Question about Hitachi 42PD6600 42 in. HD-Ready Plasma Television
I have a green line appearing down the middle of the picture any ideas? Is it fiaxable or should I just ditch it?
    President:
  • 357 Answers
Hi cdgittins
This problem could be caused by various things. First of all, it could be caused by a faulty cable from the viewing device (DVD Player etc.) or it could be a fault on the TV itself or it could be a fault in the viewing device. To determine where the problem is, change the channel to a different channel that has nothing stored on it so that your screen will appear either blue or it will look like it is receiving static (many black and white dots), if the line is still there then you have a fault with the TV and you will have to take the TV to a repairman who will troubleshoot where the problem is on the circuit board and fix it. You cannot repair the TV yourself because specialized equipment is required to find the fault.
If the line is no longer there, try and replace the cable from the viewing device. If the problem is still there then the viewing device is faulty, then you should purchase a new device or get the other one repaired and this should solve your problem.
Thank you for using FixYa! Have a great day and please remember to rate this solution.
Best regards,
BearWeb
Posted on Nov 13, 2010
Yellow stripe across middle of the picture
yes rteh color of the wires(ends)red,blue,green,sounds like they may ahve gone bad or are interchanged, what does it do with a dvd picture
May 23, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Green picture
a green screen on power up with retrace lines. At shut down a point appears in the middle of the screen. Sounds like either a shorted G2 grid, or bad flyback. If a phospher flake has shorted the grid in the tube, you can sometimes have luck by using a megger set at 1000VDC, to burn away the short. This is usually caused by the line HV going too high causing the anti-UV protection to kick in so fit a dummy load 40W lamp instead to the line output to allow measurements to be made.
Oct 19, 2008 | RCA 20F512T 20" TV
42HDS69 42 in. Plasma has several thin green vertical lines in middle of screen
If the set is still in warranty, call for warranty service. If not and you feel comfortable working on the set, carefully open up the back and reseat all of hte cables and connectors. This can be caused by marginal connections inside the set.
Keep us posted on your progress and results.
Dan
Aug 29, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Red,Blue,Green Image
YOu have convergence issues. Ok first question. IN your setup menu do you have the convergence option/ if you DO not then it can be a specail fusable link. fl231 if you do. next question do the picture bow in at the middle. if you do then it possibly a convergence power supply issue. next if you go into setup convergence does the crosshairs adjust up or down left to right on both blue and red. I if so then theres is a chance that it can be a convergence adjusment or a amplifer problem AS always THIS SET CAN GENERATE LEATHAL 380 VOLTS EVEN WITH SET UPLUGED SO BE CAREFULL.
Jun 20, 2008 | RCA HD52W59 HDTV Projection Television
Red box half way down screen
I am getting re or blue lines running vertically on my Tv. They are not there all the time just now and then. Can I fix it with my remote or do I need a tech?
Jun 16, 2008 | Hitachi 55HDS69 55 in. Plasma Television
No picture but has blue green and red light down middle and sound
Most likely a blown Vertical deflection output IC. In most (but not all) Panasonic, the vertical IC is an AN55XX.
Repairs should be fairly easy with basic knowledge of electronic circuitry and components and a little soldering. I would expect the IC to be readily available at any electronics part store. Should you be uncomfortable doing a DIY, perhaps your best bet would be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 28, 2008 | Panasonic PT-51HX43 51" Rear Projection...
Blue screen with Green Star-burst image in center?
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jan 19, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi VS-60111 picture distorted
how do I manually switch my t.v. from 480i to 1080i on dtv with remote.
Dec 31, 2007 | Mitsubishi VS-70707 70" Rear Projection...
Hitachi 42PD6600 42 in. HD-Ready Plasma Television Logo
128 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
