Question about Vacuums
Hi. We have a Riccar N2100 vacuum cleaner, which has served us well for many, many years. I'd like to attempt a repair on this unit, and looking for advice and/or a parts diagram to proceed. The unit makes a groaning sound when shut off. The sound tapers off in pitch as the motor and beater bar come to a stop. The sound only happens when the vacuum cleaner is turned off in the normal upright position. The sound does not happen when the lower unit and main housing are both laying flat. I took the folding lower unit apart (beater bar, belt section), and everything appears to be working fine. The beater bar spins freely, the belt is in good condition (no frayed edges or apparent problems), and the felt "bushings" that the beater bar spin on seems fine. I swapped the felt bushings with some home made ones, but it made no difference. The metal spindle that drives the beater bar belt, appears to have little or no support around the main housing. I can't tell if a part has broken off or is missing. The folding lower unit was easy to disassemble, but I'd like to see an assembly diagram of the main unit. This would help with disassembly, and hopefully an indication of what parts may need replacing. Any help you can provide would be much appreciated.
4 Suggested Answers
bugoy31
  • 1238 Answers
SOURCE: I purchased a Eureka C4910
Good day!
Normally when the motor is easily moved back and forth means that it have a proper lubrication,proper alignment and no clogs.
When the motor and the belt is OK the problem could be on electrical wiring and switch.
If found electrical switch burned out you need to replaced it because when the switch is burn the contact of that switch is open even you turn it ON.that's why the motor is not function because the voltage is not pass through the circuit because of open switch.You need to replaced it.
And check some fuses if any and other burned electrical wire.Replaced it also.
Thank you and don't forget to rate my answer.
Posted on May 28, 2011
SOURCE: Beater Bar Belt Removal from Upright Electrolux Vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=783793
Generic problem for all Vacuums
Beater bar Belt Removal from Upright Electrolux...
Posted by wrenn on Jul 14, 2008
I am trying to change the belt on an Electrolux Model 1717 Upright Vacuum and I am having difficulty disassembling the vacuum to remove the beater bar and belt.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. . Normally there are screws, clips or levers that would remove the bottom plate or if that does not work then the top cover will come off and that will expose the belt. Once that is off and the belt is exposed then cut off the old belt and then lift up the brushroll on the pulley end and install the new belt around the pulley end and re-install the brushroll. Then use a belt puller or a screwdriver with a bent right or left end to stretch the belt onto the motor pulley and then track the belt in a straight line and reverse you steps in the reinstall of the top cover or bottom plate. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 15, 2008
askdyson
  • 2572 Answers
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: I just replaced the clutch
    The DC17 doesn't use a clutch-based brush control system, so you may be referring to a different Dyson model. So we can determine exactly which machine you own, and offer the support you need as quickly as possible, please get in touch with us directly. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
    Kind regards,
    Jack
    Dyson Online Customer Support
    Posted on Sep 27, 2011
    How do i replace the fan on a riccar rsl3 vacuum cleaner?
    RICCAR SIMPLICITY SUPRALITE RSL MOTOR and FAN
    Its looks the same as a Kirby its done with a nut on the axle on the armature of the motor.
    Feb 20, 2016 | Riccar Vacuums
    Riccar N2100 vacuum hard to push
    Start by replacing the belt, check the brush roll while you have it out.
    Apr 12, 2014 | Riccar Vacuums
    Parts schematic for riccar 8920 vacuum
    I am looking for a new motor for my 8920 Ricaar Vacuum. All else works fine.
    Jul 13, 2012 | Riccar Vacuums
    Need to replace brushes ona ricca 8955
    Your model can last well over 20 years. You might be able to change. The. Brushes yourself but there are adjustments that are difficult to do properly by the average homeowner. It. Would be best to talk to a qualified. Riccar repair technician before you attempt to change the brush strips.
    Oct 31, 2011 | Riccar 8955 Upright Vacuum
    Cord is hot and vaccumn keeps running then shutting off and on
    Hi There,
    May you kindly please clarify what type of vacuum cleaner that you have? The model number may be located at the bottom or the back of the vacuum cleaner, and this number will help me determine what the problem with your vacuum cleaner is. Please just use the comment section on this repair solution to answer. Thanks,
    Jun 07, 2010 | Riccar and Simplcity Canister Vacuum...
    Stopped running. Filter was clogged. Cleaned filter and changed bag, but still won't start. Motor was warm when it stopped.
    Hi There,
    This sounds like the Thermal Switch in your motor tripped. All Riccar vacuum cleaners have a motor reset switch, that will shut the motor down when it gets hot. Usually it's caused by a full bag, clog, or dirty filter.
    Try resetting the thermal switch first. If this doesn't work, you may have done some more serious damage to the motor, and it might be a good idea to take it into a local Riccar dealer in your area.
    Here's a step by step guide on how to check the reset switch on your Riccar 8850:
    To reset the thermal fuse:
    1. Unplug the vacuum cleaner
    2. Check for problem – over–filled bag, clog in hose, clogged filters, etc.
    Remove the vacuum bag, and see if you can visibly see any obstructions, or replace the bag if it's full:
    Also inspect the Secondary filter while you have the vacuum bag removed from the machine. If the filter is clogged or dirty, rinse under warm water, and air dry completely before reinstalling it into the vacuum. It's best to wash this filter every 30 days, and replace after 4-5 washings.
