Question about AMD 486542-001 - HP Pavilion DV7 Series System board with integrated ATI Radeon HD 3200 graphics Motherboard
Will not power up new charger connector installed
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 106 Answers
Thanks for using fixya, that sounds a motherboard problem, you need to repair the motherboard or replace it, or you try to take all the powers from the laptop (bat. and charger ) press the power button for 10 sec. then connect only the main without the bat. and seen if works , if not , you need to repair or replace it.
Thanks
Posted on Nov 13, 2010
Unable to start (turn on) Kindle Fire 8.9 HD
Try plugging in charging cord and see if device powers on while connected to mains power if so and it doesn't start off mains it's your battery. If it doesn't turn on with regular charger try another charger with same connector to be sure it is not your charger that is faulty. Failing all of this, and you are handy, you can search for battery part number on net buy one from China and install yourself. PLEASE ONLY IF YOU ARE COMPETENT DO YOU TRY FIXING ELECTRICAL PARTS YOURSELF. Alternatively it is probably easier to buy a new ereader.
Nov 07, 2016 | Amazon Kindle Fire HD 8.9"
Electric Mobility: Replacement scooter charger
Rob, If need be, possible you can adapt you old chargers connector onto new charger if not the same plug. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
24 Volt 4 0 Amp On Board Battery Charger for Rascal Scooters and Power...
RASCAL 600 600t HANDICAP MOBILITY SCOOTER PRISM 24V BATTERY CHARGER...
Aug 17, 2016 | Electric Health & Beauty
SM-T211Why will tablet not turn on or charge
When it does not have enough power, it can't switch on. And even a new charger can't get in any power if inside the tablet is something wrong. Like a dirty or defect connector, or inside a bad or broken cable. also check the connector, where you put the charger cable in.
Feb 13, 2015 | Samsung Galaxy Tab Tablet PC
Power-pack not charging battery
bad connector on pc or received bad power/charger unit try getting new charger to verify
Aug 08, 2014 | Toshiba Satellite T215DS1150 Netbook
My cauzin Got Acer Aspire 5920 !! its charger stop working she buy another charger for it !! but due to inexperience she bought 24 volts instead of 18 volts !! after charging some time the laptop isn't...
One of two things. The Power Connector (on the motherboard) or the motherboard itself. If it is just the power connector, you can purchase a new one for around $10 (look at the specs for your model) and solder a new one on. If it is the motherboard, you'll be replacing alot more than it most likely. It could have fried the GPU, memory and Proc.
And the following three condition should be met for you to use an AC Adapter safely.
1) Output Voltage is within +/- 5% of your old charger's output.
For example, if your old charger provides 19.5V, then you can use a charger that provides 20.5V or 18.5V.
2) Output Current is the same or higher than that of your old charger.
For example, if your original adapter provides 3.42 Amps, then you can use a charger that provides 3.42 Amps, 3.9 Amps or higher.
3) Connector tip must fit securely into your laptop.
Specification of Acer Aspire 5920 Charger:
Output: DC19V 3.42A
DC Connecter (Barrel) size:
Internal Diameter: 1.5mm
External Diameter: 5.5mm
Feb 22, 2011 | Acer Computers & Internet
Not charging
If you have power to the on-board charger, check inside the base and be sure that the wires to the amp-meter are tightly connected and all other connections are tight. If so, then you probably need a new charger. Instead of paying a few hundred bucks for an on-board from the mfgr. you can buy an off-board charger on ebay for around $50.00 that will plug into the 3-pin connector located on your joystick.
Just search ebay for electric wheelchair charger and you'll find dozens; make sure you get the one with 3-pin connector...most are like that.
Dec 05, 2009 | Jet 3 Ultra Power Chair
Lost the charger of my sony dvd201 cam corder. is there any other way i can charge my camcorder?so i dnt have to buy a new charger? and do i need power to open the camcorder disc door?
Hello. Yes, you do need power to open the disc door. When you slide the disc cover open switch, you should hear the little musical sound, and then the "preparing to open cover" appears in the lcd display. Then the door opens automatically. As for charging the corder, you can get a new ac charger for 25 bucks on Ebay. Sony uses a special plug that is inserted. If you want to go the cheaper route, I saw mobile *battery* chargers for your unit(not to be used as camcorder power supplies) as inexpensive as 8 bucks...most were 10 dollars and up...the input voltage/current to the cam is 12v @ 500ma. However, the fact that the connector isn't the generic "cylinder" shaped power connector makes purchasing a compatable power source a necessity. ---Rick
Sep 16, 2009 | Sony Handycam DCR-DVD201 DVD Camcorder
Battery charger for craftman electric lawn mower model no 625 connector from charger to battery is broken and need new connector or complete charger
junked the charger connectors and replaced the connectors with better type of connectors that an old man can get a hold of to take apart to connect the charger when needed very poor design for elderly use.
Jun 13, 2009 | Craftsman Garden
AC Adapter
Hi Kayla,
It is most likely the power connector on the laptop is faulty and the power adapter is not making electrical connection with the laptop.
You stated that by moving the touchy power plug that you could get it to charge, this is proof that you have a faulty power input connector on the laptop.
Check the power adapter's laptop connector with a multimeter, if there is voltage at the connector then the adapter is OK, the voltage reading should be as stated on the label or slightly higher.
You may be able to get the power connector repaired (it may need resoldering because of a dry joint) or it may need to be replaced.
Jan 02, 2009 | Acer Aspire 3610 Notebook
AMD 486542-001 - HP Pavilion DV7  Series System board with integrated ATI Radeon HD 3200 graphics Motherboard Logo
328 people viewed this question
Top AMD Computers & Internet Experts
David
David
rafnix
rafnix
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
