Question about Whirlpool 24 in. DU1100XTP Built-in Dishwasher
My washer will not rinse all the way. It leaves a soap residue on the dishes. Is there a filter or something that needsto be changed
  • Whirlpool Master
  • 43,501 Answers
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
'll;
Posted on Mar 04, 2011
My Samsung model #WA4H7000AW/A2 seems to always need an additional rinse to get rid of soap left behind. Is this a common complaint ?
Here are some questions that may help.
1) Is the water hot enough? Since the soap "melts" better at higher temperatures, cooler water can leave a soap film.
2) Are the dishes clean before you run the machine? We like to used the dishwasher to "sanitize" the dishes, so we rinse them really good before washing them, to get off caked food residue.
3) Try changing washer soap, try powder if you used liquid, or visa-versa, and try less quantity and see if any of those help.
God bless your efforts.
Dec 19, 2016 | Samsung Washing Machines
My dishwasher isnt rinsing the dishes, leaving soap on dishes. Also doesnt seen to be draining well, leaving scum on the filter on the bottom. Tried a dishwasher cleaning agent and have tried CLR. I didnt...
The problem is most likely that there is still water residue at the bottom of your machine. If the machine is not fully drained it picks up some of the residue and sprays that onto the dishes during the final rinse, leaving an unhealthy and unsightly film on everything.
Remove the bottom strainers plates and make sure that the outlet pipe is not kinked, that there is nothing obstructing the pipe or the pump or selector valve. If possible back flush through the outlet pipe and try draining the machine once more before using it again.
Jul 25, 2011 | Dishwashers
Dishwasher is going on 3.5 yrs old, it worked well for the 1st year but for the last year & half it has been leaving gritty residue on all the dishes. To the point, dishes are being hand washed to...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
DishwasherResidue and Film on Dishes
heatman101//
Mar 22, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
Leaving a white residue on dishes after its full cycle. Have tried different soaps,rinsing agents, and ran it through a cycle with a cup vinegar in it.Is there something I can do to repair this problem ?...
As you have already done the vinegar cycle and all now it must an technical reason.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter.
Mar 17, 2011 | Frigidaire Dishwashers
Dishwasher leaves baked on soap scum on al dishes and everything ....even on the dishwasher ...tried all kinds of soap and rinse aid...nothing works...cleaned entire washer out cleaned all filters...
I imagine you've already checked that you're using the correct amount of detergent for the wash programme, and that you're washing the correct quantity of dishes for the wash programme, though if not, try that first!
Is the dishwasher heating the water to the correct temperature? If it's not rinsing at a hot enough temperature, the detergent may leave a residue. In that case, your dishes would probably also be less than entirely clean; they could be slightly greasy when removed from the machine.
Another possibility is that insufficient water is supplied to the dishwasher, so it might be worth checking the tap that lets water through the hose and into the machine. Does the tap turn on fully? Does it turn off properly?
The other thing that might be worth trying is an empty wash: put the machine through a wash programme WITH detergent but WITHOUT dishes, at the programme with the highest temperature. Is all the soap scum washed away? Or is there still a residue inside the machine? If the empty wash works, you probably need to give your machine a maintenance wash once a month or so. This is often the case if you usually wash your dishes a few at a time on a short programme.
I hope some of that helps. Good luck!
Oct 09, 2010 | Bosch Dishwashers
My new dishwasher leaves a white residue on my pots. pans and stainless flatware. I have not changed soap. Could the water not be hot enough?
Check the incoming water quality. If water is hard and having calcium content this could happen. Use water softeners in the inlet water to the machine.
If dish washer salt compartment available fill with the special salt meant for dish washers.
Check rinse aid compartment and fill rinse aid. Or use two in one soap tablet.
Sep 19, 2010 | Whirlpool Dishwashers
It is leaving an enormous amount of white residue on our dishes and is causing all of our metal dishes to come out dark.
The white residue could be from one of two sources.
Detergent Residue:
Using too much detergent or poor circulation of water can leave a white residue on the dishes. If the residue is easily rinsed off with warm water then it is detergent. Use less soap, especially if you pre-rinse the dishes or have soft water. Use a hi temperature wash to help dissolve the soap better.
Hard water deposits:
See this link where I put together some information on this.
http://www.fixya.com/support/r4666624-hard_water_calcium_white_powder_build_up
May 01, 2010 | Whirlpool Dishwashers
Soap does not disolve and residue left on all
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Jan 17, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Dishes not rinsing well,
I would check the bottom drain area. Sometimes food can stay down there and block the drain or get back around onto the next load.
Apr 06, 2009 | Kenmore Dishwashers
Bosch dishwasher
Although I previously posted with the same problem of a film on the dishes after cleaning, I did find a section in the owner's manual which solved my problem. Lift up the rinse aid cap on the inside door - the factory setting is on "4". The rinse aid works in conjunction with your local water, which has variations in it's hardness or softness. When your dishes are streaky, lower the rinse aid setting to 1 or 2. If your dishes are spotted, raise the rinse aid setting higher.
Sep 23, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Whirlpool 24 in. DU1100XTP Built-in Dishwasher Logo
74 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
