Question about HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001
Switch on one second go off - HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 106 Answers
Thanks for using fixya, looks like you have a motherboard problem try this:
1- disconnect all the power and take out the bat. , after that press the power for 10sec.
2- put only the charger (without the bat.) and try to boot
if this dont work, try :
1- take one buy one the ram memory out and try to boot.
if boot with one ram out is because that ran is faulty , if none of the cases work, your motherboard needs to be repaired or replaced.
Thanks
Posted on Nov 13, 2010
I called myself programming the new keys for my pt cruiser, but,it didnt take. At first it would start and run for a few seconds, now it wont turn over.what did I do wrong and how can I fix this?
Takes the master key to get it started again. The security gives you 3 tries to get the vehicle started, after the third time, it kills the starter.
2002 Chrysler PT Cruiser Note: You must have two valid keys to add a new key to the system.
1. Insert the first valid key into the ignition switch. Turn the ignition switch to the
ON/RUN position for at least three seconds, but no longer than 15 seconds.
Then, Turn the ignition switch to the LOCK position and remove the first key.
2. Insert the second valid key into the ignition switch. Turn the ignition switch to
the ON/RUN position within 15 seconds. After 10 seconds, a chime will sound.
In addition, the Vehicle Security Light will begin to flash. Turn the ignition switch
to the LOCK position and remove the second key.
3. Insert the new key into the ignition switch. Turn the ignition switch to the
ON/RUN position.within 60 seconds. After 10 seconds, a single chime will
sound. In addition, the Vehicle Security Light will stop flashing. To indicate that
programming is complete, the Vehicle Security Light will turn on again for
seconds and then turn off.
The new key is now programmed. The Remote Keyless Entry transmitter will
also be programmed during this procedure.
Repeat this procedure to program up to eight keys.
Oct 09, 2016 | Cars & Trucks
How can i get a manual for 2005 jeep liberty ?
Owners manual.. Dealer with he VIN#. Mechanics manual, any parts store. It covers all the Liberty's.
Oct 27, 2015 | 2005 Jeep Liberty
My kindle will not start up even though it has battery charge. Is there a soft reboot?
Yes:
  1. Get a watch with a hand for the seconds.
  2. Slide and hold the power switch for 7 seconds. After about 5 seconds the power light flashes three times. After 7 seconds, the screen will go blank and the device is switched off now. Release the switch.
  3. Slide and hold the power switch for 15 seconds (no more, no less). Do not hold the switch too long, the time window for the reset is not very big.
  4. After releasing the switch just wait. The Kindle will reboot after a few seconds.
Jan 24, 2011 | Amazon Kindle 3G
Acura RL 2000 Remote needs Program Instructions
TURN ON IGNITION SWITCH WITH ENGINE OFF.POINT THE REMOTE TRANSMITTER AT CENTRAL LOCKING SIGNAL CONTROL MODULE LOCATED BEHIND PASSENGERS SIDE C POST.WITHIN 4 SECONDS PRESS LOCK OR UNLOCK.WITH REMOTE TRANSMITTER.WITHIN 4 SECONDS SWITCH IGNITION OFF.WITHIN 4 SECONDS SWITCH ON IGNITION WITH ENGINE OFF.WITHIN 4 SECONDS PRESS LOCK OR UNLOCK USING REMOTE TRANSMITTER.WITHIN 4 SECONDS SWITCH OFF IGNITION SWITCH.REMOVES KEYS FROM IGNITION SWITCH WAIT 10 SECONDS THEN TRY USING REMOTE TO SEE IF IT WORKS DOOR LOCKS.IF THIS PROCEDURE DONT WORK.TAKE TO DEALERSHIP.
Jun 22, 2010 | 2000 Acura 3.5RL
Flashing alarm light after battery change. Car wont start,
System operation
System arms 5 seconds after switching ignition OFF. Switch ignition ON. Ensure clock LED illuminates for 3-5 seconds. If LED flashes rapidly at regular intervals for approximately 1 minute, then flashes at irregular intervals: Key code not recognised. Remove key and try again.
Programming
When
System malfunction: LED illuminates for 1 minute, then flashes at irregular intervals. Key(s) added or replaced.
NOTE: Replacement keys MUST have blue mark. Keys with red mark are NOT compatible with this system.
How
NOTE: Programming method using vehicle keys can be deactivated using diagnostic equipment.
Obtain 2 programmed keys (A and B). Insert key A into ignition switch. Turn ignition switch to position II. Wait 1 second. Switch ignition OFF. Remove key A. Insert key B into ignition switch within 5 seconds. Turn ignition switch to position II. Wait 1 second. Switch ignition OFF. Remove key B. Within 10 seconds: Insert key to be programmed into ignition switch. Turn ignition switch to position II. Wait 4 seconds. Switch ignition OFF. Wait 5 seconds. Start engine. If engine does not start and clock LED flashes: Switch ignition ON. Wait at least 20 seconds. Switch ignition OFF. Repeat programming procedure. Repeat above procedure to program remaining keys. Keys can also be programmed using diagnostic equipment
Mar 08, 2010 | 2000 Ford Focus
Central locking fob
Programming
When
Remote control buttons operated repeatedly while vehicle out of range and system becomes inoperative. System malfunction.
