I have a lcd toshiba 37RV753 , when i turn on the screen comes for 2 sec. then the green standby light goes flashing yellow , what could be the problem and how to fix it ?? Thanks
  • 14 more comments
  • RUI MOREIRA
    RUI MOREIRA Nov 13, 2010
    Hi, the light keeps flashing with no pause .
  • RUI MOREIRA
    RUI MOREIRA Nov 15, 2010
    Hello, sorry only now, but weekend :)
    yes i have knolledge about electronics, can you help me ??
  • RUI MOREIRA
  • RUI MOREIRA
    not when turns off , but when i turn on the led on the front is red, then i put on , the screen appears for 2sec. then the led gets yellow and flashing without pause.
  • RUI MOREIRA
    the power supply is faulty ! can i repair it, because i have some experience in electronics
  • RUI MOREIRA
    Ok thanks, just to confirm is the power board i need to replace ( dps-145-pp-131 ) ??
  • RUI MOREIRA
    Thanks you are the man :) !!!
  • RUI MOREIRA
    RUI MOREIRA Nov 17, 2010
    Hello, i bought and replace the power supply , but the problem still what can i do now :( ??
  • RUI MOREIRA
    please tell me something about this .
    Thanks
  • RUI MOREIRA
    i bought the power supply but still the same problem
  • RUI MOREIRA
    everything is like was before and i already spend in an new power supply, i compare both, all the components are ok :(
  • RUI MOREIRA
    no improves, is like the other one , i compare components with both power supplys they are the same , so the power supply is not faulty :(:(
  • RUI MOREIRA
    No, the only that flash is the led on the front (flashing yellow) on the back the green one on the main board is still
  • RUI MOREIRA
    i think is the inverter because i disconnect the inverter and the same result (led flashing) can you advise here to find the inverter ??
  • RUI MOREIRA
    what do you advise now ?
  • RUI MOREIRA
    yes please try to find me the part ?
    thanks
  • 4,889 Answers
The tv is turning off due to somekind of protection fault. Can you tell me how many times the yellow light flashes in between each pause?
Posted on Nov 13, 2010
  • 8 more comments
  • eagle338
    eagle338 Nov 13, 2010
    There are a lot of things that can cause this problem on an LCD the most common being, faulty protection circuits on a power supply, overload due to plagued capacitors and last but not least faulty balancer circuits due to one of the CFL backlights inside the panel malfunctioning. We are gonna have to do component level diagnosis to determine the source of the problem, which begs the question - Do you have experience working on electronic circuits before? Do you know how to work with a multimeter and how to solder? If yes then let me know and I will see you through this. Otherwise please get me your zipcode so that I can get you a list of techs in your area.
  • eagle338
    eagle338 Nov 15, 2010
    When it turns off, the LED at the front blinks right? How many times does it blink in between each pause?
  • eagle338
    Ok. That confirms it. Faulty inverter voltage from the power supply seems to be the cause. I can find you one online for about 75-100$ if you want to do it yourself.
  • eagle338
    Not this one. The pins from which the voltage goes to the inverter, are attached to a solid state component. It is irreplaceable. Replacing the board is the only solution.
  • eagle338
    Yes that is it. Make sure that the entire part number matches with the one in our set.
    http://cgi.ebay.ie/PSU-TOSHIBA-32-TV-32R...
  • eagle338
    eagle338 Nov 17, 2010
    No improvement at all?Like the power light staying green instead of clicking or something?
  • eagle338
    Please take off the back cover of the tv, and see if the LEDs on any of the boards flash. Its a self-diagnostic function that can possibly detect the cause of the failure. Try it and let me know
  • eagle338
    The inverter? If the inverter is disconnected, it won't even attempt to start and the LED just blinks. However if you insist, I can find you the part
  • eagle338
    eagle338 Nov 18, 2010
    The one in the first two images(20i and 19m) looks like the main SSB. What is the part number? 5.27 B5 is not the part number. What other numbers do you see on the board?
  • eagle338
    eagle338 Nov 20, 2010
    Ok. If you just get me the part number off the inverter board, I will be glad to find you a replacement. Do you know what it looks like?
Problem with a Sony KLV-26HG2 LCD tv switching on for 2 secs then switching off/ flashing standby light
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices
http://electro-medical.blogspot.com/
Apr 12, 2012 | Sony WEGA KLV-26HG2 26 in. HD-Ready LCD...
My toshiba 42" REGZA 42RV535U
U have sound but no picture?Picture does flashes a few sec?Yes,than those 2 long LCD inverter boards are dead.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 long LCD inverter boards for the replacement.
Jan 13, 2011 | Televison & Video
Lg Flatron 17" monitor turns on you see the green light then
it's prb.. your video card not the moniter if a moniter goes from green to yellow " standby" it's prb the computer not the moniter
Dec 27, 2009 | LG Flatron L1715S 17" LCD Monitor
Unit will not come on - popping with only red ready light
Have you fixed this yet?Please let me know.Thank You very much!
Tyler
Apr 08, 2009 | Akai LCT2660 26 in. HD-Ready LCD...
42 in SONY LCD flat screen has red light blinking and won't turn on
Does the red light blink in a discernible pattern? How many times does it flash or blink?
Jul 11, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Jun 26, 2008 | Toshiba 62HM95 62" HDTV
Green screen crash
i have a projection tv. It is a a Samsung HDTV 55" widescreen. There is a green curvey lines at top of screen. Can you help?
Jan 20, 2008 | Televison & Video
Monitor remains in standby
turn the monitor off and the computer off. unplug it from the wall. let set for 10 sec. make sure you have it in the right place and in all the way. turn computer back on, then the monitor.
Dec 18, 2007 | X2Gen MG15VT 15" LCD Monitor
Televison & Video Logo
367 people viewed this question
Top Televison & Video Experts
