Question about Estes Space Ship One Rocket
Engine will not ignite. - Estes Space Ship One Rocket
  • 1,498 Answers
Hi Jer,
If the igniters are not firing, it's a power problem.
If the igniters are firing and the engines are not igniting, there are a few things to check a well as minor alterations in procedure to try.
Remember: Safety first. Allow cool of time between tests.
  • Double check power from what ever your source is
  • Be sure the igniter is fully inserted into the nozzle.
  • Tape the igniter to the engine to ensure the flash is directed toward the propellant.
  • Switch engines - use a different one
  • Make sure the igniters work on their own without the engin - saves time between tests
  • Try a different style igniter. Century's version is very reliable and is available at Toy and hobby shops.
Good luck
Mike
Posted on Nov 13, 2010
Error Code P0351 for a 2005 Toyota Avalon
Possible causes
Faulty Ignition Coil 1
Ignition Coil 1 harness is open or shorted
Ignition Coil 1 circuit poor electrical connection
Faulty Engine Control Module (ECM)
What does this mean? When is the code detected? Each ignition circuit is continuously monitored by the Engine Control Module (ECM). The test fails when the ECM does not receive a valid pulse signal from the ignition coil. Possible symptoms Engine Light ON (or Service Engine Soon Warning Light) Lack/Loss of Power Engine may be harder to start Engine hesitation Rough engine idle P0351 TOYOTA Description: The ignition system on the vehicle uses individual ignition coils for each cylinder. The Engine Control Module (ECM) controls each ignition coil operation. The ECM sends a ON/OFF signal to energize the ignition coil to create a spark at the spark plug when a spark is required at the cylinder.
May 29, 2017 | Toyota Cars & Trucks
What is the PO320 code? what is wrong with my 2005 Hyundai xg350L?
P0320 Hyundai Ignition/Distributor Engine Speed Input Circuit Possible causes
- Faulty Ignition/Distributor engine speed sensor
- Faulty Crankshaft Position sensor
- Ignition/Distributor engine speed sensor harness is open or shorted
- Ignition/Distributor engine speed sensor circuit poor electrical connection
- Low battery charge
- Faulty Engine Control Module (ECM)
What about the obd code?
The P0320 Hyundai code is triggered when the Engine Control Module (ECM) detects that there is no current at the ignition coil group
Symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Lack/Loss of Power
- The engine may be harder to start
- The engine may stumble or stall
P0320 Hyundai Description
Ignition failure sensor is used to check whether the spark ignition is occurred correctly or not and also used to tachometer drive. The sensor monitors the voltage difference between a resistance which is on the battery circuit for ignition coil. When the ignition coil works properly, the electric current through the resistance is detected as voltage drop. This is confirmed for every ignition event with the crankshaft sensor and the camshaft sensor. If ECM detects a malfunction, no ignition is possible, so the engine would not start. If there is no ignition signal for a predetermined cycle for one or two ignition coils, an ignition coil circuit failure exists.
Nov 17, 2014 | Hyundai Motor 2005 XG350
P0320 code
P0320 KIA - Ignition/Distributor Engine Speed Input Circuit
Possible causes - Faulty Ignition/Distributor engine speed sensor
Apr 10, 2014 | 2004 Kia Optima
Wat does code po320 means f150 2002
Here is the general definition.
P0320 FORD Description Ignition failure sensor is used to check whether the spark ignition is occurred correctly or not and also used to tachometer drive. The sensor monitors the voltage difference between a resistance which is on the battery circuit for ignition coil. When the ignition coil works properly, the electric current through the resistance is detected as voltage drop. This is confirmed for every ignition event with the crankshaft sensor and the camshaft sensor. If Engine Control Module (ECM) detects a malfunction, no ignition is possible, so the engine would not start. If there is no ignition signal for a predetermined cycle for one or two ignition coils, an ignition coil circuit failure exists.
Read more: http://engine-codes.com/p0320_ford.html#ixzz2Lw6dG98q
Feb 25, 2013 | Cars & Trucks
98 mercury villager no start , code P 1320
Here is the entire description for the code -
When is the code detected?When the ignition signal in the primary circuit is not sent to Engine Control Module (ECM) during engine cranking or running.
Symptoms- Engine Light ON (or Service Engine Soon Warning Light)
P1320 NISSAN Description The ignition signal from the Engine Control Module (ECM) is sent to and amplified by the power transistor. The power transistor turns on and off the ignition coil primary circuit. This on-off operation induces the proper high voltage in the coil secondary circuit
Possible causes - Faulty power transistor unit built into ignition coil
- Ignition primary circuit is open or shorted (circuit to ignition coils)
- Ignition primary circuit poor electrical connection (circuit to ignition coils)
- Faulty ignition system condenser
- Crankshaft position sensor circuit
help.png Help with this Tech notes The most common cause that will trigger the P1320 code is the ignition coils, one or more ignition coils may have failed. Even tough the coils may be working OK, the resistance for one or more of the coils is greater or smaller that what the Engine Control Module (ECM) is expecting. Measuring the resistance with the coil out of the vehicle may not show any failures, usually the coil fails under heavy conditions (hard acceleration) or certain temperatures.