How
Ensure ignition switched OFF and all doors closed. Proceed as follows: Within 10 seconds, open driver's door and switch ignition ON. Within 10 seconds of switching ignition ON, switch ignition OFF. Within 20 seconds of switching ignition OFF, press and release driver's door contact switch 3 times. Within 10 seconds of releasing driver's door contact switch, switch ignition ON then OFF. Within 20 seconds of switching ignition OFF, press and hold both remote control buttons in turn for at least 5 seconds. The driver's door should lock and unlock once. Within 5 seconds of driver's door locking/unlocking, press remote control lock button Fig. 1 [1] or unlock button [2]. Programming procedure complete. Confirm programming has been successful by locking and unlocking vehicle.
NOTE: A maximum of 2 remote controls can be programmed.
Feb 05, 2010 | 2002 Suzuki Grand Vitara
2004 jeep cherokee alarm won't disarm
Switch ignition ON and OFF within 15 seconds. Using second programmed key, proceed as follows: Switch ignition ON and OFF within 15 seconds. Within 10 seconds: Immobilizer LED flashes. Programming mode activated (acoustic signal will be heard). Proceed as follows: Within 50 seconds: Insert first key to be programmed into ignition switch. Switch ignition ON and OFF. Within 10 seconds: Single acoustic signal will be heard and immobilizer LED stops flashing and illuminates for 3 seconds to indicate correct programming. Repeat complete procedure to program remaining keys. Keys can also be programmed using diagnostic equipment.
NOTE: A maximum of 8 keys can be programmed.
Dec 29, 2009 | 2004 Jeep Grand Cherokee
Power Door Light Stays on after battery was changed by a service department
follow this to reinitialize
1. Push the “MAIN” power switch to the “OFF” position.
The “MAIN” power switch is located on the instrument panel, left of the
steering column.
2. Confirm doors are closed, lights are OFF, and the key is out of the ignition.
3. Disconnect the negative (–) battery terminal and wait 60 seconds.
4. Reconnect the negative (–) battery terminal.
5. Push the “MAIN” power switch to the “ON” position and wait 3 seconds.
6. Push the “DOOR R” switch to open the right door and wait 3 seconds after the door
is completely opened.
7. Push the “DOOR R” switch to close the right door and wait 3 seconds after the door
is completely closed.
8. Push the “DOOR R” switch to open the right door and wait 3 seconds after the door
9. Push the “DOOR R” switch to close the right door and wait 3 seconds after the door
10. Push the “DOOR L” switch to open the left door and wait 3 seconds after the door is
completely opened.
11. Push the “DOOR L” switch to close the left door and wait 3 seconds after the door is
completely closed.
12. Push the “DOOR L” switch to open the left door and wait 3 seconds after the door is
completely opened.
13. Push the “DOOR L” switch to close the left door and wait for the door to
completely close.
With ignition in the “ON” position and both power sliding doors in the fully closed
position, the “PWR DOOR” indicator on the dash should NOT illuminate.
14. Confirm proper operation of both doors using the dash, B-pillar switches, and the
transmitter button
Aug 12, 2009 | 2001 Toyota Sienna
1999 olds aurora when you turn the key just says clean key wait 3 minutes
the key has magnet on it that may be weakening. It will have to be reprogrammed.
  1. Insert the first valid key into the ignition switch and turn the ignition switch ON for at least 3 seconds but no longer than 15 seconds. Turn the ignition switch OFF and remove the first key.
  2. Insert the second valid key and turn the ignition switch ON within 15 seconds. After ten seconds a chime will sound and the Theft Alarm Light will begin to flash. Turn the ignition switch OFF and remove the second key.
  3. Insert a new Key into the ignition switch and turn the ignition switch ON within 60 seconds. After 10 seconds a single chime will sound. The Theft Alarm Light will stop flashing, turn on for 3 seconds; then turn off. The new key has been programmed.
Jul 07, 2009 | 1999 Oldsmobile Aurora
Nissan Installed throttle reprogram
Here is the way to do it without the nissan scan tool. Make sure to follow all steps and it it best if you use a watch with a second hand.
1. Perform "Accelerator Pedal Released Position Learning".
a. Make sure that accelerator pedal is fully released.
b. Turn ignition switch 'ON' and wait at least 2 seconds.
c. Turn ignition switch 'OFF' wait at least 10 seconds.
d. Turn ignition switch 'ON' and wait at least 2 seconds.
e. Turn ignition switch 'OFF' wait at least 10 seconds.
2. Perform "Throttle Valve Closed Position Learning" .
b. Turn ignition switch 'ON'.
Make sure that throttle valve moves during above 10 seconds by confirming the operating sound. 3. Start engine and warm it up to normal operating temperature.
4. Check that all items listed under the topic 'PREPARATION' (previously mentioned) are in good order.
5. Turn ignition switch 'OFF' and wait at least 10 seconds.
6. Confirm that accelerator pedal is fully released, turn ignition switch 'ON' and wait 3 seconds.
7. Repeat the following procedure quickly five times within 5 seconds.
a. Fully depress the accelerator pedal.
b. Fully release the accelerator pedal. 8. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the MIL stops blinking and turned ON.
9. Fully release the accelerator pedal within 3 seconds after the MIL goes off.
10. Start engine and let it idle.
11. Wait 20 seconds.
12. Rev up the engine two or three times and make sure that idle speed and ignition timing are within the specifications.
13. If idle speed and ignition timing are not within the specification, the result will be incomplete. In this case, more test needs to be done.
Jun 24, 2009 | 2004 Nissan Sentra
HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001  Logo
85 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
