Question about AEG Vacuums
Vacume Overheating My vacum is overheating and then shuts down for awhile but doesn't start again untill the vacum has cooled down.. Are there any heat-relays or something like that that could cause the problem ?
  • 46 Answers
There will be a filter between the cylinder/bag and the engine. If your vacuum has a HEPA filter there will be one on the other side of the engine. Remove both of these and clean them out with water, allow to dry and replace.
Posted on Jun 18, 2008
Where is the fuse located on a dirt buster vacuum cleaner?
Black & Decker Dirtbuster Vacuum Cleaner
no fuses in these ....double insulated
the motor has a thermal protection shut off when overheating
will start again when cooled down
empty bag often
if unit keeps shutting down replace vacuum
2477301-black-and-decker-dirtbuster-vacuum-cleaner-0-bwbjq1d2inqbxh534mfqkm1n-3-0.jpg
Apr 29, 2017 | Vacuums
My shark proffesional nv502 vacuum wont power on. My daughter sucked up a sock and it shut down to avoid overheating the motor I guess. Well--3 days later andit still wont turn back on. Is there a reset...
it should start after awhile is it the whole machine or just the brush bar. oh there is no reset from what i read.over heat motor it shuts down till it cools.
Feb 08, 2015 | Shark Rotator Professional Lift-Away...
I have a cannister vacume, Fuller Brush red model # FB-DCC when I turn it on it will shut itself off in about 30 seconds this will happen several times then it will not turn on. I do not have the owners...
First, the word is "VACUUM." Second, it's obvoius that your motor is overheating. When's the last time you CLEANED THE FILTERS, per the operating instructions?
Nov 07, 2010 | Fuller Brush Vacuums
My dyson dc 16 hand held vacume stops & starts while in use, each time you pull the trigger it will start again but then stops after a short while untill i pull the trigger again.
Cutting out can be due to a few things , motor overheating due to dirty filter, Faulty mains cable or plug..sealed type also..Faulty Switch/trigger.May need to seek pro help to fix.
Apr 01, 2010 | Vacuums
Vacume overheats and shuts down I replaced the motor.When it cools down it runs again.
The filters had to be cleaned out with air.
I replaced the motor for nothing.There are two filters and the cannister give them good cleanings with an air gun.
Jun 03, 2009 | Kenmore Vacuums
Nothing inn the canister after using,suctione working,bottom roller working,no air leaks from hoses.Also when running awhile it shuts off by itself,have to wait awhile to use again
I'm not sure what vacuum you have, but that sounds like a blockage to me. Thermal shut off kicks in, shutting the motor down, to prevent damage from overheating. After waiting like 1 hour it probably comes back on. Make sure hose, filters, bag (if any) is clean. All "airways" of vacuums need to be clear of any blockages, since airflow is what makes vacuums work.
Apr 18, 2009 | Vacuums
Shuts off after 15min
the motor protection 1st has to be replaced
Mar 06, 2009 | Hoover U5780-900 Windtunnel Cyclonic...
Hoover Sensory 2200W Overheating and Shut-Down
Did you ever get to the bottom of your overheating and shut-down problem? Just got the same problem :(
regards,
Mar 31, 2008 | Hoover Vacuums
Won't start
It should after it has cooled down. But first make sure all ports are checked for blockage, including the hose. There a number of covers that will come off easily.
Feb 19, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson Vacume dco7
Vacume overheated when inflow was plugged. Will it restart when it cools off.
Feb 17, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuums Logo
360 people viewed this question
Top AEG Vacuums Experts
JoeVacs
Are you an AEG Vacuum Expert? Answer questions, earn points and help others