The P1320 code means that there is problem with the "Ignition Coil" or the wire to the ignition coil. For some models without individual ignition coils the Ignition Coil is inside the distributor and the distributor need to be replaced to fix the problem.
Read more: http://engine-codes.com/p1320_nissan.html#ixzz2EJsrz4BZ
Read more: http://engine-codes.com/p1320_nissan.html#ixzz2EJsktmXX
Dec 06, 2012 | Cars & Trucks
I cannot find my ignition module
Your ignition control module is under the coil packs on the motor.
Jan 05, 2011 | 1991 Chevrolet Lumina
How do Iknow fireing order on ignition coils?Idon't know coil order
Here ya go...found the block for the reply....
3.8L engine Firing order: 1-2-3-4-5-6 Distributorless Ignition System
Sep 13, 2010 | 1994 Buick Regal Gran Sport
Coil firing oreder for a 2004 pontiac grand prix II V-6
Several VIN engine there, check this diagrams...
Fig. 3.1L Engine Firing order: 1-2-3-4-5-6 Distributorless ignition system
Fig. 3.4L Engine Firing order: 1-2-3-4-5-6 Distributorless ignition system
Fig. 3.8L (VIN 1) Engine Firing order: 1-6-5-4-3-2 Distributorless ignition system
Fig. 3.8L (VIN K) Engine Firing order: 1-6-5-4-3-2 Distributorless ignition system
Hope helps (remember rated this).
Jul 07, 2010 | 2004 Pontiac Grand Prix
Ignition firing order and cable position at the coils
The 3.5L (VIN H) engine's unique ignition system has the ignition coils directly over each plug. No spark plug wires are used.
3.5L (VIN H) engine Firing order: 1-2-3-4-5-6 Distributorless Ignition System
The firing order for the 3.1L VIN M, 3.4L VIN E, 3.4L VIN X and 3.5L VIN H engines is 1-2-3-4-5-6. The right bank cylinders are on the cowl side (rear) of the engine compartment and are numbered 1,3,5, left bank cylinders on the front side of the vehicle, are numbered 2,4,6.
3.1L (VIN M) engine Firing order: 1-2-3-4-5-6 Distributorless Ignition System
3.4L (VIN X) engine Firing order: 1-2-3-4-5-6 Distributorless Ignition System
3.4L (VIN E) engine Firing order: 1-2-3-4-5-6 Distributorless Ignition System
The firing order for the 3.8L VIN K and 3.8L VIN 1 engines is 1-6-5-4-3-2. Starting at the front of the engine, cylinders in the left bank are numbered 1,3,5 and cylinders in the right bank are numbered 2,4,6.
3.8L (VIN 1) engine Firing order: 1-6-5-4-3-2 Distributorless Ignition System
3.8L (VIN K) engine Firing order: 1-6-5-4-3-2 Distributorless Ignition System
I hope help you with this, remember rated this help. Good luck.
Sep 01, 2009 | 1999 Chevrolet Lumina
How do i put a coil in a 2001 jaguar s type
303-07A: Engine Ignition — 3.0L (4V) 2001 Lincoln LS Workshop Manual DESCRIPTION AND OPERATION Engine Ignition The electronic ignition (EI) system is a coil-on-plug (COP) ignition system.
SECTION 303-07B: Engine Ignition — 3.9L 2001 Lincoln LS Workshop Manual
v-8
REMOVAL AND INSTALLATION Ignition Coil Removal
  1. Remove the air cleaner outlet tube. For additional information, refer to Section 303-12 .
  1. Remove the bolts and the ignition coil cover.
  1. Disconnect the electrical connector from each ignition coil.
  1. Remove the ignition coils.
    1. Remove the bolts.
v-6
SECTION 303-07A: Engine Ignition — 3.0L (4V) 2001 Lincoln LS Workshop Manual
  1. Remove the engine appearance cover.
  1. To access the RH bank ignition coils, remove the upper intake manifold. For additional information, refer to Section 303-01A .
  1. Disconnect the electrical connector from the ignition coils.
please rate as fixed if this helps.
Apr 28, 2009 | 2001 Jaguar S-Type
Estes Space Ship One Rocket Logo
76 people viewed this question
Top Estes Toys Experts
ray gallant
Are you an Estes Toy Expert? Answer questions, earn points and help others