    Here's a link to the secondary filter on our website if you ever need to purchase one:
    Riccar 8800 Series Secondary Filter
    Your Riccar 8850 also has a set of exhaust filters that are on the front of the vacuum, near the bottom where the upright body meets the agitator housing. These filters when clogged may also cause the thermal switch to trip. These filters are recommended to be replaced every 6-12 months, and are not recommended to be washed.
    Here's a link to 2 sets of the exhaust filters for the Riccar 8850 on our website:
    Riccar 8850 Exhaust Final Filters, 2 Sets, 4 Total Filters
    It's also possible that you may have clog in the suction port inside of the agitator housing. Remove the bottom plate from the vacuum, and look for the tube that runs on the left hand side from the tray to the rear of the agitator housing. Make sure that this tube is clear from obstructions:
    Locate "tripped" fuse – the small white button located on the bottom of the back side of
    the main body (roughly one inch to the right of the left wheel)
    Using a pencil, paper clip or other pointed object, push the reset button in, you should hear a clicking noise when it resets.
    Plug the vacuum cleaner back into the wall, and try turning the vacuum on. It should come right back on. If not, it's best to take your machine into a local Riccar authorized repair facility for further more advanced diagnosing.
    Please feel free to ask any follow up questions by adding a comment to this repair, I'm always more then happy to answer any and all follow up questions if you need some clarification. If this was helpful, please rate the repair helpful or leave some feedback for me. Thanks so much,
    Chris Jones
    Govacuum.com
    May 22, 2010 | Riccar 8850 Vacuum
    My Riccar 8850 stopped running. Changed the bag and cleared all hoses. Light comes on but the motor doesn't operate. I can turn the brush freely by hand.
    Greetings from GoVacuum,
    If the light on your Riccar 8850 is coming on, but the motor is not coming on, this indicates that your motor has gone bad. There is a reset switch on the back of the vacuum cleaner that sometimes trips if the bag is too full, or the filters are not maintained, but when this happens nothing on the vacuum comes on including the headlight. If the headlight is coming on, this indicates that electricity is making it down to the headlight, and the current is going through, but just not activating the motor. This is a tell tale sign of your motor being bad, and needing replacement. You can purchase the motor for the Riccar 8850 (12 AMP, 2 stage motor, Riccar part D113-1700 $122.44) from GoVacuum by giving us a call, as we don't yet have this part on our website.
    I hope this helped you. We have been fixing Riccar's for over 30 years, and they are great vacuum cleaners, and the age of the model 8850 is probably the life expectancy of this vacuum cleaner.
    Chris Jones
    GoVacuum.com
    Mar 18, 2010 | Riccar 8850 Vacuum
    Where is the reset button located?
    The reset buttons on the Riccar vacuum cleaners are located at the bottom of the vacuum cleaner in the back, underneath of where the wand sits on the vacuum cleaner.
    Here's a picture of a Riccar 8925 which replaced your 8850 a few years ago, but the reset switch will be in the same exact location on all Riccar uprights;
    Here's a closer look of the reset switch;
    I hope that I was able to answer your question. You can avoid the reset switch flipping in the first place by always ensuring that you change the bags frequently and when full, as well as the motor filter that sits underneath of the bag. Also keeping the vacuum from clogging will prevent this.
    If you found this repair solution helpful to you, may you please click the 4 Thumbs Up Icons in the top right hand corner to help me out here on Fixya? I really do appreciate it, thank you so much.
    Chris
    GoVacuum
    Jan 15, 2010 | Riccar 8850 Vacuum
    Where can I get replacement wheels?
    Greetings from GoVacuum.com,
    I just wanted to let you know that we are an authorized Riccar dealer, and we can certainly get the replacement wheels for your Riccar 4812 upright vacuum cleaner.
    We stock some parts, and what we don't stock we'll order for you. We don't currently have the wheels on our site, but if you still need the wheels, you may email me at chris.jones@govacuum.com.
    We do stock a lot of parts for your 4812 Riccar, including the following;
    Riccar 4000 Series Bags That Fit the 4812. Paper Bags 12pk.
    http://www.govacuum.com/ricc103.html
    Riccar 4000 Series Exhaust Filters for the 4812 Part RF4-2;
    http://www.govacuum.com/ricc117.html
    Riccar 4000 / 8000 Series Drive Belts Part # A20-R2P
    http://www.govacuum.com/ricc112.html
    Foam Filter Underneath of Bag Riccar 4812 Part B622-0500
    http://www.govacuum.com/ricc133.html
    I look forward to helping you if you still need to get the wheels for your vacuum.
    Thank you,
    Chris J.
    GoVacuum.com
    Jan 11, 2010 | Riccar 4812 Vacuum
    Riccar RC-1100 won't power on?
    try a different power cord, otherwise it is a thermal issue. if it is a thermal issue, call or e-mail tech support, and send it in. otherwise you could get it repaired @ any local vacuum cleaner dealer
    Apr 07, 2009 | Riccar RC1100 Compact Vacuum
    Vacuums Logo
    366 people viewed this question
    Top Vacuums Experts
    AskDyson
    AskDyson
    D. Floyd Kolb
    D. Floyd Kolb
    Are you a Vacuum Expert? Answer questions, earn points and help others
