Question about Frigidaire GLEB27T8A Electric Double Oven
After self cleaning lower oven door is locked and cooling fan running. F8 keeps coming up as error code, tried powering off etc, still the same?
  • tdompke Nov 13, 2010
    there is no code that can be entered that will shut the fan off and unlock door?
  • tdompke Nov 14, 2010
    Will this resolve the cooling fan still running?
  • 10,515 Answers
This error means that the oven door is not unlocking even though it's trying. So the computer knows it needs to unlock but for some reason the oven latch can't do so.
Push the door on the lower oven in and hold it. Then start self clean, wait 60 seconds, and cancel self clean. Wait 60 more seconds and see if the door opens. if not then you will need to replace the latch assembly for the bottom oven.
If the problem persists even after replacing latch assembly, then you need to replace control board / clock.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 14, 2010
The F8 error code means you will need to replace the door latch assembly. The part number for the latch is: 88 5303311222 AB. Click on the link below to order a replacement part:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=117692
  • 4,323 Answers
Hi
F8 error is door lock error, which states that the issue is with the door lock switch/latch and to resolve this problem you can change the part that has gone bad. Hope this helps...please post back for further questions.
Daniel
Posted on Nov 13, 2010
GE monogram double oven . Self cleaning top oven and F9 in red showing and beeping noise
F9 is a problem with the oven door lock circuit. If the door is locked, it's probably a bad switch that tells the oven it's locked. If the door isn't locked, it's probably a problem with the lock mechanism.
A common problem on many built-in GE ovens (you don't say if yours is built-in or free standing...) is air circulation in the control panel. The fan that keeps the panel cool either stops working or gets clogged with dirt/dust and can't move any air. This causes the panel to overheat and can cause all kinds of odd problems and error codes. If you have a built-in, check to make sure the fan is working and the mesh screen behind it is clean.
Jul 17, 2016 | GE Monogram ZET3058SHSS Stainless Steel...
Frigidaire Gallery series model GLEB30T8CBA key pad not working
Hello Dana, thank you for your post!
From my understanding your Frigidaire oven is displaying an error code of "F8" and your keypad is not working properly. An "F8" error stands for runaway temperature (overheating). I would recommend performing a reset on your oven and you can do that by disconnecting the power cord for at least ten minutes.
If that does not help correct your issue then you could have a problem with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would suggest having a professional technician out to perform a proper diagnosis and repair. I hope this information is helpful. -Matt
Jan 10, 2016 | Frigidaire 30 in. Electric Gallery Series...
F9 error code appears within two hours of self clean cycle
F9 error code on GE ovens is usually caused by a problem in the door lock/latch system for the self clean. You state it happens about 2 hrs into the clean cycle. My guess is the the control is not sensing that the door is actually locked. Could be several reasons. Bad door lock motor, Bad switch that senses the door is latched, or is some cases the main control board could have a problem and is just not reading the door is locked. You need someone with the right knowledge to trouble shoot which part is actually bad since it could several different problems.
Mar 10, 2015 | GE JTP75 Electric Double Oven
F8 code on my frigidare double oven after cleaning with self cleaning oven ....know this is in the lock but need to know how to fix it myself left it unpluged overnight plugged back in and its still f8...
Hi
Yes F8 is oven door lock error warning.
You need to physically check the door switches and lock relay, these will be inside the oven casing.
It is probably not the easiest of diy jobs as everything is concealed.
Dec 16, 2010 | Ovens
Started to self-clean, locked the door, etc. Had
Hi.
The appliance door is probably locked in consequence of the self cleaning cycle.
Unplug power cord, and allow the oven cooling down for few hours.
If the is still locked, then the high temperature generated in self cleaning cycle may have damaged the door latch, or the electronic control.
Parts must be tested to discover the fault.
Call Frigidaire at the number listed on the owners manual.
Regards.
Mar 03, 2010 | GE Ovens
Oven wont work after self clean
I have a Whirlpool MOD. RBS275PDB17 single electric self-cleaning oven; although the manual is generic, it specifies, "When the cycle is completed and the oven cools, "End" will appear on the lower oven display and "LOCKED' will disappear" and "To Stop Self-Clean any time: Press UPPER/OFF, LOWER/OFF or OFF/CANCEL. If the oven temperature is too high, the door will remain locked. It will not unlock until the oven cools." Has your oven had time to cool?
Jun 13, 2008 | Whirlpool RBS275PD Electric Single Oven
"Door Locked" keeps flashing
Was able to get the lock to go in on the door and then turned off the power which reset the system.
Mar 31, 2008 | GE Profile JTP56 Electric Double Oven
GE self cleaning radiant oven - model JB578GP
I went out to my circuit breakers and turned the circuit off, let the oven cool, and powered it back up after about 2 hours. Fine now.
Feb 17, 2008 | GE Profile JT912 Electric Single Oven
Frigidaire GLEB27T8A Electric Double Oven Logo
66 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
