Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Power light blinks green but tv wont come on please help??? there is also a white ground wire connected to the bottom but the other end is not connected?? its a rca scenium 61'' d61w130 , what do i need to fix this promblem thanks....
  • 11 more comments
  • jwaters10580 Nov 14, 2010
    it blinks 3 times, but i got it to come on last night, i just pushed the power button in and wedged it behind the metal , afaid to turn it off, it might not com back on ?
    it blinks 3 times, but i got it to come on last night. i just pushed the power button in and kinda wedged it behind the medal.. afraid it wont come back on if i turn it off??
  • Anonymous Mar 11, 2014
    torque axel mut on 2005 fount wheel mercury mariner 4 whell drive
    My 2000 cougar got flooded now it wont start what can be the problem
    rm2354 stopped working and lights started flashing will not re start on either electric or gas
    futura c250 bobbin thread winding stops with error 88
    MY KEURIG DRIPS VERY SLOWLY AND NOT A FULL MEASUREMENTproblems with keurig
    I need to replace the whole bath vent with a new one with these same dimensions
    "Please Help..my Indesit washing machine model WIXL143 wont work its flashing the 1st & the 4th light aswell as the light that indicates the machine is on is flashing, i've tried unplugging it from the mains but it hasn't made any difference, thank you"
    and can it be moved to other sidefor opening
    I want to log in in to my gmail account and would not let me
  • Anonymous Mar 12, 2014
    replacing dust shields on rear 2004 chevy 2500hd how to remove old shield
    Power Brake Booster is hissing and needs to be replaced, before I could do this the Transmission that was rebuilt 14 months ago failed and had to be rebuilt. When I got it back it was running rough and had several Diagnostic Codes. P0700, P0337, P0785, P0014 and P2131. I erased the codes and only the P0700 and P0337 came back.
  • 4,889 Answers
Anything you can tell me about how many times it blinks in between each pause? Also can you get me an image of the white ground wire you are talking about?
Posted on Nov 14, 2010
  • eagle338
    eagle338 Nov 14, 2010
    3 blinks indicate that there is a problem with the High voltage not coming on. My money would be on faulty flyback transformer and/or HOT(horizontal output transistor). There can also be some faulty capacitors in the circuit. How good are your electronics/soldering skills? This is a high voltage(25000 to 30000V) circuit and it may not be a good idea to play with it, without prior experience .
Motion sensor light wiring
problem could be sensor, not light, black is power, white is neutral, green is ground, sensor may have a red wire, black wire and a white wire, hook black wire to power from sensor, red to black wire on light,
white wires will connect together, then wire black to power on home, white to white on home and green to ground, if you need help call an electrician and they will wire it for you
Feb 03, 2012 | Home
How do you connect the electric to wire bathroom lights on one switch, and the fan on the other switch, The power comes in through the switch, Both switches are located in the same box
In the box, connect all white wires together, that is the incoming power, the lights and the fan.
Then take the black supply wire and connect it to the bottom terminal of one of the switches and cut and install a jumper from that terminal to the bottom terminal of the other switch.
Next connect a black wire that goes to the light(s) to the top terminal of one of the switches. When this switch is turned on, power should flow from the supply thru the switch to the light.
Finally, connect another black wire that goes to the fan to the top terminal of the other switch. This will turn on the fan.
All ground or green wires connect together and the green terminal on each switch should have a piece of green wire to connect to all the other green ground wires.
Mar 16, 2011 | Dryers
I am adding a light to a Hampton Bay fan. From the ceiling wiring I have a red and a green wire that are not connected. Is the red wire for the light and do I tie it in to the black wire to the fan for...
The green is a ground and the red is the hot wire for the light. One wire from the light kit is white and should be connected to the other white wire in the fan. The red wire should be the hot wire and gets connected to the black or blue (other wire) from the light kit. If you connect the two wires and the light does not come on, you need to find the other end of the red wire and make sure it is connected to a switch to give it power. The other end of the red wire is probably in the single gang box where the wall switch for the fan is located. Or you can tie the red wire for the light to the black wire for the fan and simply use the pull cord to cut on/off the light.
Jan 26, 2011 | Heating & Cooling
The wires for hooking this fan up are white,black and blue my guess is white and black are hot and blue is a ground wire. is this right?
