most of the time, we've seen the remote fail. Sometimes we are able to service the remote. Sometimes, the IR LED and or the crystal fails in the remotes. If it is more than this, it is impossible to have internal service parts for most remotes. It takes service experience to be able to change these parts.
On rare occasions the IR remote sensor and remote processor area in the set can have a failure. It is best to try another remote to verify this before sending the set for service.
The most common causes of failure of a remote controller is dropping, rough handling, getting food and drink inside, or putting the batteries in backwards.
Jerry G.
Apr 25, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Toshiba TV Remote Control not working
REPLACE IR SENSOR INSIDE THE SET COMMON PROBLEM
Apr 11, 2009 | Toshiba 36AF42 36" TV
Televison & Video Logo
70 people viewed this question
Top NEC Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
