Question about Memorex MVD2042 DVD Player
DVD Tray won't open
All of a sudden my dvd tray won't open and I have a disk in it as we speak and the player won't respond to the remote or manually trying to get it to open or play. The blue light comes on but no reading in the screen where it use to come on with "Power on" then read the disk and when you shut it off it first read "power off". Once the blue light is on for a bit then it goes into stand by mode. Will not respond to anything I do and this just all of a sudden happened out of no where. How can I
1. get the disk out?
2. get it to respond again
3. Is there such a thing as a 're set"?
  • Anonymous Jul 20, 2008
    Yes, it's 2008 now and the player turns on. That's it. Nothing works. I'm trying to find a reset button or set of procedures to reset it. Unless I see some reset button inside the box. Meanwhile, I'm cruising the net for answers.
  • broncjon Sep 01, 2008
    Very similar problem. I only see the standby light. Nothing else comes on and there's DVD loaded that I'd like to at least get out of it.
The quickest way I've found is to just remove the upper casing, unscrew the disk holder and take the disk out that way. The disk holder will look like the silver part in this picture http://www.vintagecomputing.com/wp-content/images/nesdvd/nesdvd_03_large.jpg although your could be black or other color.
Posted on Sep 28, 2008
DVD ' s tray won't open when pres OPEN, DVD is inside
There are little gears to open the tray with a little rubber belt that drives it you should be able to open door and pull on tray to get disk out if not unplug it take top off push tray out Cheapper to replace player than to fix but little flap should pull down grab tray and pull
Feb 21, 2013 | RCA DRC247N DVD Player
Unlock region on dvd player
please see the next steps: God bless you
  • 1 Turn on the DVD player.
  • 2 Open the DVD disc tray and keep it open. Power on your DVD player and open the disk tray. Leave the tray open as DVD region code hacks need the tray to be open as the code is entered for it to get activated.
  • 3 Press the "Home" key on the DVD remote.
  • 4 Select the "Setup" option.
  • 5 Select the "Lock" icon by using the arrow keys on the remote control.
  • 6 Press the number key "0," seven times on the remote. This is the code-"0000000."
  • 7 Confirm by selecting "OK" when you get the "Region Free" message. Insert an import DVD to test the DVD player.
  • 8 Repeat the steps again if the you encounter problems playing the DVD as you may have missed something.
Aug 01, 2012 | LG Televison & Video
CHANGE REGION RHT390H
see this steps:
  • God bless you
    Jul 16, 2012 | LG Televison & Video
    Sony RDR-GX360 won't respond to any buttons on unit or remote. Only function that works is power button. Disk tray won't even open.
    Try unplug,replug the unit back like about an hour later for the unit for resetting itself back to factory setting.If getting the same result the unit might have a shorted motor drive for the disc tray.Or shorted control panel on the unit itself.Well,this thing a basic DVD player only wright?If u can tries take it aparts and check out tries to repair it ur self that great.If u tries the shops,not worth it.Trash it.These basic DVD player only are very cheap now.U can get one brand new like $40 dollars.
    Aug 11, 2011 | Sony DVP-S360D DVD Player
    How can I change the region on my Toshiba SD K860?
    1. Power on the DVD player
    2. Press the Open/close button on your remote control to open the drive tray and remove any disk
    3. Press 2403960
    4. Press 9 for multi-region playback. DO NOT Press Enter button on your remote control
    5. You will see a 9 (region-free) on the TV (right corner)
    6. Press the Open/close button on your remote control to close the drive tray
    7. Power off the DVD player
    8. Power on the DVD player and it is region free.
    May 22, 2011 | Televison & Video
    Need code to unlock international dvd's on a samsung htbd2t blu-ray dvd player
    hope this helps
    1. Open tray and remove any disks in tray.
    2. Close tray.
    3. Switch Off Player and Unplug from mains wait 30 seconds (this clears RAM)
    4. Reconnect to mains
    5. Turn on player with remote.
    6. Press ENTER on remote.
    5. Press 8, 4, 2, 6, 9.
    7. Press ENTER on remote. (The tray will open)
    8. Switch off power from remote, then switch back on.
    9. Player is now Region Free.
    Nov 23, 2008 | Televison & Video
    Region Settings
    Turn Player On
    Open The Disk Tray (Leave Open)
    On Remote Control Press Stop
    On Remote Control Press 1.3.6.9 and 0 (Zero)
    Close Disk Tray
    Power Off
    or
    Turn Player On
    On Remote Control Press Clear
    Close Disk Tray
    Power Off
    Jun 28, 2008 | Disney DTD1363-CAR 13" TV/DVD
    "safe" keeps me from opening dvd tray manually (must use remote control)
    I unplugged the recorder for 10 seconds, replugged it in and voila, the problem was solved.
    Walt in Indiana
    Apr 11, 2008 | GoVideo VR3845 DVD Recorder/VCR
    Not recognizing DVD player
    i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
    get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
    Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
    DVD Tray will not open
    Uhm..
    Unplug it/turn it on and off
    Try to press the eject button and lightly pry the tray open with your fingers.
    Call support.
    Good luck
    Dec 21, 2007 | Jwin JD-VD130 DVD Player
    Memorex MVD2042 DVD Player Logo
    190 people viewed this question
    Top Memorex Televison & Video Experts
     Grubhead
    Grubhead
    Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