White (Neutral) White to White
Blue (Light to Hot) Blue to Black (optional)
Black (Fan to Hot) Black to Black
Green (Ground to Ground) Green to Green
If you do not have a green lead you might see a green screw to attach the ground wire from the house power. The fan has the optional light fixture future connect the blue wire to the black hot wire. If you have the optional light fixture you may want to connect it to a separate switch power.
Jan 14, 2011 | Hampton Bay 73554 Antigua Ceiling Fan
Timer has 4 wires Blue, Green White and Black but wall switch only has black and white. where do I connect all the wires?
You are replacing a single-pole switch that has two wires.
You posted under UPM timer.
But UPM timers have a red wire instead of a blue wire, so you have different brand.
Some GE programmable timers and some Leviton timers have a blue wire.
Here are instructions:
-Green wire goes to bare ground wire.
-Timer black wire goes to black wire
-Timer blue wire goes to white wire.
-Located in back of electric box are white wires twisted together and covered with wire nut. These are neutral wires. Timer white wire connects to these wires. This will power electronics inside the timer.
-If your box does not have white neutral wires described above, then connect timer white wire to bare ground wire along with timer green wire.
-Turn power ON, and push on-off button. If timer works, then it is wired correctly.
- If timer doesn't work, then reverse Timer blue and Timer black wires.
- If lights blink on-and-off, then you connected white wire incorrectly, review wiring shown above.
If your box does not have neutral wires or bare ground wire as described above, then buy Walmart.s Brinks 46-1022 or Intermatic ST01C or Intermatic EJ500 or Aube T1032. These timers do not need neutral or bare ground wire.
Dec 31, 2010 | UPM Programmable Wall Switch Timer
Window switch is bad will do down but wont go up ,how do i get window up for a quick fix.
Hi, I assume you're talking driver's window. If not, please get back to me.
pull up your switch, take connector off and hotwire the connector.
motor wires are yellow and white/black stripe.
power is yellow/light green stripe
so connect the yellow to yellow/light green and white/black stripe to ground, key on. this might be up or down--not sure.
if it is down, then connect white/black stripe to yellow/light green stripe and yellow to chassis ground, key on--should go up.
Let me know if you have questions and thanks for using FixYa.
Dec 29, 2010 | 2000 Lincoln Town Car
The 3-way dimmer switch has 4 wires; 1-red, 1-yellow, 1 green and 1 black. Hot wire coming in is black, ground is bare and neutral is white. Wires going out are red,black,bare and white. What does each of...
Incoming white - outgoing white This is the neutral, which just passes through without connecting to the switch
incoming black - switch black the hot wire provides power to the switch
switch red - outgoing red a traveler, will have power when toggle is one position
switch yellow - outgoing black
the other traveler, will have power when toggle is in the other position
incoming bare - switch green - outgoing bare the switch is grounded and it passes through
If this was helpful, please vote.
Mar 21, 2010 | Cooper Wiring Devices Three Way Grounded...
Replace a 3 wire power cord with a 4 wire power cord.
red on one end, black on the other, white in the middle, green to cabinet ground.
Jun 12, 2009 | Dryers
2005 Scion TC brake light wire color code question
1. is white with black strip- ground
2. is green is left brake and
3. is green with white is running light
Mar 28, 2009 | Scion TC Cars & Trucks
Ceiling fan
OK, the wires coming from the top of the fan are going to go into the junction box in your ceiling. Out of the ceiling, you should have a white wire, a black wire, and a green or bare copper ground wire. Make sure your power is off at the fan. Your wires coming out of the fan should be white, black, blue, and a green ground wire. Pull the wires through the top of your fan, and connect the white to the white in the ceiling, the black and blue wires from the fan to the black wire in the ceiling, and then connect your ground wires together. Make sure you use wire nuts and twist them firmly onto the ends of the wires. If you happen to have a red wire coming out of the ceiling as well, just put a wire nut on it and stuff it back into the ceiling box. The blue wire is what works your light kit, and the black is for the fan. Hope this helps you!
Jan 05, 2008 | Casablanca Fan 3245T Ceiling
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
1,193 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
