Question about Estes Toys
I can't seem to get the engine to ignite. I have gone through all of the coils. I have pushed them all the way in with no luck. Is there another way to ignite the engine. I cant tell you what a disappointment it has been to do the work assembling it to not get it to launch.
  • jerhangsit Nov 13, 2010
    Thanks Mike,
    I will look for a new power source. when i tested the ignition coil, without it being in the engine, the tip got hot enough to wrinkle plastic but i could hold it in my hand.
    with the right amount of power will it get bright like a bulb filament?
  • 1,498 Answers
Hi again Jer,
If the igniters are not firing, it's a power problem.
If the igniters are firing and the engines are not igniting, there are a few things to check a well as minor alterations in procedure to try.
Remember: Safety first. Allow cool of time between tests.
  • Double check power from what ever your source is
  • Be sure the igniter is fully inserted into the nozzle.
  • Tape the igniter to the engine to ensure the flash is directed toward the propellant.
  • Switch engines - use a different one
  • Make sure the igniters work on their own without the engin - saves time between tests
  • Try a different style igniter. Century's version is very reliable and is available at Toy and hobby shops.
Good luck
Mike
Posted on Nov 13, 2010
  • Justin Case
    Justin Case Nov 14, 2010
    Absolutely. The filament analogy is perfect. A filament without the vacuum afforded by the bulb would flash brightly and incinerate itself. Not good for a bulb, nut perfect as an ignition source. The nichrome wire they use has a very high resistance, so it gets very hot like a filament.
    For it to work, it should be getting White Hot so fast it practically bursts into sparks of molten metal.
    If you can hold it in your hand........well
    After my first power related embarrassment at a launching, I upgraded to motorcycle batteries, they're easy to carry and talk about response time, press the button, gone. Instantaneous gratification. Just a thought.
    Have fun
    Mike
Sometimes this problem is because the igniter is not actually touching the propellent. If taping the igniter does not solve the problem you can add a minute amount of flammable liquid to the propellent hole where the igiter is inserted. For example, take 6 inches of kite string and dip the first inch into some gasoline. Hold the string over the propellent hole and squeeze the string from top to bottom using your other index finger and thumb. Once 2 or 3 drops of gasoline have fallen into the hole insert the igniter & plug.
Posted on Jan 03, 2012
There is no current on the coils. it's been working fine but one tmne it started back firing. i have new sparkplugs but it would'nt still start
Hi Anonymous, and the usual suspects are:
1. Fuel tank empty
2. Fuel supply valve turned off.
3. Fouled spark plugs.
4. Engine flooded with gasoline as a result of over use of enrichner.
5. Fuel valve or filter clogged.
6. Vacuum hose to automatic fuel supply valve disconnected, leaking, or pinched.
7. Discharged battery, loose or broken battery connections.
8. Loose wire connection at coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, spark plug cable connections loose,
or cables connected to wrong cylinders.
10. Ignition timing incorrect due to faulty ignition coil, ignition module, or sensors " Manifold Absolute Pressure" "Camshaft Position Sensor" "Crank Position Sensor" "Brake Apply Sensor
11. Engine lubricant to heavy ( winter operation )
12. Sticking or damaged valves or push rod wrong length.
13. Primary cam sproket spline sheared or missing spacer.
For a primary suspect please visit the website below:
Good luck
Harley Davidson Sportster error codes and how to access them
Feb 05, 2014 | Harley Davidson XL Sportster 883...
1996 Audi A4 2.6E - Not idling properly.
The ignition coils on your Audi A4 are what provide the spark to the spark plugs, which sit underneath each coil. Every cylinder in your A4's engine has a spark plug and an ignition coil assigned to it. Sometimes, the ignition coils can fail and require replacement. Typical symptoms of a failed ignition coil include a flashing "Check engine" light, a rough idle or hesitant acceleration. Replacing the ignition coils on your A4 is a quick procedure that takes just a few minutes.
Instructions
    • 1
      Park your Audi A4 on a level surface and open the hood.
    • 2
      Remove the plastic rivets that secure the plastic engine cover to your engine with the flathead screwdriver. Depending on your engine, there may be either three or four plastic rivets, which are all very obviously placed. Set the engine cover aside.
      • 3
        Firmly pull the ignition coil you need to replace up from the engine. Since it does attach to the spark plug, you will need to apply a little force. Be sure to pull directly up so that you do not bend the metal rods at the bottom of the ignition coil.
      • 4
        Unplug the ignition coil from its wiring harness. Depending on your engine, you may need to use a flathead screwdriver to pry up the loosening latch on the wiring harness.
      • 5
        Insert the replacement ignition coil into the spark plug cylinder and push directly down until you hear a slight popping noise, which will indicate that it has been installed correctly.
      • 6
        Replace the plastic engine cover and secure it with the flathead screwdriver and the plastic rivets to complete the procedure.
    Sep 05, 2012 | 1996 Audi A4
    My 2005 Dodge stratus will not crank. It was sputtering this morning when cranked, and the engine liht was on. I took to advance auto to put on tester. They told me the heating coil or the plugs. I buy...
    Well, let see, see if you hear fuel pump hissing or a click once you turn your key to the "on" postion. If so, then fuel pump is building pressure and is working, if not then fuel pump is the promblem and please check your fuel pump relay before actually considering fuel pump failure, secondly could be your ignition coil that's gone bad, I don't really know how to test this, but heard you can pull the spark plug out while still instact with the spark plug wire, position it about 1" away from a ground unit, such as your engine valve cover which is the metal part, or ground to see if there is a spark.... this is only on older model when the ignition coil is relayed within the distruburator. However seems by what advance auto diagnostic, seems like it the ignition coil that gone bad and needs to be replaces.
    Jan 22, 2011 | 2005 Dodge Stratus
    Engine won't crank or seem to get power on key turn.
    More than likely, your starter has gone out. If the battery is fully charged and its not even turning over, that is what i would start with.
    Jun 17, 2009 | 2003 Ford Focus
    1987 GMC S-15 2.8L engine will not fire on any cylinder.
    Follow this link
    It shows the step by step troubleshoting of non-starting engine
    Good Luck
    http://www.nls.net/mp/volks/htm/eng_strt.htm
    Jan 09, 2009 | 1987 GMC VanDura
    Ignition coil
    Hi,yes coils tend to heat up and cause the car to die ,your diagnostic seems accurate .!good luck.......
    Aug 19, 2008 | 2002 Daewoo Lanos
    Toys Logo
    140 people viewed this question
    Top Estes Toys Experts
    Andrew Taylor
    Andrew Taylor
    Are you an Estes Toy Expert? Answer questions, earn points and help others
