HELLO THERE:
Many people think that it's a
pressure problem, and the fact that the iPod is not picking up the
pressure you apply when you touch the screen to perform a task. However,
the screen on the iPod Touch is not pressure-activated but rather,
heat-activated. This means that when you touch the iPod screen, the
sensors inside the Touch pick up on the heat from your finger and follow
it to wherever it goes. If it can't pick up the heat, it won't be able
to do much for you. Luckily, because it's the heat sensor, the problem
can sometimes be very easily corrected.
Oftentimes, this problem occurs when people are outside on a very warm day and are trying to use their iPod Touch. Because the surrounding air is just as warm, or hotter, than the temperature
from the tip of the finger, the sensors can't differentiate and so,
they don't respond when you touch the screen. So, just move to a cooler
place and you should be able to operate your iPod Touch again. Some also suggest turning your iPod off and on and waiting a few minutes before trying again to see if it will work.
Unfortunately, if those solutions don't work for you, you might be
out of luck and might just have a defective screen. If this happens, the
only solution sadly is to return your iPod Touch to Apple and hopefully, you're still under warranty to get a new one.
