Question about Lexmark C760 Laser Printer
Lexmark C760 problem
When the printer tries to print the paper jams and spits toner all over the place. Can this be fix in house or a professional? Thanks
Helen,
This model has a transfer belt, not a drum. Never clean this or even touch it with your fingers. Its spitting toner every where because its jamming before the toner can fuse to the paper. Concentrate on the jam only, if its jamming continuously you have a sensor or obstructiong in the path. Get a tech.
Mack
Posted on Jul 04, 2008
  • 94 Answers
R u using refill toner than spill over will happen
use good quality toner
plus clearn the ITU drum regularly
if using genuine toner than demand replacement fm lexmark for this problem
Posted on Jul 02, 2008
Lexmark c760 i am consistently getting a paper jam error at the VTB what would be the cause of this?
check and adjust the paper thickness setting for the paper in use
there are at least 4 settings for paper on the market and from your description , the paper is too thick for the setting
Nov 10, 2017 | Lexmark Office Equipment & Supplies
T652n 202.03 paperjam
1Open the upper-front cover and remove the toner cartridge.2
Look into the printer. Remove any jammed sheets of paper that you find there.
  • If the print job only consisted of this one page, reinstall the toner cartridge and close the front cover. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If the print job consisted of more than one page, confirm the entire paper path is clear before printing again. Do the following:
    1. Remove the top paper tray ('Tray 1').
    2. Remove any jammed or partially-fed sheets of paper you find here, then reinstall the tray.
    3. Go around to the back of the machine and open the upper-rear cover. Remove any jammed sheets of paper you find, then close the cover.
    4. Once you have confirmed that the entire paper path is clear, reinstall the toner cartridge and close the front cover.
    5. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If you cannot locate any jammed paper under the toner cartridge, then check the rest of the printer for any jammed paper. Do the following:
    • Remove the top paper tray ('Tray 1') and look for any jammed or partially-fed sheets of paper.
    • If you do not find any jammed pages there, reinstall the tray and go around to the back of the machine. Open the upper-rear cover and look there.
    • If the entire paper path appears to be clear, close the rear cover and power off the printer. Reinstall the toner cartridge and close the front cover. Power the printer back on. If a 200 error continues on power up, a sensor in the printer may be malfunctioning. This will require a service call to correct the issue. Please contact Lexmark Technical Support for additional information (see Contacting Lexmark Technical Supportbelow for details).
Aug 28, 2012 | Lexmark T652N PRINTER OPPENHEIMER SPECIAL...
Will the toner out of a C760 work in a C782
Color Laser Toner Cartridge is compatible with Lexmark X762E, X762, so it will not work in C782
Lucas
Jul 07, 2011 | Lexmark C750, C752, C760, C762, C770,...
AFTER PAPER JAM WILL NOT PRINT
The printer could be stuck with the paper jam error due to paper still stuck inside the printer. Make sure you check under the toner, in the back of the printer and at the paper tray. If there is still paper jammed then the printer will not go to a ready state. The other problem could be that the printer sensor got damaged after removing the jammed paged. If that is the case then you will probably have to take the printer to a service provider to fix it. Here is a link with illustration on how to check and removed jammed paper. http://bit.ly/aqUrn7
Feb 20, 2010 | Lexmark E232 Laser Printer
Paper jams when printing and paper is being pulled in sideways
Hi, Follow these steps:- 1.Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred. 2.Turn off the printer. 3.Remove any paper trays. Inspect them for wrinkled or damaged paper. 4.Open any other doors that give access to the printer's paper path and to the toner or ink cartridge. 5.If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it. 6.If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly.The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam. 7.If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. 8.Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on. 9.If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path. Thanks! mannu_rakesh
Sep 07, 2009 | Lexmark Z1480 InkJet Printer
BLACK VERTICAL STREAKS
toner recently replaced?
have you cleaned nozels?
try running a cleaning cycle.
also clean the paper rollers to make sure you got no ink on them.
Feb 25, 2009 | Lexmark C760 Laser Printer
Lexmark, paper jams and prints in same place, over+++
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 06, 2009 | Compaq Lexmark Color Jetprinter Z12 InkJet
Printer says clear paper jam. There is no paper jam.
Dec 31, 2008 | Lexmark X5250 All-In-One InkJet Printer
Paper jams
there are two parts to the copy of this machine, one is the photo conductor (drum, green cylinder ***'y) and the toner which fits in the drum ***'y.
you replaced the drum but you need to replace the toner as well (low toner)
then turn off and hold the start key an dturn on to get into service mode, scroll to reset photo count, select.
Aug 20, 2008 | Lexmark E340 Laser Printer
The paper light is flashing
My printer is constantly getting jammed, spitting out blank sheets of paper in between every printed sheet, clicking and snapping, etc.
There are a few places to check for a jam - pull the paper drawer out and check there, take the toner cartridge out and you'll often find a sheet there that you cannot see from any other angle, open the little compartment at the back and check there and the usual paper sticking out of the output just enough to pull it out the rest of the way.
I'll be looking for a new printer this week though. I can't take the constant paper jams and sifting out the blank sheets when I'm printing 500+ statements a month.
Definitely NOT an office friendly machine!
Aug 20, 2008 | Lexmark E250dn Laser Printer
Lexmark C760 Laser Printer Logo
130 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
