My hivion 9191 x pvr give some massage that u should ve update this can i do now
Do you know where I can find the firmware update (1.18) for a Bauhn 1Tb PVR?
http://tempoaustralia.com/sw/as-pvr1000r/AS-PVR1000R_IM.pdf
DG-DABVPR1TB
down load and put on a usb drive,
DGTEC firmware 2011 updates available
New updates available for service issues such as freezing and start up/ recording issues (firmware 2011) are also available from the DGTEC website.
Please update software first before replacing hardware...
From DGTEC Website Software Upgrades page: -
Click on the relevant link below to download the latest software update for your DGTEC product. For further help and assistance, please access the DGTEC Call Centre via the Support page.
Obsolete Products
* DG-FV500PVR Upgrade (zip file 4.3Mb)
* DG-HD6760 Upgrade (rar file 2.3Mb) Upgrade instructions DG-HD6760 (25Kb)
New Products
DG-HDMP1080
DG-HDMP1080P
DG-HDMP1080TT
DG-HDMP500TT
DG-DABVPR1TB
DG-DABPVR500GB
DG-HD2104AND
Models
DG-FV500PVR - 500GB HD PVR WITH TWIN TUNER (FREEVIEW)
DG-HD6760 - HD SET TOP BOX WITH USB RECORDING
DG-HDMP1080 - HD MEDIA PLAYER
DG-HDMP1080P - WIRELESS HD MULTI MEDIA PLAYER / STB
DG-HDMP1080TT - HD MEDIA PLAYER WITH TWIN TUNER
DG-HDMP500TT - (NEW MODEL RELEASE)
DG-DABVPR1TB - 1TB HD PVR WITH TWIN TUNER WITH INTEGRAT
DG-DABPVR500GB / DG-DAB+500PVR- 500GB HD PVR / TWIN TUNER WITH INTEGRATED
TV-6600 BAUHN UNIT- 500GB HD TWIN TUNER PVR
GG-HD1200PVR- BAUHN UNIT WITH TWIN TUNER
Note: - Master Override Password 1973
Instructions:
Read instructions carefully before commencing. Software needs to be carried out while the PVR is cold. Go to "Telefix" website and select "Service Guide" or "Download Service Manuals" and download software to a location on the PC Hard Drive.
Unzip file and copy "usb.upg" software onto a blank USB Memory Stick.
Plug USB Stick to USB port of PVR
Connect Power to PVR and switch on so that that the booting process commences.
Press 'Menu' button and scroll left or right by using the arrow buttons to find 'Installation' then press OK to select.
Note: PVR may freeze and not allow selection. Several attempts will be required to enable selection. If problem persists, switch OFF PVR to allow it to cool down then try again or use the alternative method.
Alternative Method
1a. Disconnect mains power.
2a. Plug USB Memory Stick to USB port.
3a. Press and hold the CH down arrow button on the unit and then connect mains power.
4a. When the display starts counting down release channel button and the upgrade interface will appear on screen.
7. Scroll down to 'USB Menu' by using the arrow down button then press 'OK' to select.
8. Scroll down to 'USB Upgrade' by using the arrow down button then press 'OK' to commence software update.
ยท Note: - Please do not shutdown PVR or remove USB Stick during the update process. When the update is complete the PVR will power down and reboot again as normal.
Once the update has completed, reset the PVR by restoring back to Factory Default.
Press Menu ? Installation ? Factory Default ? enter password 0 0 0 0 ? Select 'Yes' ? press OK to rescan channels.
Check Software Version, Press Menu ? Installation ? Version Info ? OK
download and put on usb drive
Software Updates
Apr 11, 2015 | Televison & Video
Hi I have a PACE PVR Decoder which skips channels when p+ / p- is pressed
Hi, This may be due to one or two things. The remote and the box should have P+ and P- buttons. If the box operates ok but the remote doesn't the remote buttons are causing what is called switch bounce and needs replacing but if the box and remote jumps channels they are not the cause but programming and memory retention of the PVR.
Make sure the pvr is not recording anything first as this may inhibit some channels from showing. go to the update page and make sure that the box is fully updated. Another reason could be the aerial not giving strong enough signals for some of the multiplexed stations. To check this select the channel number rather than using P + or P-.
If the channel does not show it could be signal related or moved to another number and not updated. Tim
Aug 22, 2014 | Televison & Video
Where do I find the Firmware update for the TV-6600 BAUHN UNIT- 500GB HD TWIN TUNER PVR
I need the Firmware update for the TV-6600 BAUHN UNIT- 500GB HD TWIN TUNER PVR as well. Can anyone out there be of any help?
Apr 26, 2014 | Computers & Internet
My Frontech Externall TV Tuner Box showing this error E2&VIF Adjust
MY FOXEN TV CARD EXTERNAL IS PROBLEM SOW MASSAGE ...
E2 & VIF ADJOST
PAGE ADDR OOH
OFFSFT 80
Oct 22, 2012 | V-Stream Xpert TV-PVR 883 Low Profile PCI...
Hivion hv-9090x master password
HI
press menu>Stb Setting>>Press Ok>>Press 9876
Dec 24, 2011 | Computers & Internet
I need a replacement cord for the brookstone thera spa cordless massager
HELLO MEAD
I had a Theraspa cordless turbo massager that eventually stopped working but I kept the charger. It still works because I've used it for my replacement massager.
If you're still interested, would $10 be reasonable (plus shipping cost)?
I have an e-bay account and I can sell it to you through there if you want.
Let me know if/how you'd like to proceed.
JK
Nov 21, 2011 | Brookstone Theraspa Turbo Massager
How to upgrade Dansat 8400 PVR i need it thanks
Link to software v 3.0.3 for Dansat 8400 PVR:
http://www.mediafire.com/file/zjzwzyzooj2/DANSAT DSR-8400 _090328.rar
This solves the problem with displaying 16:9 format.
Jul 23, 2009 | Televison & Video
Please tell me my hivion 9191x master codes.
I have Hivion HV9090X Reciver.
I forget his pasword.
anybody tell me Pasword.
May 03, 2009 | Televison & Video
WHEN I UPDATE THE WINDOWS IRECEIVE THE MASSAGE YOU MAY BE AVICTIM
Is this your first time to update your operating system?
This message is a security feature of MS to detect the copy of windows is genuine before it let you update.
It may have been that you installed a pirated copy of windows. But if you are sure that your copy is genuine, contact microsoft as soon as possible and tell them the problem...they may give you a new serial key and instructions to resolve this problem.
hope this helps.
Feb 07, 2009 | Microsoft Windows XP Professional
The power led light keeps flashing
Hi.
Give it a good 'knock' on the back (hard surface). You might hear a clink sound. I think it's when a cog gets out of line. My chair is fine now. You'll notice that the rollers start moving back to the off setting. So if it goes off and they are in the middle or top then it's stuck and needs a thwack!
Dec 01, 2008 | Homedics SBM 300H Therapist Select Shiatsu...
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
Electro Med Services...
