Question about Pioneer VSX-915 Receiver
Pioneer VSX 915 powe off
Dear sir,
I purchased a receiver and it was working fine until a power surge yesterday now I have a blue LED flikkering on the power button you can press power but system does not come on. It seems as if it went into protection mode, How do I reset this please.
Koos Reots,
South Africa
  • zxmb Dec 30, 2008
    same, water came into the unit'
  • Anonymous Mar 31, 2009
    la led bleu clignote
Had a power surge last night and got the same problem. Unit wont power on and has a blinking blue light on standby button. I found the solution from the service manual for a similar model.
Hold down ENTER and ADVANCED SURROUND buttons.
This resets the DC overvoltage sensor and bingo the unit comes back to life again.
Posted on Feb 05, 2009
  • cheesemethod Dec 19, 2010
    WOW! Huge thanks, was about to buy a new receiver after a tropical Brisbane storm the other night. Turned on like magic.
Pioneer manual repair
You have probably blown an internal fuse.
You may find more information here:
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/218219098VSX815OperatingInstructions.pdf
If you are inexperienced in electronics repair,
you should take your unit to the nearest Pioneer service center.
Jul 21, 2014 | Pioneer VSX-815-K Receiver
Pioneer vsx 915 blue light flashing
Time for a repair shop to look, clearly the amp is down, it has failed. Have a qualified tech look at and get a repair estimate.
Dec 15, 2012 | Pioneer VSX-915 Receiver
My Pioneer VSX-D902S receiver will not turn on.
the receiver pioneer vsx - d902s has in the display lights are LED. ? and that screen will wear over time and stop working .. ? like the large volume potentiometer . ?I have wanted to purchase the sony receiver str.dh130 to renew the pioneer..que reviewers. ? although it is 100 watts and 125 watts pioneer
Aug 14, 2011 | Audio Players & Recorders
Pioneer vsx-01 receiver, standby light burned out. Button works fine, just no blue light. Pioneer sells a replacement standby button......is this easy to install and will it solve the problem? Do you have...
the light is an ledt they very rarely go bad ..to confirm its bad you must first see that the led is getting power --a voltmeter one end to the frame of the unit and the other to either lead on the led will confirm if its bad or not a typical led will run on or near 3 volts dc... if theres no power at the led than the problem is elsewhere
Aug 30, 2010 | Pioneer Elite® VSX-01TXH 7.1 Channels...
Pioneer Elite vsx-27tx receiver with no bass!?
There may be a subwoofer mute function on your amp. The sub out is nothing more than a preamp output with a low frequency response. It is meant to be amplified by an external amp. Either check your powered subwoofer for operation or look through your operators manual for a sub mute function.
Feb 11, 2010 | Pioneer VSX-27TX Receiver
Pioneer power LED is Blinking
If that didn't work, with the power off try holding Tune + and Auto surround/stream direct buttons for a few seconds to reset the protection circuits. Make sure to keep 8" of empty space above the unit for air, as overheating can cause this problem. If it fails again, there could be bigger problems, so get it checked
Mar 29, 2009 | Pioneer VSX-918V Receiver
Blinking Standby Light on receiver, no power
Unplug from power socket for few hours,most likely had a surge from storm and destroyed,either way will need to be serviced to evaluate damage if power trick does not work
Jan 05, 2009 | Pioneer VSX-915-K 7.1 Channels Receiver
Problem with pioneer vsx-916 av receiver
Be sure you have proper impedance with both sets connected. Some units have a selector switch in the back of the receiver to set the proper bias. ...accordianman
Jan 21, 2008 | Pioneer VSX-915 Receiver
Pioneer vsx-d307
You have a flashing "mute" on the display?...accordianman
Oct 04, 2007 | Pioneer VSX-D307 Receiver
Pioneer VSX-915 Receiver Logo
837 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
