Question about AEG B5741-4 Electric Single Oven
I have recently had a MCC3880E-m oven fitted in to a housing unit by a Magnet kitchen fitter and It keeps flashing up a red ErC on the left hand side of the display panel - the Kitchen designer at Magnet has phoned a technician and was told it could be the "ambient" temperature of the kitchen , but this is not the issue. We were then told to run the main oven on 200 degrees for 10 - m15 minutes and this might sort it - but it hasn't. Can you help please?
    Top Expert:
  • AEG Master
  • 34,089 Answers
The "technician" has no idea why your oven is defective but the fact remains it was defective when installed. Magnet needs to take responsibility for replacing it.
Posted on Jun 10, 2017
5 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: bottom oven is not working seems like a light dust
I would say that the fan oven element has blown from the sound of it .
Quite a common occurance.
It is located at the rear of the oven compartment behind a removeable cover.
Please rate my solution.
Thankyou.
Posted on Jan 16, 2010
barkencoa
  • 3463 Answers
SOURCE: the power to the whole house tripped off, when it
I would say that the oven element has failed.
This is to be found at the rear of the oven compartment behind a removeable cover.
Fitting a new one should solve the problem.
Thanks.
Posted on Jan 19, 2010
SOURCE: ERROR CODE F6
F6 error code relates to the power board excessive temperature,this points to the cooling fan situated on top of the oven unit being faulty.
You already said it was noisy which is most certainly coo;ing fan.
Hope this helps.
Posted on May 08, 2010
  • 106 Answers
SOURCE: Not heating up to required temperature and burning food at back
some elements are bunt please check and an replace
Posted on Jun 15, 2010
Oven won't heat flashes F2EO and 5D on
List below does not apply to Whirlpool Models using the "Y" line in the products model numbers. Applies to models using 4 digit displays only.
F0-E0 Analog to Digital failure
Disconnect panel for 30 seconds
Should the above error re-appears, replacement of the control is required.
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad. Replace Keypad.
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Below applies only to the two digit display models for the brands above.
F0 Defective ERC Replace ERC
F1 Defective ERC Replace ERC
F2 Oven over heat Replace defective Sensor
F3 Oven Sensor Open Check/Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground.
F7 Shorted or sticking button Clean button or replace ERC
F8 Defective ERC Replace ERC
F9 Door Latch Error Check latch and latch circuit
Mar 20, 2016 | Ovens
I have a flashing code on my kenmore electric oven, model 911.47709200. the code is F7 dc, what does it mean?
Stuck Keypad. Roper ovens with 2 Digit Displays:
Oct 25, 2011 | Ovens
My oven keeps randomly beeping and flashing F-1 recently. When I push cancel it stops, sometimes for an hour and sometimes for a week. I have tried to reset by turing circuit on and off, but problem does...
Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
May 11, 2011 | Maytag Ovens
This cooker was fitted by Kitchens Direct last year, so is new. No manual was left by the fitters A power cut, throws the electronics out and the oven stops working. How do I get the light to stop...
Most likely, the digital panel just kind of locked up. The first thing I would try is to turn off the circuit breaker at your home's breaker (or fuse) panel for about 5 minutes and then turn it back on again. This should "reboot" it and hopefully the oven will get its brains back!
I hope this helps! :)
Dec 14, 2010 | Ovens
I recently bought a new house with fitted kitchen containing a fitted Diplomat double oven. When the power is on but both ovens off the Amber light above the top oven mode selector glows dimly. When I...
I'm not sure its been connected properly, needs checking out by someone who know's what they're doing. Be careful, the fuse doesn't trip for nothing.
Jul 09, 2010 | Ovens
I have a Kenmore gas built in oven, model number 790.30179400. It's 5 years old. I just used the oven and it wouldn't turn off. It seemed to be hotter than the temperature I had it on. I have a fuse box in...
Usually F11 is a comunication error and the initial fix is to remove all power for 30 seconds then try it again.
The oven element that did not turn off is a sticking relay on the Electronic Range Control (ERC) board /clock timer that did not open the relay electrical contacts when the power was removed from the relay coil. Or there was an on the printed circuit board (PCB) fault in the ERC that allowed power to remain on the relay coil until you removed power by pulling the fuse.
The most probable cause below with the cheapest source being Sears Direct in 2nd link.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-316418553-%3d%3di1064462&PartID=1064462
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=79030179400&productCategoryId=0125200&brandId=0582&brandDescription=KENMORE&modelName=GAS-WALLOVEN&diagramPageId=00001&componentDescription=CONTROLS&documentId=R0409085&blt=06
Thanks for using FixYa!
Kelly
Jan 20, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Oven flashes F2 and beeps in the middle of baking or broiling something. Our oven is all electric and recently whenever we start to broil or bake something, after a little while it will shut off and the...
HI. an F-2 during a baking cycle is the result of an out of control oven temp that has reached Temperatures above 615F-630F
If this actual over temperature condition occurred, Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred, Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
Aug 04, 2009 | GE Ovens
Range keeps beeping and flashes F-1
Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be canceled, replace the oven control (also called clock or ERC), touch pad, or both.
Jun 19, 2009 | GE Ovens
Kenmore model # 911-494-79790
May 11, 2008 | Kenmore 30169 Electric Single Oven
AEG B5741-4 Electric Single Oven Logo
76 people viewed this question
Top AEG Ovens Experts
ashburton
Sal DeAngelo
Steve
Are you an AEG Oven Expert? Answer questions, earn points and help others
